Microchip
直播中
程春华
8年用户 228经验值
私信 关注
[问答]
PIC32MM TQFP 48引脚 中心焊盘(49)
HI,数据表指示设备有中心焊盘,但实际设备没有。是否需要热传递?我问的原因是我所用的脚印不在这个地方垫上防滑面具,而且在挑选和放置的时候可能会有问题。或者我可以完全移除这个垫子……干杯,安得烈。
以上来自于百度翻译
      以下为原文
    Hi,
The datasheet indicates the device has a center pad but the actual device does not. Is it required for thermal transfer? The reason I ask is the footprint I'm using doesn't solder-mask this pad and potentially it could be an issue during pick and place.
Alternatively I could remove the pad altogether...
Cheers, Andrew
   Attached Image(s)
更多回帖
