保罗,我点击了你发送的链接,但我只看到开发者的初始帖子。我看不到你(或其他人)对那个帖子的反应(?)在回答您的问题:我尝试使用一个新的项目,既有自定义板和几个目标BSP的和谐。我也尝试打开现有项目Inc: Microchip HyrnV2Y06AppsExcel。每一次尝试都以与前面描述的相同的失败结束。我可能读T。在发布之前非常相似的问题;所有的似乎都是通过卸载/重新安装和声和/或MHC来修复的。我已经做了好几次都没用。根据我的最大努力,我的系统被配置为和谐的V2.06发行说明在这个时间点建议。但奇怪的是,失败和以前的帖子很相似,我似乎在经历这个问题。顺便说一下,我的IDE并没有简单列出失败的原因…IDE总是锁起来……这是我以前没有看到其他人提到过的东西。谢谢你的帮助,杰夫。
以上来自于百度翻译
以下为原文
Paul,
I clicked on the link to the post you sent but I only see the developer's initial posting. I do not see your (or anyone else's) response to that post (?).
In response to your questions:
I attempted using Harmony in a fresh project with both a custom board and several of the target bsps.
I also attempted opening existing projects in C:microchipharmonyv2_06appsexamples.
Every attempt ends with the same failure as I described earlier.
I probably read twenty posts on very similar issues before posting; all seemed to be fixed by uninstalling/reinstalling harmony and/or MHC. I have done this several times to no avail.
Per my best efforts, my system is configured exactly as the Harmony v2.06 release notes suggest at this point in time.. but it is odd that the failure is very similar to previous posts who appeared to get past this issue I am having.
BTW, my IDE does not simply list the failures...the IDE *always* locks up...which is something I haven't seen anyone else mention in earlier posts.
Thanks for you help,
Jeff
以上来自于百度翻译
以下为原文
Paul,
Jeff
举报
