英伟达
直播中
吕品
8年用户 154经验值
私信 关注
[问答]
PvS或MCS
嗨,
我刚刚开始研究vGPU的XenDesktop配置。
是否优先选择桌面编排工具?
我在某地读过PvS不受支持,但那可能是旧版本。
如果支持,PvS将是首选,因此可以使用私有磁盘。
缓存到RAM也有溢出。
在配置任务期间是否有任何考虑因素?
假设您让PvS从已经传递vGPU的模板创建新桌面,并在启动之前通过XenCenter将vGPU分配给新创建的VM。
或者是否需要额外的步骤来确保vGPU是完整的
谢谢
以上来自于谷歌翻译
以下为原文
Hi,
I'm just starting to look at an XenDesktop configuration for vGPU. Is there a preference for the desktop orchestration tool? I read somewhere that PvS wasn't supported, but that was probably for an older version.
If supported, PvS would be much preferred so Private Disks can be used. Cache to RAM with overflow as well.
Are there any considerations during the provisioning tasks? Presumably you let PvS create new desktops from a template that had a vGPU passed through to it, and assign the vGPUs to the newly created VMs via XenCenter before powering them up. Or are there additional steps required to ensure the vGPU is ful
Thanks
回帖(1)
qwe041
2018-9-5 09:55:30
应该以任何方式工作 - 它与配置机制无关。
GPU passthrough或vGPU分配都是可能的。
我们使用MCS是因为它(1)更容易,(2)更便宜(不需要额外的配置服务器),(3)我们已经使用精简配置和缓存存储服务器,因此已经获得了很好的I / O性能。
附:
是的,通过溢出到磁盘缓存到RAM会很好,最终可能会来到MCS。
以上来自于谷歌翻译
以下为原文
Should work either way -- it has nothing to do with the provisioning mechanism. Either GPU passthrough or vGPU assignments are possible. We use MCS because it's (1) easier, (2) cheaper (no extra provisioning server(s) needed), (3) we use thin provisioning already with a caching storage server, so already get great I/O performance.
P.S. Yes, cache to RAM with overflow to disk would be nice, and will probably come to MCS eventually.
举报
更多回帖
