英伟达
直播中
李婷婷
8年用户 216经验值
私信 关注
[问答]
你可以组建一个Grid K1用于RDS环境吗?
很多人在做VDI,但对我们公司来说,我们已经成功地做了RDS环境多年。
在2012R2和现在的2016年,我们使用的是K4200并且它运行良好,但尝试使用像GPU一样的多GPU ...
网卡是否可以实现这一点?
当我们安装它时,我们可以看到所有4个GPU,但所有负载只有1个GPU。
以上来自于谷歌翻译
以下为原文
So many people doing VDI but for our company we have been successfully doing RDS environment for years. with 2012R2 and now 2016 we were using a K4200 and it was working well but was trying to utilize a multi- GPU much like SLI...
Is this even possible with the Grid Card? when we had it installed we could see all 4 GPUs but all the load went to only 1 GPU.
回帖(1)
王文霞
2018-9-6 10:23:28
裸机不支持多个GPU卡 -  M6(只能使用一个GPU)。
这是我们所知道的要求。
一种选择是为每个GPU虚拟化并拥有4个服务器虚拟机 - 尽管对于RDS服务器,K2将是正常的建议--K1专为办公室工作人员VDI的高密度VDI而设计。
每个GPU的规格低于通常建议共享使用的规格。
对于裸机单GPU卡,例如
像K4200这样的Quadro将是一个有效的选择,尽管如果使用大量用户作为共享资源,我们通常会看到更像K6000甚至M6000的东西。
以上来自于谷歌翻译
以下为原文
Multiple GPU cards are not supported for bare metal - the M6 (which only has one GPU can be used). It is a request we are aware of. One option is to virtualise and have 4 server VMs one for each GPU - although for a RDS server the K2 would be the normal recommendation - the K1 is designed for high-density VDI for office worker VDI. The spec of each GPU is below what it usually recommended for shared use.
For bare-metal a single GPU card e.g. a Quadro such as the K4200 would be a valid choice although we'd often normally see something more like a K6000 or even M6000 if using large numbers of users as again it's shared resource.
举报
更多回帖
