Microchip
直播中
张昂笙
9年用户 1109经验值
私信 关注
[问答]
mTouch V2.50新选项是什么意思
Buttons tab的新选择有什么解释吗?暂停/禁用MODESREST MODEL JeMeMy。
以上来自于百度翻译
      以下为原文
    Is there any explanations anywhere of the new options under the Buttons tab?
Suspend/Disable Modes
Reburst Mode
Jeremy.
   Attached Image(s)
回帖(1)
卜臻敏
2018-9-18 15:00:13
HI杰瑞米,暂停/禁用个别按钮和接近传感器现在可以暂停或禁用应用程序代码。使用MouthChuthButoNoxDabable()/MouthChiRealthIyDeable()禁用按钮/接近传感器。禁用的按钮/接近传感器将停止它的传感器扫描和基线更新。使用MouthChuthButoNoxRead Enter()/MouthChiRealyTySythEnter()来挂起一个按钮/接近传感器。暂停按钮/接近传感器将停止其传感器扫描,但将周期性扫描以进行基线更新。使用MouthChyButoNoReuMeMe(/MouthChiRealthIyReuMeMe)重新激活禁用/挂起的按钮/接近传感器。按钮/接近传感器将继续与现有的传感器配置。ReurBurStruSurb用于改善系统响应时间,同时解决按钮和接近传感器的检测状态。当超过传感器阈值时,在该传感器上进行多个测量以解决检测状态。不是AKS组的一部分的传感器,或者可以被禁用以减少处理时间。采用三种模式的再爆裂:所有的传感器都没有发生故障,所有的传感器都重新确定检测状态。再爆裂没有解决:只对同一个ACK组的传感器进行爆裂,其余的都暂停(减少处理)。Reburst没有:标准捕获。我会来MICHCHIPDealth.com
以上来自于百度翻译
      以下为原文
    Hi Jeremy,
Suspend / Disable
Individual buttons and proximity sensors can now be suspended or disabled by application code.
  • Use MTOUCH_Button_Disable() / MTOUCH_Proximity_Disable() to disable a button / proximity sensor. A disabled button/proximity sensor will stop its sensor scanning and baseline updating.
  • Use MTOUCH_Button_Suspend() / MTOUCH_Proximity_Suspend() to suspend a button/proximity sensor. A suspended button/proximity sensor will stop its sensor scanning but will scan periodically for baseline updating.
  • Use MTOUCH_Button_Resume() / MTOUCH_Proximity_Resume() to reactivate a disabled/suspended button / proximity sensor. The button/proximity sensor will continue with the existing sensor configuration.
Reburst
Reburst is used to improve the system response time while resolving detect state for both buttons and proximity sensors. When a sensor threshold is exceeded, multiple measurements are taken on that sensor to resolve the detect status. Sensors that are not part of the AKS Group or may be disabled to reduce the processing time. Three modes of Reburst are used:
  • Reburst All : No sensor suspension takes place, all sensors reburst to determine detect status.
  • Reburst Unresolved : Reburst sensors only part of same AKS Group, all others suspended (reduced processing).
  • Reburst None : standard acquisition only.
All these explanations will be coming to the microchipdeveloper.com.
-Xiang
举报
更多回帖
