The PMP5653 reference design uses the TPS54060 DC/DC converter to generate dual outputs providing +-31V at up to 70mA. The high-side MOSFET is incorporated inside the TPS54060. The negative output is used as the ground reference for the converter, which allows the regulation of the positive and (...)
主要特色
Inverting buck-boost using a simple buck converter
