是德科技
直播中
任斌
8年用户 177经验值
私信 关注
[问答]
SCPI跟踪N9340B上的数据如何获取x轴数据
嗨,我试图从N9340B转储跟踪数据。
通过编程手册,很容易获得y轴数据,但我不确定如何获取x轴数据,我似乎无法在那里找到任何对它的引用。
具体来说,我想知道以下两个公式中的哪一个是正确的(如果是!)因为我不确定它如何分割箱:N =箱数(整数)Fstart =起始频率Fstop =停止频率F =频率*
bin center * X = bin number(整数)F = X *(Fstop - Fstart)/(N-1)+ Fstart或F =(X + 0.5)*(Fstop - Fstart)/(N-1)+ Fstart Can
有人帮我这个吗?
或者,如果我错过了记录的地方,那么如果你能指出我在哪里就会很棒:)谢谢!编辑:jeremyherbert于2016年1月28日上午6:18;
关闭1错误
以上来自于谷歌翻译
     以下为原文
  Hi,
I am trying to dump the trace data out of an N9340B. Looking through the programming manual, it is easy to get the y axis data, but I am unsure of how to get the x axis data and I can't seem to find any references to it in there. Specifically, I am wondering which of the following two formulae is correct (if either!) as I am not sure how it segments the bins:
N = number of bins (integer)
Fstart = start frequency
Fstop = stop frequency
F = frequency at *bin center*
X = bin number (integer)
F = X * (Fstop - Fstart) / (N-1) + Fstart
or
F = (X + 0.5) * (Fstop - Fstart) / (N-1) + Fstart
Can anyone help me with this? Alternatively, if I have missed where this is documented, it would be great if you could point out to me where it is :)
Thanks!
Edited by: jeremyherbert on Jan 28, 2016 6:18 AM; off by 1 error
回帖(1)
h1654155275.5614
2018-9-12 16:06:02
我让N9340B的人帮忙回答你的问题,但很多人不在办公室。
查看N9912A的编程示例。
也许它会有所帮助?
http://na.support.keysight.com/fieldfox/help/Programming/webhelp/Examples/N9912A_SpecAn_Get_Data_as_ASCII_Output_IMAGE.png有一些FieldFox编程示例可能会对您有所帮助。
虽然我不确定FieldFox和N9340B是否表现相同。
我希望如此,对于一些简单的事情,但我并不是百分百肯定。
http://na.support.keysight.com/fieldfox/help/Programming/webhelp/FFProgrammingHelp.htm Afsi Moaveni编辑:am95405于2016年2月12日下午2:16
以上来自于谷歌翻译
     以下为原文
  I asked the N9340B folks to help answer your question, but many are out of the office.
Check out this programming example for N9912A. Maybe it will help out?
There are a few FieldFox programming examples that perhaps you will find helpful. though I am not sure if FieldFox and N9340B behave the same way. I would hope so, for something simple, but I am not 100% sure.
Afsi Moaveni
Edited by: am95405 on Feb 12, 2016 2:16 PM
举报
更多回帖
