看起来这是你的第一篇文章 - 如果这样欢迎!
我非常喜欢VEE中的整洁:我认为值得花几分钟时间让事情变得合理而整洁,所以我很高兴看到你的代码(或者至少你发布的代码!)很容易
-读书。
我认为你的问题很容易解决:运行未连接线程的顺序是'未定义',所以,除非你导入的Specan lib有任何连接,否则错误是在导入之前调用库。
当然很容易解决:通常我有一个'Initialise'UF(UserFunction),在运行其他任何东西之前都有所有导入,定义变量的设置等。
您可以这样做,或者只是将您的Specan导入的序列输出引脚连接到其他导入的引脚序列。
如果已经是这种情况(但未在Word文档中显示),请重新发布。
以上来自于谷歌翻译
以下为原文
Looks like this is your first post - if so welcome!
I'm a big fan of neatness in VEE: I think it well worth the few minutes needed to put things into a logical and tidy fashion, so I was pleased to see your code ( or at least that which you posted! ) was easy-to-read.
I'm thinking your problem is simple to fix: the order of running unconnected threads is 'undefined', so, unless there is anything connected to your import of Specan lib then the bug is that the call to the library happens before the import.
Very easy to fix that of course: typically I have an 'Initialise' UF ( UserFunction ) which has all imports, setting of defined variables etc. before anything else is run. You could do the same or simply connect the sequence out pin of your Specan import to the sequence in pin of the other imports.
Please re-post if that is already the case ( but not shown in your Word doc ).
-读书。
以上来自于谷歌翻译
以下为原文
举报
