工程资源中心
直播中
苏旭
8年用户 174经验值
私信 关注
[电源设计]
基于LM5122控制器的同步双相升压电源包括BOM及层图
PMP7979 is a synchronous dual-phase boost power supply using the LM5122 controllers. The design accepts an input voltage of 12 V to 67 V, and boosts a 54-V output rail that is capable of sourcing 4.8-A continuous current. The LM5122 has an internal current source to keep the high-side FET to run at  (...)
主要特色
  • 12 Vin to 67 Vin, 54 Vout at 5-A out; IC capable of 4.5 Vin to 65 Vin
  • 260-W Pout
  • Peak efficiency at 98%
  • Switching frequency 100 kHz per phase (200 kHz)
  • Board size: 4 in x 3 in
更多回帖
