STM32/STM8技术论坛
直播中
冬妮
8年用户 214经验值
私信 关注
[问答]
利用stm32输出可调的PFM波但ADC不起作用是什么原因
本人刚学STM32,想用stm32输出可调的PFM波,通过一个可调电阻来调节PFM波,但ADC不起作用,无论怎么调都还是输出300KHz的PFM波,即ADC为0,下面是程序,请大侠们指教。
int main(void)
        u32 ad1=0;
        u32 ad2=0;
        RCC_Configuration();
    GPIO_Configuration();
        ADC_Configuration();
    Tim1_Configuration();
        while(1)
                ad1=ADC_GetConversionValue(ADC1);
                ad2=ad1*3.3/4095;
                if(ad2>3)
                         TIM_SetAutoreload(TIM1,119);
                         TIM_SetCompare1(TIM1,60);        //设定占空比
                if((ad2>=2.5)&&(ad2<=3))
                         TIM_SetAutoreload(TIM1,99);
                         TIM_SetCompare1(TIM1,50);        //设定占空比
                if((ad2>=2)&&(ad2<=2.5))
                         TIM_SetAutoreload(TIM1,79);
                         TIM_SetCompare1(TIM1,40);        //设定占空比
                if((ad2>=1.5)&&(ad2<=2))
                         TIM_SetAutoreload(TIM1,59);
                         TIM_SetCompare1(TIM1,30);        //设定占空比
                if(ad2<1.5)
                         TIM_SetAutoreload(TIM1,39);
                         TIM_SetCompare1(TIM1,20);        //设定占空比
void GPIO_Configuration(void)        //端口初始程序,可初始化多组管脚,串口要用到PA9、10做输入输出
        /*输出管脚初始化*/
        GPIO_InitTypeDef GPIO_InitStructure;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;        //
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        /*初始化相应的GPIO*/
        GPIO_Init(GPIOA, &GPIO_InitStructure);
//        输入管脚初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
//        初始化相应的GPIO
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        //ADC输入
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
void RCC_Configuration(void)        //时钟初始程序
{    SystemInit();        //系统时钟频率72MHz            /*打开GPIOX使用的GPIO的时钟使能*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
RCC_ADCCLKConfig(RCC_PCLK2_Div6);//6分频为12M}
void Tim1_Configuration(void)
{                TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_BDTRInitTypeDef TIM_BDTRInitStructure;    //第三步,定时器基本配置
TIM_TimeBaseStructure.TIM_Period=150-1;             // 自动重装载寄存器的值
TIM_TimeBaseStructure.TIM_Prescaler=6-1;            // 时钟预分频数
TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;    // 采样分频
TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//向上计数
TIM_TimeBaseStructure.TIM_RepetitionCounter=0;//重复寄存器,用于自动更新pwm占空比
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);        //第四步pwm输出配置
TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;                    //设置为pwm1输出模式
TIM_OCInitStructure.TIM_Pulse=75;                                  TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;                 //设置输出极性        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;        //使能该通道输出        //下面几个参数是高级定时器才会用到,通用定时器不用配置        TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_High;        //设置互补端输出极性
TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;//使能互补端输出
TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Reset;        //死区后输出状态
TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;//死区后互补端输出状态
TIM_OC1Init(TIM1,&TIM_OCInitStructure);                                            //按照指定参数初始化        //第五步,死区和刹车功能配置,高级定时器才有的,通用定时器不用配置        TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Disable;//运行模式下输出选择
TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Disable;//空闲模式下输出选择
TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;         //锁定设置
TIM_BDTRInitStructure.TIM_DeadTime = 42;                                         //死区时间设置
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;                 //刹车功能使能
TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;//刹车输入极性
TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;//自动输出使能
TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);        //第六步,使能端的打开
TIM_Cmd(TIM1,ENABLE);                                                           //打开TIM2
TIM_CtrlPWMOutputs(TIM1, ENABLE);                                   //pwm输出使能,一定要记得打开}
void ADC_Configuration(void) //配置数模转换
{        ADC_InitTypeDef ADC_InitStructure;
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = DISABLE;//多通道扫描模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//循环采样
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//转换由软件而不是外部触发启动
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 1; //转换通道数量
ADC_Init(ADC1, &ADC_InitStructure);                  //定义规则组
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_239Cycles5);
ADC_Cmd(ADC1, ENABLE);//ADC使能
  ADC_ResetCalibration(ADC1);         //ADC复位
while(ADC_GetResetCalibrationStatus(ADC1));
ADC_StartCalibration(ADC1);        //ADC校准
while(ADC_GetCalibrationStatus(ADC1));
ADC_SoftwareStartConvCmd(ADC1, ENABLE);//启动ADC}
回帖(10)
庄金樱
2018-9-20 09:40:24
输出不是DAC么,ADC是输入的呀。。
举报
陈萍
2018-9-20 09:59:26
太长了,顶一下吧。。。
举报
冬妮
2018-9-20 10:14:49
引用: vuweurvxs 发表于 2018-9-20 11:16
输出不是DAC么,ADC是输入的呀。。
是用ADC输入,我用一个可调电阻个给相应的引脚输入电压信号来控制PFM,但无论怎么调都没有反应。
举报
袁富存
2018-9-20 10:21:24
PFM ?PWM吧,首先调试下ADC采集的结果保存在那个变量里,值正确吗,用这个值去控制TIM比较输出。
你的问题是程序没写对
举报
冬妮
2018-9-20 10:27:23
你的问题是程序没写对
你好,想请教一下,用什么方法来调试ADC采集结果,我程序中是什么地方出现问题,由于刚接触STM32有很多不懂得地方,恳请大家指教!!!
举报
袁富存
2018-9-20 10:41:04
用串口啊
举报
陈俊
2018-9-20 11:00:23
PFM波是什么
举报
孙婷婷
2018-9-20 11:15:43
要先设置AD采集通道、开启AD时钟、通过单独或者连续采集的方法,采集到数据放入到一个缓冲区中,达到缓冲区满以后,输出AD数据,并清空缓冲区重新开始采集。
举报
范潇潇
2018-9-20 11:34:17
支持学习
举报
董薇
2018-9-20 11:42:18
学习一下!
举报
更多回帖
