Microchip
直播中
曾艳
7年用户 257经验值
私信 关注
[问答]
在PIC18F4550有保留记忆吗
嗨,在PIC18F45 50中有保留记忆吗?我想在电源关闭后保持一段时间,谢谢,RegardsSunil。
以上来自于百度翻译
        以下为原文
        Hi,
Is there any retention memory in the PIC18F4550? I want to hold the value after power turned off and on for awhile.
Thanks and Regards
Sunil
回帖(2)
陈晨
2018-8-24 16:17:33
是的,它有EEPROM。可写闪存。
以上来自于百度翻译
        以下为原文
        Yes, it has EEPROM. And writable flash.
举报
罗茵
2018-8-24 16:27:02
我只使用这个内存的问题是有写操作的有限周期。我正在开发一个计数器应用程序,我需要将计数器值存储在保留内存中,这样在断电到ON后,计数器值不会改变。计数器值在一天中变化数千次,我听说,在闪存中写入时,它从不立即在闪存中写入,而是存储在一些缓冲器中,然后在某个周期之后,在闪存中写入。你能帮我看看Flash中的写作顺序吗?谢谢
以上来自于百度翻译
        以下为原文
        I have only problem with using this memory is there is the limited cycle of write operation. I am developing a counter application where I need to store the counter value in the retention memory so that after power OFF to ON, the counter value doesn't change. And counter value changes thousand times in a day.
I heard, while writing in the flash memory, it never immediately write in the flash memory but it store in some buffer and then after some cycle, it write in the flash. Can you help me with the writing sequence in the flash?
Thanks
举报
更多回帖
