CYUSB的来源有LiPulb API。但它们似乎没有使用LuBubxDeViMeMyOLLC()API。
例如,批量数据传输是使用CysBuBulkJuffic API完成的,内部调用LiBubSulkkType()API。这调用了LIUBBUBALLOLJORACTION API,它为传输分配了一些预定义的内存。
供参考:
你可以在这里下载CyUSB Linux主机源码:
CyPAS-FX3-SDK-Linux/UTIL/CysBBLILUXX1.1.4在Master·NekdAdvo/CyPress -FX3-SDK-Linux·GITHUB
此外,LYBUB开放源代码可以在这里下载:
HTTPS:/SooSurfFuG.NET/PROSPIDS/LIUBSB/?源= Type重定向
当做,
- Madhu Sudhan
以上来自于百度翻译
以下为原文
The source of cyu*** has libu*** APIs. But they do not seem to use the libu***_dev_mem_alloc () API.
For example the bulk data transfer is done using the cyu***_bulk_transfer API which internally calls libu***_bulk_transfer () API. This calls the libu***_alloc_transfer API which allocates some predefined memory for the transfer to take place.
For reference:
You can download the cyu*** linux host source here:
cypress-fx3-sdk-linux/util/cyu***_linux_1.0.4 at master · nickdademo/cypress-fx3-sdk-linux · GitHub
Also, the libu*** open source can be donwloaded here:
https://sourceforge.net/projects/libu***/?source=typ_redirect
Regards,
- Madhu Sudhan
供参考:
当做,
- Madhu Sudhan
以上来自于百度翻译
以下为原文
For reference:
Regards,
- Madhu Sudhan
举报
