恩,谢谢你的回复!
评估板上的屏幕是自带的,官网刚好也有对应的例程。出现这样的错误我想也是驱动文件没配置好。WM_SetCreateFlags(WM_CF_MEMDEV);这条指令加和不加效果是一样的,也就是可能是LCDConf_stm32373c_eval.c和GUIConf_stm32373c_eval.c这两个文件官方没有配置好。
/* 这是LCDConf_stm32373c_eval.c */
#include "GUI.h"
#include "GUIDRV_FlexColor.h"
#include "global_includes.h"
// Physical display size
#define XSIZE_PHYS 240
#define YSIZE_PHYS 320
* Configuration checking
#ifndef VXSIZE_PHYS
#define VXSIZE_PHYS XSIZE_PHYS
#endif
#ifndef VYSIZE_PHYS
#define VYSIZE_PHYS YSIZE_PHYS
#endif
#ifndef XSIZE_PHYS
#error Physical X size of display is not defined!
#endif
#ifndef YSIZE_PHYS
#error Physical Y size of display is not defined!
#endif
#ifndef GUICC_565
#error Color conversion not defined!
#endif
#ifndef GUIDRV_FLEXCOLOR
#error No display driver defined!
#endif
* Defines, sfrs 这个也不清楚为什么这样配置
#define START_BYTE 0x70
#define SET_INDEX 0x00
#define READ_STATUS 0x01
#define LCD_WRITE_REG 0x02
#define LCD_READ_REG 0x03
* Local functions
* LcdWriteReg
* Function description:
* Sets display register
static void LcdWriteReg(U16 Data) {
LCD_CtrlLinesWrite(LCD_NCS_GPIO_PORT, LCD_NCS_PIN, Bit_SET);
LCD_WriteRegIndex (Data);
LCD_nCS_StartByte(START_BYTE | LCD_WRITE_REG);
* LcdWriteData
* Writes a value to a display register
static void LcdWriteData(U16 Data) {
LCD_WriteRAM(Data);
* LcdWriteDataMultiple
* Writes multiple values to a display register.
static void LcdWriteDataMultiple(U16 * pData, int NumItems) {
while (NumItems--) {
LCD_WriteRAM (*pData++);
* LcdReadDataMultiple
* Reads multiple values from a display register.
static void LcdReadDataMultiple(U16 * pData, int NumItems) {
*pData++ = LCD_ReadReg(R34);
* Public functions
* LCD_X_Config
* Called during the initialization process in order to set up the
* display driver configuration.
void LCD_X_Config(void) {
GUI_DEVICE * pDevice;
CONFIG_FLEXCOLOR Config = {0};
GUI_PORT_API PortAPI = {0};
// Set display driver and color conversion
pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_565, 0, 0);
// Display driver configuration, required for Lin-driver
LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
// Orientation
Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
GUIDRV_FlexColor_Config(pDevice, &Config);
// Set controller and operation mode
PortAPI.pfWrite16_A0 = LcdWriteReg;
PortAPI.pfWrite16_A1 = LcdWriteData;
PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
PortAPI.pfReadM16_A1 = LcdReadDataMultiple;
GUIDRV_FlexColor_SetFunc(pDevice, &ortAPI, GUIDRV_FLEXCOLOR_F66708, GUIDRV_FLEXCOLOR_M16C0B16);
* LCD_X_DisplayDriver
* This function is called by the display driver for several purposes.
* To support the according task the routine needs to be adapted to
* the display controller. Please note that the commands marked with
* 'optional' are not cogently required and should only be adapted if
* the display controller supports these features.
* Parameter:
* LayerIndex - Index of layer to be configured
* Cmd - Please refer to the details in the switch statement below
* pData - Pointer to a LCD_X_DATA structure
* Return Value:
* < -1 - Error
* -1 - Command not handled
* 0 - Ok
int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData) {
int r;
(void) LayerIndex;
(void) pData;
switch (Cmd) {
case LCD_X_INITCONTROLLER: {
STM32373C_LCD_Init();
return 0;
default:
r = -1;
return r;
这里是不是哪里还要改呢,“这原本是官网的”,运行GUI_init()后屏幕左边有一条窄的雪花状的矩形,右边是宽的黑屏。
恩,谢谢你的回复!
#include "GUI.h"
#ifndef VXSIZE_PHYS
#endif
#ifndef VYSIZE_PHYS
#endif
#ifndef XSIZE_PHYS
#endif
#ifndef YSIZE_PHYS
#endif
#ifndef GUICC_565
#endif
#endif
* Local functions
* LcdWriteReg
* LcdWriteData
LCD_WriteRAM(Data);
* Public functions
* LCD_X_Config
// Orientation
* Parameter:
* Return Value:
* < -1 - Error
* 0 - Ok
int r;
(void) LayerIndex;
(void) pData;
switch (Cmd) {
return 0;
default:
r = -1;
return r;
举报
