HI,如果周围有RF,确保没有连接到PIC输入的接线,作为天线。编程引脚可以使用4K7欧姆电阻器拉到GND,当拾取3没有连接时,不使用的引脚不应该作为输入浮动。相反,应该配置为输出和驱动低,见数据表。PIC16F82也有一个PGM引脚,确保保持低,连接到GND,或使用电阻GND。/MCLR引脚拉到+5V 2.2K欧姆电阻器似乎不错。迈西尔
以上来自于百度翻译
以下为原文
Hi,
If there is RF around, make sure there are no wiring connected to PIC inputs, acting as antennas .
Programming pins may be pulled to GND using 4k7 ohm resistors, when PICkit 3 is not connected,
Pins that are not used, should Not be left floating as Inputs.
Instead should be configured as Outputs and driven Low, see datasheet.
PIC16F882 also have a PGM pin, make sure to keep it Low, connect to GND, or use a resistor to GND.
/MCLR pin pulled to +5V by 2.2k Ohm resistor seem OK.
Mysil
以上来自于百度翻译
以下为原文
Hi,
Mysil
举报
