英伟达
直播中
王桂花
8年用户 182经验值
私信 关注
[问答]
Tesla V100-2016 Hyper-V-使用RemoteFX的多个VM
我继承了使用2012 Hyper-V / Fail-over Cluster / Windows VDI构建的系统。
我正在尝试使用Server 2016 Hyper-V(1607)和戴尔R740机箱中的Tesla V100 32GB GPU推出RemoteFX。
许可证门户中的最新网格驱动程序(391.81)安装正常,Hyper-V管理器可以看到该卡并允许它用于RemoteFX。
但是,当我将其添加到VM并尝试启动VM时,我收到错误32788.(“VMName”无法更改状态。操作失败,错误代码为“32788”)。
尝试了新的虚拟机,包括第1代和第2代,以及当前的虚拟机。
如果我在硬件中包含RemoteFX 3D适配器,无论设置如何,VM都会拒绝启动。
它尝试可能1-3分钟,然后在GUI弹出窗口中报告错误32788,它无法启动。
如果我删除虚拟RemoteFX适配器,它会正常启动。
有任何想法吗?
以上来自于谷歌翻译
以下为原文
I've inherited a system that is built using 2012 Hyper-V/Fail-over Cluster/Windows VDIs.
I'm trying to roll out RemoteFX using Server 2016 Hyper-V (1607) and a Tesla V100 32GB GPU in a Dell R740 chassis.
Latest grid driver (391.81) from the license portal installs fine and Hyper-V Manager can see the Card and allow it to be used for RemoteFX.
However, when I add it to a VM and try and start the VM I get an error 32788. ("VMName" failed to change state. The operation failed with error code '32788'). Tried new VMs, both Gen 1 and 2, as well as current VMs.
The VM refuses to start if I include a RemoteFX 3D adapter in the hardware, no matter what the settings. It tries for maybe 1-3 minutes, then reports error 32788 in a GUI popup, that it couldn't start. If I remove the virtual RemoteFX adapter it starts fine.
Any ideas?
回帖(1)
赵爱香
2018-9-6 10:19:04
为了防止其他人遇到类似问题,我将其缩小为继承系统上的GPO。
一旦我确定了导致它的设置,我就会回复。
以上来自于谷歌翻译
以下为原文
Just in case anyone else has a similar issue, I've narrowed it down to a GPO on the inherited system.
As soon as I pin down the setting that's causing it, I'll respond back.
举报
更多回帖
