TI论坛
直播中
潘福乔
7年用户 195经验值
私信 关注
[问答]
CCS6.0仿真器连接不上SM320F28335
C28xx: Error connecting to the target: (Error -233 @ 0x0) The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 5.1.450.0)
回帖(10)
周静
2018-9-17 15:08:21
您好,论坛中有同样的帖子请参考:http://www.deyisupport.com/question_answer/microcontrollers/c2000/f/56/t/70865.aspx
举报
潘福乔
2018-9-17 15:21:04
我这个一直都连接不上呀
举报
潘福乔
2018-9-17 15:29:57
引用: xiaoxian26 发表于 2018-9-17 18:24
我这个一直都连接不上呀
C28xx: Error connecting to the target: (Error -501 @ 0x0) The built-in scan-path length measurement failed. The built-in scan-path reliability tests cannot be performed without knowledge of the scan-path length. Try specifying the scan-path lengths in the command-line options or board configuration file of this utility or debugger. (Emulation package 5.1.450.0)
举报
周静
2018-9-17 15:47:39
引用: xiaoxian26 发表于 2018-9-17 18:33
C28xx: Error connecting to the target: (Error -501 @ 0x0) The built-in scan-path length measurement failed. The built-in scan-path reliability tests cannot be performed without knowledge of the scan-path length. Try specifying the scan-path lengths in the command-line options or board configuration  ...
target configerion的配置对吗?
还有排查下电源,焊接是否有问题?
举报
更多回帖
