Cypress技术论坛
直播中
张杰
8年用户 255经验值
私信 关注
[问答]
CX3 RAW8数据流
你好,
我想得到一个功能相机连接使用ov2740柏CX3。
在raw8 @ 1080P 30FPS的ov2740只输出。
所以我调整了描述如下:
GUID到Y800
每像素位数:8
变比特率1920x1080x30x8
改变数据格式cy_u3p_csi_df_raw8
在cx3rdkov5640我改变以下线的applinit():
状态= cyu3pmipicsigpifload(cy_u3p_mipicsi_bus_8,es_uvc_data_buf_size);
然而,当我试图流使用Amcap我收到以下错误:
以上来自于百度翻译
     以下为原文
  Hi,
I am trying to get a functional camera link using an OV2740 and Cypress CX3.
The OV2740 only outputs in RAW8 @ 1080p 30fps.
Therefore i have adjusted the descriptors as following:
-GUID to 'Y800'
-Number of bits per pixel:8
-Changed bit rate to 1920x1080x30x8
-Changed data format to CY_U3P_CSI_DF_RAW8
In the CX3RDKOV5640 i changed the following line in the ApplInit():
-status = CyU3PMipicsiGpifLoad(CY_U3P_MIPICSI_BUS_8, ES_UVC_DATA_BUF_SIZE);
However when I try to stream using AmCap i get the following error:
回帖(17)
张杰
2018-9-3 15:17:30
的HSYNC和VSYNC(G6)(H5)线的电压稳定在提到。
应积极和消隐期间这些线路可以吗?
根据相机的计时表,下面的时钟是用于MIPI线:
- MiPIILCK:720MbPs
- MIPIIL PCLK:90MHz
以上来自于百度翻译
     以下为原文
  The HSYNC(G6) and VSYNC(H5) lines are stable at the voltage mentioned.
Should the Active and blanking periods be viewable on those lines?
According to the timing sheet from the camera, the following clocks are used on the MIPI line:
-MIPI_CLK: 720Mbps
-MIPI_PCLK: 90MHz
举报
张杰
2018-9-3 15:35:50
应积极和消隐期间这些线路可以吗?
你好,
对不起,我正在测试错误的测试引脚。
现在,我在测量时得到了清晰的信号。
PCLK为80MHz。
垂直同步是在正确的帧速率(30fps)活动期:32.92ms消隐期:680us
在HSYNC,后11常规脉冲20us分开,较大的脉冲显示。
程序结束的bug结束
错误之前的最后一个规则,第一个错误后的规则
Vsync合计
VSunc消隐
HSYNC规则脉冲
同步脉冲宽度
同步脉冲宽度
以上来自于百度翻译
     以下为原文
  Hi,
Sorry, I was measuring at the wrong testpins.
Right now, I got a clear signal when measuring.
The PCLK is at 80MHz.
The Vsync is at the correct frame rate (30fps) active period: 32.92ms blanking period: 680us
In the Hsync line, after 11 regular pulses at 20us apart, a larger pulse shows up.
end of bug to start of regular
last regular before bug, first regular after bug
Vsync total
Vsync blanking
Hsync regular pulses
Hsync regular pulse width
Hsync bug pulse width
举报
张杰
2018-9-3 15:55:22
引用: 60user167 发表于 2018-9-3 13:00
你好,
对不起,我正在测试错误的测试引脚。
现在,我在测量时得到了清晰的信号。
这是一个图片的当前图像出来的传感器,它是显示相同图像的3次转移到屏幕上,可能是由于不匹配的行吗?
以上来自于百度翻译
     以下为原文
  This is a picture of the current image coming out of the sensor, it is showing the same image 3 times shifted over the screen, probably due to a mismatch of the hsync?
举报
张杰
2018-9-3 16:05:55
可以支持建立一个视频通话吗?
因为我们很快就接近最后期限了,进度就是
目前速度太慢,最后期限。
亲切的问候,
莱恩贝恩斯
以上来自于百度翻译
     以下为原文
  Would it be possible to set up a videocall for support?
Since we are quite quickly approaching a deadline, and the progress is
currently too slow to meet the deadline.
Kind regards,
Rens Baeyens
举报
更多回帖
