编译了NV_RESTORE之后,节点断电后会保存之前的网络信息
若是您想加入B协调器,则需要清除NV保存的网络信息。根据官网的说明
"If the application would like to force a "new" join, the application should set the ZCD_STARTOPT_DEFAULT_NETWORK_STATE bit in the ZCD_NV_STARTUP_OPTION NV item before calling this function. "New" join means to not restore the network state of the device. Use zgWriteStartupOptions() to set these options
[zgWriteStartupOptions(ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_NETWORK_STATE);]
举报
