大部分信息都在
http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/b2/1e/33/77/c6/92/47/6b/DM00279086/files/DM00279086.pdf/jcr:内容/翻译/ en.DM00279086.pdf
:来自垂直激光器的红外脉冲的爆发以锥形立体角发射。
如果存在物体,则反射光束将被雪崩照片diod感测到。
通过测量从发射到接收光脉冲所花费的时间来计算距离。
每皮秒0.299792毫米==> 1mm对应于~3 ps时间粒度实现
以上来自于谷歌翻译
以下为原文
Most of the information is in the
http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/b2/1e/33/77/c6/92/47/6b/DM00279086/files/DM00279086.pdf/jcr:content/translations/en.DM00279086.pdf
:Burst of infrared pulses from vertical laser is emitted in a cone shaped solid angle.
If there is an object, the reflected light beam will be sensed by the avalanche photo diod.
The distance is calculated by mesuring the time it took from emission to reception of a light pulse.
0.299792 mm per picosecond ==> 1mm correspond to ~3 ps time granularity implementation
大部分信息都在
以上来自于谷歌翻译
以下为原文
举报
