我有疑问
如果有可能从近场模拟获得辐射模式(如在远场模拟中)(我试图模拟这么多次并且在模拟完成之前花了很长时间)并且我不确定我是否能够获得
数据形式的数据,例如辐射强度在特定区域(例如距离天线3毫米)的数量,而不是3D形式。
另外,如果我必须使用其他传感器(在FEM中),我应该使用哪一个?
还有一个问题,我如何从模拟中导出结果。
谢谢。编辑:2016年2月16日下午7:41成为RF工程师
以上来自于谷歌翻译
以下为原文
I have questions. If it possible to get the radiation pattern (like in the far field simulation) from near-field simulation (I tried to simulate so many times and it took so long before the simulation is done) and I'm not sure if I can get the data such as how much the radiation intensity is in the specific area (like 3 millimeters from antenna) in the numerical form, not in the 3D form. In addition, if I have to use others sensors (in FEM), which one I should use?
One more question, how can I export the result from simulation.
Thank you.
Edited by: To be RF engineer on Feb 16, 2016 7:41 PM
我有疑问
还有一个问题,我如何从模拟中导出结果。
以上来自于谷歌翻译
以下为原文
Thank you.
举报
