This is already done but I need the data in memory to be able to display and
work on.
The problem is that the Concanator eats up memory.
-----Oprindelig meddelelse-----
Fra: Christian Wienhold [mailto:christian.wienhold@biotronik.de]
Sendt: 20. november 2002 07:52
Til: Ren Srensen
Emne: Re: [vrf] Memory leak ??
Save your data sequential to file without checked 'Clear File at Prerun and
Open'. After last write cycle send Execute Close. This keeps used memory
at a minimum and saves your data in case of a system crash up to that
time.
You are currently subscribed to vrf as: r***@soco.agilent.com
To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email "vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
