是德科技
直播中
冉屹芳
8年用户 144经验值
私信 关注
[问答]
5227A上的未知校准有什么限制
所有,我正在尝试使用SMA连接器在PNA N5227A上进行未知的校准。
我想知道这个校准有什么限制。
我有一个未知的通过,没有那么好的匹配(谢谢你,
以上来自于谷歌翻译
     以下为原文
  All,
I am attempting an unknown thru calibration on a PNA N5227A with SMA connectors.  I am wondering what the limitations are on this calibration. I have a unknown thru that has not-so good match (<- 10dB) from 10 MHz to 16 GHz. My loss is about 23 dB at 16 GHz. Whenever i do the calibration, i get an unrealistic post-calibration measurement (i.e. S11 < -30 dB) and S21 essentially open (-40dB) across this particular frequency range. I am wondering if i have to use a better matched thru and/or less lossy thru. The documentation stipulates that as long as you dont have 40 dB loss including the cables this method should work. I am dumbfounded as to what could be going on. I can post some of the plots if this helps answer the question.
thank You,
回帖(1)
孔德羲
2018-9-12 16:00:54
什么FW?
您使用什么Calkit?
你正在使用什么UT(过滤器,垫?)。
如果UT辐射也可能是一个麻烦。
所有频率的问题都只是一个子集吗?
以上来自于谷歌翻译
     以下为原文
  What FW? What Calkit are you using? What is the UT that you are using (filter, pad?) .  If the UT radiates that can be a trouble as well.  Is the trouble at all frequencies are at just a subset?
举报
更多回帖
