通常是这样做的……你必须在TIC上完成“TX完成”的标志:一个告诉你字节已经移动到TX'Enter寄存器,一个告诉它已经完成了传输-所以你通常使用这个。然后我添加一些时间延迟…确保线路稳定。这有点TBD,但工作!
以上来自于百度翻译
以下为原文
Usually this is how it's done...
You have to "TX done" flags, usually, on PICs: one tells you that the byte has been moved to TX'ing shift register, and one tells that it is done transmitting - so you usually use this one.
Then I add some bit-time delay... to make sure line is stable. This is somewhat TBD, but works!
以上来自于百度翻译
以下为原文
举报
