是德科技
直播中
李秀云
8年用户 815经验值
私信 关注
[问答]
vrf从格式化文件中获取字段
迈克,谢谢你的回答...这真的是我想要的。保罗,保罗-----原始信息-----来自:M Watts To:Paul Cc:VEE Reflector(E-mail)发送:星期三,
2002年7月17日4:26 AMSubject:vrf从格式化的文件保护中获取字段,您只需要使用“读取令牌”功能 - 对于此类问题,它是一个非常强大的解决方案。
请参阅随附的示例.Regards,Mike Watts_______________________________________________________________________ Michael Watts,顾问PO Box 92网站:www.PreciselySo.Co.UK埃克塞特,德文电子邮件:MJWC@PreciselySo.Co.UK英格兰电话:+44 7714 339 729 EX4
2YY _______________________________________________________________________-------------------------------------------------
--------------------这是由Majordomo管理的“vrf”maillist。
要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。
订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.---
以上来自于谷歌翻译
     以下为原文
  Mike,
Thanks for your answer... it really what I want.
Regards,
Paul
----- Original Message -----
To: Paul
Cc: VEE Reflector (E-mail)
Sent: Wednesday, July 17, 2002 4:26 AM
Subject: vrf Get field from formatted file
Paul,
     You just need to use the 'read token' feature - it's a very elegant
solution for this type of problem.  See the attached example.
Regards,
Mike Watts
  Michael Watts, Consultant                                 PO Box 92
  on the web: www.PreciselySo.Co.UK                      Exeter,Devon
  e-mail: MJWC@PreciselySo.Co.UK                              England
  tel: +44 7714 339 729                                       EX4 2YY
This is the "vrf" maillist, managed by Majordomo.  To send messages to
this maillist, just email to "vrf@lvld.agilent.com".  Subscriptions and
unsubscriptions are done through the address "vrf-request@lvld.agilent.com".
If you need details, just send a message containing the text "help"
to "vrf-request@lvld.agilent.com".
回帖(3)
李秀云
2018-9-6 10:15:02
以上来自于谷歌翻译
     以下为原文
举报
李秀云
2018-9-6 10:21:06
I made a burn in program which controlled 6 serial ports in sequence. I made
one com port box and added a device name (if memory serves correctly) input
pin and cycled through the port names using a for range box and a formula
box to drive the serial port object.
I don't think VEE has any limit on the number of ports.
Mark
-----Original Message-----
Sent: Wednesday, July 17, 2002 7:05 AM
To: vrf
Subject: vrf talk to 10 serial ports
Hi,
Does anyone know how to connect more than 4 serial ports in VEE. I have 10
ports (com1 to com10) but VEE only supports 4. Thank you.
Tim Xing
Dept. of Engineering
Labconco
8811 Prospect Ave.
Kansas City, MO. 64132
(816) 822-3759
举报
李秀云
2018-9-6 10:40:55
以上来自于谷歌翻译
     以下为原文
举报
更多回帖
