Microchip
直播中
符敛招
8年用户 165经验值
私信 关注
[问答]
mplab-x WATCH窗口不显示全局变量列表
最近返回到一个旧的项目来添加一些新的特性,我注意到当观察窗口在调用“添加新表”到监视列表之后出现时,窗口不会在全局符号单选按钮下显示任何变量。SFR的列表如预期的那样出现,但我不知道为什么没有“全局符号”列表来选择。我正在使用MPLAB-X的V4.20,这个项目确实生成了一个.map文件,列出了数据存储器中的符号及其地址。我使用的符号列表是用CBORD指令定义的,将变量放在0x000内存中的访问库中。处理器是PIC18F420。谢谢,
以上来自于百度翻译
      以下为原文
    having returned recently to an older project to add some new features, I notice that when  the watch window appears after invoking' add New watch' to the watch list, the window does not display any variables under the global symbols radio button. The list of SFR's appears as expected, but i am at a loss as to why there is no list of 'global symbols to select from. i am using V4.20 of Mplab-x and the project does generate a .map file which lists the gloabl symbols and their addresses in data memory.
Any suggestions would be appreciated. The list  of symbols I am using is defined using the cblock directive to place the variables in the access bank of memory starting at 0x0000. the processor is a PIC18F4520.
Thank you,
回帖(4)
吴键洪
2018-9-6 16:42:05
您需要编辑项目属性,以说明您的汇编器源使用的是“绝对模式”,而不是默认的“可重新定位模式”。
以上来自于百度翻译
      以下为原文
    You need to edit the project properties to say your assembler source is using "Absolute mode" rather than the default "Relocatable mode".
举报
余少华
2018-9-6 16:56:27
谢谢你的回复,我不能理解这个问题,因为我确信它以前就醒了。-我想我上一届会议上的项目一定发生了神秘的变化。
以上来自于百度翻译
      以下为原文
    Thank you for the reply qub, I could not understand the problem since I'm sure it woke fine previously. - I guess the project proprties must have mysteriously changed since my previous session.
举报
余少华
2018-9-6 17:09:58
已经尝试过按Qub提出的绝对模式下的项目,但同样的问题也存在。有人帮忙吗?
以上来自于百度翻译
      以下为原文
    Have tried building the project in Absolute mode as suggested by qub but the same problem is present.
Anyone help?
举报
李维兴
2018-9-6 17:27:19
第14版的HTTPS://www. McCHIP.COM/FUMMS/FUNDSPE/1002553
以上来自于百度翻译
      以下为原文
    Post #14 of https://www.microchip.com/forums/FindPost/1002753
举报
更多回帖
