PMP15006 is a miniature (15 mm X 15 mm) Fly-Buck™ reference design using the LM5017. The primary and secondary outputs are set at +/-5V nominal. This ultra-compact design accommodates an input voltage range from 18V to 30V, and a nominal input voltage of 24V. The primary side is set at (...)
主要特色
18V to 30Vin, 5V @250 mA (dual) output, 2.5W (one non-isolated primary and one isolated secondary)
~82% peak efficiency
Compact and cost effective isolated solution with an off-the-shelf coupled inductor instead of a custom transformer
Board size: 15 x 15 mm; max component height: 3.5 mm
