“他们肯定是在项目的设计阶段被画出来的。”不可能。和声本来是一组代码生成器结合在一起的以前的注释。(代码生成器现在看来是个大问题),基本的概念并不总是由Harmony Team所遵循。此外,概念随着时间的推移而发展。团队成员显然拥有不同数量的技能。文档是多年来的一个问题。与代码本身的某些部分一样,似乎没有任何驱动器可以返回并修复旧的问题。(我猜一个新的图形库的乐趣,或者把它移植到ARM上更受欢迎)。这是我个人的观点,作为一个外部的观察者,并且可能不符合现实。Mann先生会更加了解公司的实际情况。注:1。和谐是有效的。陡峭的学习曲线会抵消“快速设计”方面的影响,你会看到。2。我觉得通过使用RTOS可以帮助很多应用程序。3。您不需要使用和谐外围驱动程序(UART,I2C,SPI,ECT),那么往往是复杂的和难以使用的。(在我看来,基于V1.xx)PIC32 MX AppNOTES和一些PIC24是可用的,外设是16位。4。如果你对计时器服务有问题,很可能不是你。5。问问题
以上来自于百度翻译
以下为原文
"surely they must have been drawn during the Design Phase of the project."
No unlikely. Harmony was originally a collection of Previous Appnotes brought together with a code generator. (code generator appear to be the big thing now) The Stated basics concepts were not always followed by the Harmony Team. Additionally, The concepts evolved over time. The Team member apparently had a varying amount of Skill.
the Documentation has been an issue going back years. Like parts of the code itself, there does not appear to be any drive to go back and fix old problems. ( My Guess the Fun a new Graphic library or of porting it to ARM was more favored).
This is MY personal opinion as an outside viewer, and may not match reality.
Mr Mann would be more aware of corporate realities.
Notes:
1. Harmony does Work. Does the steep learning curve offset the " Rapid Design" aspects, You will see.
2. I feel many apps would be aided by using a RTOS.
3. You do not need to use the Harmony Peripheral drivers (UART,I2C,SPI,ect) Then tend to be complex and hard to use. (In my opinion, and based on V1.XX) The PIC32MX appnotes and some PIC24 are usable the Peripherals are 16 bit.
4. If you are having Issues with the Timer Service, it is probably, not you.
5. Ask Questions
以上来自于百度翻译
以下为原文
Notes:
5. Ask Questions
举报
