英伟达
直播中
李振云
8年用户 165经验值
私信 关注
[问答]
Linux VDA如何启用H.264编码?
你好
真的是冠军。
我有一个安装了7.13 VDA的Linux VM。
有谁知道如何启用H.264编码?
我会告诉我这不是一个Linux家伙,所以有可能误解了一些东西......
我分配了M60 8Q配置文件,因此可以使用CUDA。
已安装GRID 4.1驱动程序并且已获得许可。
我正在关注本指南:http://docs.citrix.com/en-us/linux-virtual-delivery-agent/7-13/configuration/configuring-graphics.html
但是,当我尝试在VDA上运行时:
sudo ctxreg create -k“HKLM  System  CurrentControlSet  Control  Citrix  Thinwire”-t“REG_DWORD”-v“AdvertiseH264”-d“0x00000001”--force
我得到了回应:
sudo:ctxreg:找不到命令
我最初的想法是,我正在尝试在Linux VM上安装Windows注册表项,当然它不起作用。
但是,作为一个非Linux的家伙,我其实不知道。
通常的说明并不像它们应该的那样清楚。
所以任何指导都表示赞赏
非常感谢
以上来自于谷歌翻译
以下为原文
Hi
As title really.
I have a Linux VM with 7.13 VDA installed. Does anyone know how to enable H.264 Encode?
I'll caveat this by stating I'm not a Linux guy, so have more than likely misunderstood something ...
I have an M60 8Q profile assigned so CUDA is available. GRID 4.1 drivers are installed and it's licensed.
I'm following this guide: http://docs.citrix.com/en-us/linux-virtual-delivery-agent/7-13/configuration/configuring-graphics.html
However, when I try and run this on the VDA:
sudo ctxreg create -k "HKLMSystemCurrentControlSetControlCitrixThinwire" -t "REG_DWORD" -v "AdvertiseH264" -d "0x00000001" --force
I get this in response:
sudo: ctxreg: command not found
My initial thoughts were, I'm trying to install a Windows registry key on a Linux VM, of course it won't work. However, as a non-Linux guy, I actually don't know.
Instructions as usual aren't as clear as they should be. So any guidance is appreciated
Many thanks
回帖(2)
刘宇
2018-9-17 14:45:21
得到了朋友的一点帮助......
对于使用Linux的任何其他人,您需要从此处运行命令:/ opt / Citrix / VDA / bin
然后根据上面的链接,运行:
那么这个:
ctxreg create -k“HKLM  System  CurrentControlSet  Control  Citrix  Thinwire”-t“REG_DWORD”-v“HardwareEncoding”-d“0x00000001”--force
启用它,然后检查它:
./ctxreg dump |
grep HardwareEncoding
一切正常。
以上来自于谷歌翻译
以下为原文
Had a little help from a friend ...
For anyone else playing with Linux, you need to run the command from here: /opt/Citrix/VDA/bin
Then as per the link above, run this:
then this:
ctxreg create -k "HKLMSystemCurrentControlSetControlCitrixThinwire" -t "REG_DWORD" -v "HardwareEncoding" -d "0x00000001" --force
to enable it, and then this to check it:
./ctxreg dump | grep HardwareEncoding
All working now.
举报
彭菲
2018-9-17 14:54:21
感谢您的信息。
以上来自于谷歌翻译
以下为原文
Thank you for the information.
举报
更多回帖
