谢谢你确认杰森。
@Rachel,
至于我们的崩溃(或冻结),这里是完整的堆栈:
3 x Dell R730服务器,1 x M60(完成gpumode-switch并设置为图形模式)
VMware ESXi 6.0(3825889)>最近发布了一些补丁,并将尝试使用最新补丁和修复程序升级所有主机(4192238)
Windows 10企业版(已安装1511和完全修补)
带有HDX3dPro的XenDesktop 7.9 VDA
*当冻结发生时,它不是实际的Windows机器,而只是图形会话..它只是冻结会话。
我然后尝试断开并再次连接,只是得到一个灰色的屏幕。
我然后尝试RDP但它仍然连接....我仍然可以ping机器并访问远程事件查看器和服务控制台..我们唯一的选择是从VMware控制台/ Studio重启机器。
*当使用较小的配置文件(),0b)时,显示冻结发生..我计划给所有用户
*无法使用较大的配置文件重现问题
*从Windows PC Receiver和10zig零客户端连接时出现问题
*在测试时出于某种原因,使用时比使用0b更容易复制
*在Windows中正常工作时会发生此冻结,例如使用普通浏览器或办公应用程序
*当我们使用passmark的工具进行性能测试时,我首先遇到了这个问题,它在DX11的3D测试期间冻结了......该工具很快就能够重现这个问题。
*如果没有安装Citrix VDA,我们无法重现相同的问题。
因此,在没有安装VDA的情况下,标记工具会在完全相同的机器上完成。
使用Citrix和NVidia打开案例[事件:160727-000032],但进展非常缓慢。
约翰
以上来自于谷歌翻译
以下为原文
Thanks for confirming that Jason.
@Rachel,
As for our crashes (or freeze), here is the full stack:
3 x Dell R730 server with 1 x M60 (gpumode-switch done and set to graphics mode)
VMware ESXi 6.0 (3825889) > there were a few patches released very recently and will attempt to upgrade all hosts tonight with latest patches and fixes (4192238)
Windows 10 Enterprise (installed 1511 & fully patched)
XenDesktop 7.9 VDA with HDX3dPro
*when the freeze happens, its not the actual Windows machine, but the graphics session only.. it just freezes the session. i then try to disconnect and connect again and just get a grey screen. I then try RDP but it remains connecting....i can still ping the machine and access remote event viewer and services console.. Our only option is the reboot the machine from VMware console / Studio.
*the display freeze happens when using the smaller profiles (0q, 0b).. which I plan to give to all my users
*haven't manage to reproduce to the issue with the larger profiles
*issue occurs when connecting from Windows PC Receiver and also from a 10zig zero client
*it was easier to reproduce when using the 0q than 0b for some reason when testing
*this freeze occurs when working normally in windows, like using normal browsers or office applications
*i first came across the issue when we did a performance test using passmark's tool and it froze during the 3D tests for DX11.... that tool reproduces the issue quite quickly.
*we have not managed to reproduce the same issue without the Citrix VDA installed. so the passmark tool goes through all the way on the exact same machine without VDA installed.
Opened cases with Citrix and NVidia [Incident: 160727-000032] but the progress is going quite slow.
John
谢谢你确认杰森。
@Rachel,
*无法使用较大的配置文件重现问题
约翰
以上来自于谷歌翻译
以下为原文
@Rachel,
John
举报
