你好卢克,
非常感谢您的回复。
我想这是一个BIOS或驱动程序问题(或两者),而不是关于电源。
该系统经过认证,可以承载大约相同功耗的nVidia GPU加速卡(其中4个)并配备4 x 1200瓦电源。
问题是,我必须购买机架式服务器(Proliant DL系列)并且不能购买刀片服务器或SL系列服务器。
一旦安装了网格卡,DL380就无法提供足够的可用PCI插槽。
如果我正确理解图片功能,我首先需要找到一个可以公开上传图片的平台,然后我在img-Tags中发布网址。
即使没有技术解决方案:如果系统认证背后有任何路线图,我也要求考虑4插槽机架式服务器。
非常感谢你。
亲切的问候
安德烈亚斯
以上来自于谷歌翻译
以下为原文
Hello Luke,
Thanks a lot for your response.
I guess it is a BIOS or driver issue (or both) and not regarding to power. The system is certified to host nVidia GPU accelerator cards with about the same power consumption (4 of them) and is equipped with 4 x 1200 Watts power supplies.
The problem is, that I have to buy rack servers (Proliant DL series) and cannot buy blades or SL series server. And the DL380 does not offer enough free PCI slots as soon as the Grid cards are installed.
If I understand the picture function correctly I need first to find a platform where I can publicly upload my image and them I post the URL in img-Tags.
Even if there is no technical solution: If there is any roadmap behind the certification of the systems I kindly ask to also take 4 socket rack servers into account.
Thank you very much.
With kind regards
Andreas
你好卢克,
非常感谢您的回复。
非常感谢你。
亲切的问候
安德烈亚斯
以上来自于谷歌翻译
以下为原文
Hello Luke,
With kind regards
Andreas
举报
