工程资源中心
直播中
张珍岚
8年用户 132经验值
私信 关注
[接口]
具有PMBus接口和RCC纹波电流注入功能的POL设计包括BOM及层图
            PMP4499 is a reference design that uses the TPS544C20 to generate low-voltage point-of-load (POL) outputs up to 30 A. The design is sync-buck topology with integrated FETs to provide high efficiency. The controller also offers PMBus commands for telemetry and monitoring. The design is  (...)
主要特色
  • 8.3-V to 14.4-V input, 1-V 30-A output with high-integration and high-efficiency solution
  • Online adjustment output voltage margin and trim to provide wide and precise output voltage
  • PMBus provides for converter configuration, as well as monitoring of key parameters
  • Robust solution with optimized PCB  (...)
更多回帖
