TI论坛
直播中
郑涵
7年用户 237经验值
私信 关注
[问答]
请问cc2630/cc2650 Zigbee芯片的I2S如何调用
各位亲好。
我最近在用cc2630/cc2650 芯片做一个音频相关的项目。
我查看了数据手册,cc2630/cc2650带有I2S接口。
但是我不清楚这两款芯片的I2S该如何使用。
我上ti官网查了这两个芯片的资料,没有找到这两个芯片有关I2S如何使用的文档,官方给出的示例工程中也没有关于I2S的工程。
请问,这两款芯片的I2S该如何使用?
或者能否给出这两款芯片如何使用I2S的文档或者I2S的示例工程。
感谢您的回复!
回帖(1)
凌云志
2018-8-18 06:39:40
可以参考蓝牙协议栈里的相关I2S例子
比如:
C:tisimplelinkble_sdk_2_02_01_18examplescc2650stksensortag_audioiar
或者
C:tisimplelinkble_sdk_2_02_01_18examplescc2650rchid_adv_remote_privacyiar
可以从里面的PDMCC26XX.C里借鉴
* Copyright (c) 2015-2016, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* INCLUDES
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
* CONSTANTS
const int32_t PDMCC26XX_aBqCoeffs[] = [
//--v-- Adjust overall gain by changing this coefficient
331, 0, -1024, -1356, 342, // DC-notch, halfband LP filter (@32 kHz)
200, 789, 934, -994, 508,
538, 381, 944, -519, 722,
732, 124, 987, -386, 886,
763, 11, 1014, -386, 886,
0, // Terminate first filter
// Insert optional second filter here (@16 kHz). Some examples:
//1147,-1516, 522, -1699, 708, // +5dB peak filter (F0=500 Hz, BW=3 octaves)
//1313, -565, -6, -725, 281, // +5dB peak filter (F0=2.5 kHz, BW=2 octaves)
//1335, 532, -66, 694, 225, // +5 dB peak filter (F0=5.5 kHz, BW=1 octave)
0, // Terminate second filter
const uint16_t PDMCC26XX_gainTable[PDMCC26XX_GAIN_END] = [
1318, //PDMCC26XX_GAIN_24,
660, //PDMCC26XX_GAIN_18,
331, //PDMCC26XX_GAIN_12, // Default
166, //PDMCC26XX_GAIN_6,
83, //PDMCC26XX_GAIN_0,
// 42, //PDMCC26XX_GAIN_N6,
// 21, //PDMCC26XX_GAIN_N12,
// 7, //PDMCC26XX_GAIN_N22,
// 2, //PDMCC26XX_GAIN_N32
* MACROS
#define MIN(a,b) ((a) < (b) ? a : b)
#define MAX(a,b) ((a) > (b) ? a : b)
* TYPEDEFS
/*! Struct that contains a PCM queue element and a pointer to the data buffer it is responsible for */
typedef struct [
Queue_Elem _elem; /*!< Queue element */
PDMCC26XX_pcmBuffer *pBufferPCM; /*!< Pointer to a ::PDMCC26XX_pcmBuffer */
] PDMCC26XX_queuePCM;
* LOCAL VARIABLES
/* PDM Task Configuration */
Task_Struct pdmTask;
Char pdmTaskStack[PDM_TASK_STACK_SIZE];
/* PDM Hwi Configuration */
Hwi_Struct pdmHwi;
Hwi_Params pdmHwiParams;
/* Static allocated memory for PDM data stream
* Used instead of dynamic allocation due to heap fragmentation seen during test.
pdmSample_t pdmContinuousBuffer[PDM_BUFFER_SIZE_IN_BLOCKS * PDM_BLOCK_SIZE_IN_SAMPLES * PDM_NUM_OF_CHANNELS];
uint8_t pdmContMgtBuffer[PDM_BUFFER_SIZE_IN_BLOCKS * I2S_BLOCK_OVERHEAD_IN_BYTES];
/* Keep track of compression variables */
static PDMCC26XX_metaData metaDataForNextFrame = [0];
static int32_t decimationFilterInRAM[sizeof(PDMCC26XX_aBqCoeffs) / sizeof(PDMCC26XX_aBqCoeffs[0])];
static uint32_t decimationState[6+5*2] = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0];
static Queue_Struct pcmMsgReady;
static Queue_Handle pcmMsgReadyQueue;
static Event_Struct sPDMEvents;
static Event_Handle pdmEvents;
static PDMCC26XX_Handle pdmHandle = NULL;
static int byteCount = 0;
static int currTempBufIndex = 0;
static PDMCC26XX_queuePCM *activePcmBuffer;
PDMCC26XX_StreamNotification streamNotification = [
.arg = NULL,
.status = PDMCC26XX_STREAM_IDLE
PDMCC26XX_I2S_StreamNotification pdmStream;
PDMCC26XX_I2S_Handle i2sHandle;
* LOCAL FUNCTIONS
static void PDMCC26XX_taskFxn(UArg a0, UArg a1);
static bool PDMCC26XX_initIO(PDMCC26XX_Handle handle);
static void PDMCC26XX_setPcmBufferReady(PDMCC26XX_Handle handle, PDMCC26XX_queuePCM *pcmBuffer, PDMCC26XX_I2S_BufferRequest *bufReq);
static PDMCC26XX_queuePCM * PDMCC26XX_getNewPcmBuffer(PDMCC26XX_Handle handle);
static void PDMCC26XX_i2sCallbackFxn(PDMCC26XX_I2S_Handle handle, PDMCC26XX_I2S_StreamNotification *notification);
static void PDMCC26XX_rollbackDriverInitialisation(PDMCC26XX_Handle handle, uint32_t rollbackVector);
* EXTERNAL FUNCTIONS
extern bool pdm2pcm16k(const void* pIn, uint32_t* pState, const int32_t* pBqCoeffs, int16_t* pOut);
extern uint8_t tic1_EncodeBuff(uint8_t* dst, int16_t* src, int16_t srcSize, int8_t *si, int16_t *pv);
* PUBLIC FUNCTIONS
void PDMCC26XX_init(PDMCC26XX_Handle handle);
PDMCC26XX_Handle PDMCC26XX_open(PDMCC26XX_Params *params);
void PDMCC26XX_close(PDMCC26XX_Handle handle);
bool PDMCC26XX_startStream(PDMCC26XX_Handle handle);
bool PDMCC26XX_stopStream(PDMCC26XX_Handle handle);
bool PDMCC26XX_requestBuffer(PDMCC26XX_Handle handle, PDMCC26XX_BufferRequest *bufferRequest);
* ======== PDMCC26XX_init ========
* @pre Function assumes that it is called *once* on startup before BIOS init
* @param handle handle to the PDM object
void PDMCC26XX_init(PDMCC26XX_Handle handle) [
/* Locals */
PDMCC26XX_Object *object;
PDMCC26XX_HWAttrs const *pdmCC26XXHWAttrs;
Task_Params taskParams;
/* Set local reference to return to callers */
pdmHandle = handle;
/* Get object for this handle */
object = handle->object;
pdmCC26XXHWAttrs = handle->hwAttrs;
/* Mark the objects as available */
object->isOpen = false;
/* Then initialize I2S driver */
i2sHandle = (PDMCC26XX_I2S_Handle)&(PDMCC26XX_I2S_config);
PDMCC26XX_I2S_init(i2sHandle);
/* Configure task */
Task_Params_init(&taskParams);
taskParams.stack = pdmTaskStack;
taskParams.stackSize = PDM_TASK_STACK_SIZE;
taskParams.priority = pdmCC26XXHWAttrs->taskPriority;
/* Construct task */
Task_construct(&pdmTask, PDMCC26XX_taskFxn, &taskParams, NULL);
* ======== PDMCC26XX_open ========
* @brief Function for opening the PDM driver on CC26XX devices
* @param params Parameters needed to configure the driver
* @return handle to the opened PDM driver
PDMCC26XX_Handle PDMCC26XX_open(PDMCC26XX_Params *params) [
PDMCC26XX_Handle handle;
unsigned int key;
/* Get handle for this driver instance */
handle = pdmHandle;
/* Get the pointer to the object */
/* Disable preemption while checking if the PDM is open. */
key = Hwi_disable();
/* Check if the PDM is open already with the base addr. */
if (object->isOpen == true) [
Hwi_restore(key);
Log_warning0("PDM: already in use.");
return (NULL);
/* Mark the handle as being used */
object->isOpen = true;
Hwi_restore(key);
/* Initialize the PDM object */
object->callbackFxn = params->callbackFxn;
object->useDefaultFilter = params->useDefaultFilter;
object->micGain = params->micGain;
object->micPowerActiveHigh = params->micPowerActiveHigh;
object->applyCompression = params->applyCompression;
object->startupDelayWithClockInSamples = params->startupDelayWithClockInSamples;
object->bStreamStarted = false;
object->streamNotification = &streamNotification;
object->mallocFxn = params->mallocFxn;
object->freeFxn = params->freeFxn;
object->retBufSizeInBytes = params->retBufSizeInBytes;
/* Get first buffer for PCM data so that we don't get NULL
* pointer exception.
if ((activePcmBuffer = PDMCC26XX_getNewPcmBuffer(pdmHandle)) == NULL) [
/* We didn't manage to allocate enough space on the heap for the activePcmBuffer.
* Exit with return value NULL to prevent the driver running with activePcmBuffer == NULL
PDMCC26XX_rollbackDriverInitialisation(handle, PDM_ROLLBACK_OPEN);
Log_warning0("PDM: heap is full could not allocate space for activePcmBuffer.");
return (NULL);
/* Default PDMCC26XX_I2S parameters structure */
PDMCC26XX_I2S_Params PDMCC26XX_I2S_params = [
.requestMode = PDMCC26XX_I2S_CALLBACK_MODE,
.ui32requestTimeout = BIOS_WAIT_FOREVER,
.callbackFxn = PDMCC26XX_i2sCallbackFxn,
.blockSize = PDM_BLOCK_SIZE_IN_SAMPLES,
.pvContBuffer = (void *) pdmContinuousBuffer,
.ui32conBufTotalSize = sizeof(pdmContinuousBuffer),
.pvContMgtBuffer = (void *) pdmContMgtBuffer,
.ui32conMgtBufTotalSize = sizeof(pdmContMgtBuffer),
.currentStream = &pdmStream
/* Init IOs */
if (PDMCC26XX_initIO(handle) == false)[
/* We couldn't allocate the necessary pins though the PIN driver. */
PDMCC26XX_rollbackDriverInitialisation(pdmHandle, PDM_ROLLBACK_OPEN | PDM_ROLLBACK_ACTIVE_PCM_BUFFER);
Log_warning0("PDM: PIN driver could not allocate necessary i/o's.");
return (NULL);
/* Then open the interface with these parameters */
if ((i2sHandle = PDMCC26XX_I2S_open(i2sHandle, &PDMCC26XX_I2S_params)) == NULL)[
PDMCC26XX_rollbackDriverInitialisation(pdmHandle, PDM_ROLLBACK_OPEN | PDM_ROLLBACK_ACTIVE_PCM_BUFFER | PDM_ROLLBACK_PIN);
Log_print0(Diags_USER1, "Failed to open the I2S driver");
return (NULL);
/* Set dependency on the UDMA. This makes sure it's clocked, which in turn keeps the system bus active. */
Power_setDependency(PowerCC26XX_PERIPH_UDMA);
/* Construct ready and available queues */
Queue_construct(&pcmMsgReady, NULL);
pcmMsgReadyQueue = Queue_handle(&pcmMsgReady);
/* Initialize filters */
if (object->useDefaultFilter) [
/* Use default */
object->decimationFilter = decimationFilterInRAM;
memcpy(object->decimationFilter, PDMCC26XX_aBqCoeffs, sizeof(PDMCC26XX_aBqCoeffs));
else [
object->decimationFilter = params->decimationFilter;
/* Apply gain, if set */
if (object->micGain < PDMCC26XX_GAIN_END) [
object->decimationFilter[0] = PDMCC26XX_gainTable[object->micGain];
return (handle);
* ======== PDMCC26XX_close ========
* @brief Function for closing the PDM driver on CC26XX devices
* @param handle Handle to the PDM object
void PDMCC26XX_close(PDMCC26XX_Handle handle) [
/* Post close event to shutdown synchronously and prevent resetting settings and datastructures in the middle of a block ready event */
Event_post(pdmEvents, PDM_EVT_CLOSE);
Log_print0(Diags_USER1, "PDM: close event posted");
* ======== PDMCC26XX_startStream ========
* @brief Function for starting a PDM stream
* @pre ::PDMCC26XX_open() must be called first and there must not already be a stream in progress.
* @return true if stream started, false if something went wrong.
bool PDMCC26XX_startStream(PDMCC26XX_Handle handle) [
unsigned int key;
PDMCC26XX_HWAttrs const *hwAttrs;
hwAttrs = handle->hwAttrs;
/* Disable preemption while checking if a transfer is in progress */
if (object->bStreamStarted) [
Hwi_restore(key);
Log_error0("PDM: stream in progress");
/* Stream is in progress */
return (false);
/* Power microphone --> It typically requires some startup time */
PIN_setOutputValue(object->pinHandle, hwAttrs->micPower, (object->micPowerActiveHigh) ? 1 : 0);
uint32_t i = 0;
/* Reset decimation states */
for (i = 0; i < sizeof(decimationState)/sizeof(decimationState[0]); ++i) [
decimationState = 0x00;
/* Move unused ready elements to available queue*/
while (!Queue_empty(pcmMsgReadyQueue)) [
PDMCC26XX_queuePCM *readyNode = Queue_dequeue(pcmMsgReadyQueue);
/* Free up memory used for PCM data buffer */
object->freeFxn(readyNode->pBufferPCM, object->retBufSizeInBytes);
/* Then free up memory used by the queue element */
object->freeFxn(readyNode, sizeof(PDMCC26XX_queuePCM));
/* Reset compression data */
metaDataForNextFrame.seqNum = 0;
metaDataForNextFrame.si = 0;
metaDataForNextFrame.pv = 0;
/* Then start stream */
if (PDMCC26XX_I2S_startStream(i2sHandle)) [
/* The starting of stream succeeded, don't allow the device to enter
* standby.
Power_setConstraint(PowerCC26XX_SB_DISALLOW);
/* Make sure to flag that a stream is now active */
object->bStreamStarted = true;
Hwi_restore(key);
/* Let thread prepare to throw the first PDM_DECIMATION_STARTUP_DELAY_IN_SAMPLES samples */
Event_post(pdmEvents, PDM_EVT_START);
return true;
] else [
/* If the starting of stream failed, return false*/
Hwi_restore(key);
return false;
* ======== PDMCC26XX_stopStream ========
* @pre ::PDMCC26XX_startStream must have been called first.
* @return true if stream stopped correctly, false if something went wrong.
bool PDMCC26XX_stopStream(PDMCC26XX_Handle handle) [
unsigned int key;
bool retVal = false;
/* Get the pointer to the object and hwAttr */
if (!(object->bStreamStarted)) [
Hwi_restore(key);
Log_error0("PDM: stream not in progress");
/* Stream is not in progress */
return (false);
/* Make sure to flag that a stream is no longer active */
Hwi_restore(key);
if (!PDMCC26XX_I2S_stopStream(i2sHandle)) [
/* We failed to stop!! */
else [
/* Allow system to enter standby again */
Power_releaseConstraint(PowerCC26XX_SB_DISALLOW);
/* Unpower microphone */
PIN_setOutputValue(object->pinHandle, hwAttrs->micPower, (object->micPowerActiveHigh) ? 0 : 1);
retVal = true;
return retVal;
* @fn PDMCC26XX_taskFxn
* @brief PDM task function which is processing the PDM events from the
* driver (e.g. callback).
* @param none
* @return none
static void PDMCC26XX_taskFxn(UArg a0, UArg a1) [
uint32_t events;
static int16_t tempPcmBuf[32];
PDMCC26XX_I2S_BufferRequest bufferRequest;
PDMCC26XX_I2S_BufferRelease bufferRelease;
static uint32_t throwAwayCount = 0;
static bool pcmBufferFull = false;
static bool tempBufActive = false;
object = pdmHandle->object;
/* Semaphore and event for the task */
Event_Params evParams;
Event_Params_init(&evParams);
Event_construct(&sPDMEvents, &evParams);
pdmEvents = Event_handle(&sPDMEvents);
/* Loop forever */
for (;;) [
events = Event_pend(pdmEvents, Event_Id_NONE, (PDM_EVT_BLK_RDY | PDM_EVT_START | PDM_EVT_BLK_ERROR | PDM_EVT_CLOSE), BIOS_WAIT_FOREVER);
if ( events & PDM_EVT_CLOSE) [
/* Release dependency on the UDMA, such that the bus can be deactivated as needed */
Power_releaseDependency(PowerCC26XX_PERIPH_UDMA);
/* Move unused ready elements to available queue */
Queue_destruct(&pcmMsgReady);
Hwi_destruct(&pdmHwi);
* Deallocate the activePcmBuffer, close down the I2S driver, release the pins back to the PIN driver, and set the PDM driver to closed.
PDMCC26XX_rollbackDriverInitialisation(pdmHandle, PDM_ROLLBACK_OPEN | PDM_ROLLBACK_ACTIVE_PCM_BUFFER | PDM_ROLLBACK_I2S_DRIVER | PDM_ROLLBACK_PIN);
Log_print0(Diags_USER1, "PDM: close driver synchronously");
/* Cancel all other queued events. After closed is called, we don't want the driver to do anything else without being reopened. */
events &= 0;
if ( events & PDM_EVT_START ) [
byteCount = 0;
/* Some microphones require a startup delay with clock applied. The
* throw counter is used for this.
if(object->applyCompression) [
/* If compression is enabled, the throwAwayCount is decremented
* with respect to compressed data output. This number is the half
* of the number of samples:
throwAwayCount = MAX(PDM_DECIMATION_STARTUP_DELAY_IN_SAMPLES / 2, object->startupDelayWithClockInSamples / 2);
else [
/* If compression is disabled, the throwAwayCount is decremented
* with respect to raw data, but in bytes not samples. Each sample
* is two bytes and the throwAwayCount is operating
* in bytes, this gives us:
throwAwayCount = MAX(PDM_DECIMATION_STARTUP_DELAY_IN_SAMPLES * 2, object->startupDelayWithClockInSamples * 2);
events &= ~PDM_EVT_START;
if ( events & PDM_EVT_BLK_ERROR ) [
/* Notify caller of error */
streamNotification.status = PDMCC26XX_STREAM_ERROR;
object->callbackFxn(pdmHandle, &streamNotification);
if ( events & PDM_EVT_BLK_RDY ) [
/* Request PDM data from I2S driver */
while ( PDMCC26XX_I2S_requestBuffer(i2sHandle, &bufferRequest) ) [
/* Buffer is available as long as it returns true */
if (throwAwayCount == 0) [
/* Get new buffer from queue if active PCM buffer
* is full.
if (pcmBufferFull) [
/* PDMCC26XX_getNewPcmBuffer()
* Get new container from available queue and allocate
* memory for new buffer.
if ((activePcmBuffer = PDMCC26XX_getNewPcmBuffer(pdmHandle)) != NULL) [
byteCount = 0;
else [
/* If we did not succeed getting a new pcm buffer, we
* need to start throwing data.
* Update throwAwayCount
* In this case throw bytes equal to the size of the
* PCM buffer minus the data output size of one iteration
* (which is dependent on compression/no compression).
* Note: Assuming that the (object->retBufSizeInBytes-PCM_METADATA_SIZE) is
* larger than the data output of one iteration.
if((object->retBufSizeInBytes-PCM_METADATA_SIZE) > (object->applyCompression ? PDMCC26XX_COMPR_ITER_OUTPUT_SIZE : PDMCC26XX_CPY_ITER_OUTPUT_SIZE))[
throwAwayCount = (object->retBufSizeInBytes-PCM_METADATA_SIZE) - (object->applyCompression ? PDMCC26XX_COMPR_ITER_OUTPUT_SIZE : PDMCC26XX_CPY_ITER_OUTPUT_SIZE);
else [
/* If the retBufSizeInBytes without the metadata is less than the output of one iteration, we would get an underflow on the throwAwayCount.
* Instead, we throw away the entire buffer and leave the throwAwayCount at 0.
* Since we've thrown away more than one PCM buffer worth of PDM data, we need to increment sequence number.
metaDataForNextFrame.seqNum++;
/* Decimate PDM data to PCM, result is stored in tempPcmBuf */
pdm2pcm16k(bufferRequest.bufferIn, decimationState, object->decimationFilter, (int16_t *)&tempPcmBuf);
/* Mark the temp buf as active */
tempBufActive = true;
/* Since the tempPcmBuffer might fill up the current pcm
* buffer, we might have to perform the operation (compression
* or memcpy) on the tempPcmBuffer in more than one iteration.
* If we did not allocate a new buffer succesfully above, we
* are about to throw away data. In that case we should not
* perform an operation on the PDM data.
while(tempBufActive && !pcmBufferFull) [
int srcSize;
/* Next step is to handle the data in the tempPcmBuffer
* - If compression is enabled, the compression function
* will read in data from tempPcmBuffer and output the
* compressed data to the dynamically allocated pcmBuffer.
* - If compression is disabled, we use memcpy to move the pcm
* data from the tempPcmBuffer to the dynamically allocated
* pcmBuffer.
if (object->applyCompression) [
/* Prepare metadata.
* This is done before the first compression into the
* allocated PCM buffer.
if(byteCount == 0) [
activePcmBuffer->pBufferPCM->metaData.si = metaDataForNextFrame.si;
activePcmBuffer->pBufferPCM->metaData.pv = metaDataForNextFrame.pv;
/* If the current PCM buffer can fit the output of a
* compression of what is left in tempPcmBuf, set srcSize
* to that size. If not, set the srcSize to whatever will
* fit and mark the current pcm buffer as full.
* Note: currTempBufIndex will always be multiple of 2.
if (((object->retBufSizeInBytes-PCM_METADATA_SIZE) - byteCount) > PDMCC26XX_COMPR_ITER_OUTPUT_SIZE - (currTempBufIndex/2)) [
/* srcSize set to whatever is left in the tempPcmBuffer. */
srcSize = PDMCC26XX_COMPR_ITER_OUTPUT_SIZE*2 - currTempBufIndex;
else [
/* This is the last compression into the current data buffer,
* mark it as full.
pcmBufferFull = true;
srcSize = ((object->retBufSizeInBytes-PCM_METADATA_SIZE) - byteCount)*2;
/* Perform compression
* Since the source (tempPcmBuf) is operated as int16_t,
* while the output as uint8_t srcSize is size in samples
* (int16), it must be multiple of 2.
Codec1_encodeBuff((uint8_t *)&(activePcmBuffer->pBufferPCM->pBuffer[byteCount]),
(int16_t *)&(tempPcmBuf[currTempBufIndex]),
srcSize,
(int8_t *)&metaDataForNextFrame.si,
(int16_t *)&metaDataForNextFrame.pv);
/* Update byteCount for next iteration.
* Since the compression is reduzing the size with a factor 4,
* and the pcm output buffer and the tempPcm buffer are of
* different types, the byteCount will be incremented with
* half the size of srcSize.
byteCount += srcSize/2;
/* Prepare currTempBufIndex for next iteration */
currTempBufIndex += srcSize;
else [
/* Compression is disabled */
/* Compression will not be performed, so we copy data from
* temporary pcm buffer to allocated memory. Uncompressed
* PCM data buffer is 64 Bytes wide.
* Output and input are handled as bytes.
if (((object->retBufSizeInBytes-PCM_METADATA_SIZE) - byteCount) > (PDMCC26XX_CPY_ITER_OUTPUT_SIZE - (currTempBufIndex*2))) [
srcSize = PDMCC26XX_CPY_ITER_OUTPUT_SIZE - (currTempBufIndex*2);
else [
* mark it as full.
srcSize = (object->retBufSizeInBytes-PCM_METADATA_SIZE) - byteCount;
/* Copy PCM data from temp buffer to allocated memory */
memcpy(&(activePcmBuffer->pBufferPCM->pBuffer[byteCount]),
&tempPcmBuf[currTempBufIndex],
srcSize);/* <- size in bytes */
/* Prepare byteCount for next iteration, for memcpy the
* byteCount is equal to the srcSize.
byteCount += srcSize;
/* Prepare currTempBufIndex for next iteration.
* Since the srcSize is byte aligned, but the tempBuffer
* is sample (int16_t) aligned, divide srcSize with 2.
currTempBufIndex += srcSize/2;
/* Is all the data in the tempPcmBuffer consumed?
* If so, reset the index count and clear active flag.
if(currTempBufIndex >= (sizeof(tempPcmBuf)/sizeof(tempPcmBuf[0]))) [
/* If the allocated PCM buffer is full, we need to flag
* that the PCM buffer is ready (and making the callback).
* And last, allocate a new PCM buffer to be used.
PDMCC26XX_setPcmBufferReady(pdmHandle, activePcmBuffer, (PDMCC26XX_I2S_BufferRequest *)&bufferRequest);
/* Get new PCM buffer from available queue and allocate
byteCount = 0;
else [
/* if we did not succeed getting a new pcm buffer,
* we need to start throwing data.
* Update ThrowCount
* In this case throw count is equal to data fitting
* in one allocated PCM buffer minus the output data
* which will be thrown in this iteration.
* Data thrown amount is data size of one iteration (which is dependent on
* compression/no compression), minus the data already
* consumed by the previous buffer.
if((object->retBufSizeInBytes-PCM_METADATA_SIZE) > (object->applyCompression ? PDMCC26XX_COMPR_ITER_OUTPUT_SIZE : PDMCC26XX_CPY_ITER_OUTPUT_SIZE) - currTempBufIndex)[
throwAwayCount = (object->retBufSizeInBytes-PCM_METADATA_SIZE) - ((object->applyCompression ? PDMCC26XX_COMPR_ITER_OUTPUT_SIZE : PDMCC26XX_CPY_ITER_OUTPUT_SIZE) - currTempBufIndex);
else [
/* If the retBufSizeInBytes without the metadata is less than the output of one iteration minus the currTempBufIndex, we would get an underflow on the throwAwayCount.
/* Mark the tempBuf as no longer active */
else [
/* Still throwing away data */
if (throwAwayCount<=(object->applyCompression ? PDMCC26XX_COMPR_ITER_OUTPUT_SIZE : PDMCC26XX_CPY_ITER_OUTPUT_SIZE)) [
/* if the amount to be thrown away is less than or equal to
* the output of one iteration of the data operation, the
* count must be set to zero, the sequence number must be
* incremented, and the index to be used by next data operation
* must be updated correspondingly.
/* Note: Currently the startup delay will use the throwAwayCount
* and that means the sequence number will be incremented
* after the startup throwing has finished.
/* tempPcmBuf is int16 array, but the throwAwayCount is
* count in bytes.
/* If compression is enabled, the throwAwayCount number
* is the half of the number of samples:
currTempBufIndex = throwAwayCount * 2;
else [
* with respect to raw data, but in bytes not samples. Since
* the currTempBufIndex is sample oriented, we need to divide
* that number with 2.
currTempBufIndex = (throwAwayCount + 1) / 2;
throwAwayCount = 0;
else [
/* Decrement the throw counter with amount corresponding to
* output data size of one iteration.
throwAwayCount -= (object->applyCompression ? PDMCC26XX_COMPR_ITER_OUTPUT_SIZE : PDMCC26XX_CPY_ITER_OUTPUT_SIZE);
/* Release PDM buffer */
bufferRelease.bufferHandleIn = bufferRequest.bufferHandleIn;
PDMCC26XX_I2S_releaseBuffer(i2sHandle, &bufferRelease);
events &= ~PDM_EVT_BLK_RDY;
* ======== PDMCC26XX_requestBuffer ========
* @pre Function assumes that the stream has started and that bufferRequest is not NULL.
bool PDMCC26XX_requestBuffer(PDMCC26XX_Handle handle, PDMCC26XX_BufferRequest *bufferRequest) [
/* We expect the user to call this after being notified of available
* buffers. Hence we may directly check queue and dequeue buffer
if (!Queue_empty(pcmMsgReadyQueue))[
PDMCC26XX_queuePCM *readyNode = Queue_get(pcmMsgReadyQueue);
/* Provide pointer to buffer including 4 byte metadata */
bufferRequest->buffer = readyNode->pBufferPCM;
bufferRequest->status = streamNotification.status;
/* free up memory used by queue element */
else [
return false;
return true;
static void PDMCC26XX_i2sCallbackFxn(PDMCC26XX_I2S_Handle handle, PDMCC26XX_I2S_StreamNotification *notification) [
if (notification->status == PDMCC26XX_I2S_STREAM_ERROR) [
/* Let thread process PDM error */
Event_post(pdmEvents, PDM_EVT_BLK_ERROR);
else [
/* Let thread process PDM data */
Event_post(pdmEvents, PDM_EVT_BLK_RDY);
* ======== PDMCC26XX_initIO ========
* This functions initializes the PDM IOs.
* @pre Function assumes that the PDM handle is pointing to a hardware
* module which has already been opened.
static bool PDMCC26XX_initIO(PDMCC26XX_Handle handle) [
PIN_Config micPinTable[PDM_NUMBER_OF_PINS + 1];
uint32_t i=0;
/* Get the pointer to the object and hwAttrs */
/* Configure IOs */
/* Build local list of pins, allocate through PIN driver and map HW ports */
if (hwAttrs->micPower != PIN_UNASSIGNED) [
micPinTable[i++] = hwAttrs->micPower | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX;
micPinTable = PIN_TERMINATE;
/* Open and assign pins through pin driver */
if (!(object->pinHandle = PIN_open(&(object->pinState), micPinTable))) [
return false;
return true;
* ======== PDMCC26XX_setPcmBufferReady ========
* This function prepares metadata, puts the buffer in ready queue, sets stream
* status and makes the callback.
static void PDMCC26XX_setPcmBufferReady(PDMCC26XX_Handle handle, PDMCC26XX_queuePCM *pcmBuffer, PDMCC26XX_I2S_BufferRequest *bufReq) [
/* Update sequence number */
pcmBuffer->pBufferPCM->metaData.seqNum = metaDataForNextFrame.seqNum++;
/* Place PCM buffer in ready queue */
Queue_put(pcmMsgReadyQueue, &pcmBuffer->_elem);
/* Notify caller by updating the stream status */
if (bufReq->status == PDMCC26XX_I2S_STREAM_BUFFER_READY) [
streamNotification.status = PDMCC26XX_STREAM_BLOCK_READY;
else if (bufReq->status == PDMCC26XX_I2S_STREAM_BUFFER_READY_BUT_NO_AVAILABLE_BUFFERS) [
streamNotification.status = PDMCC26XX_STREAM_BLOCK_READY_BUT_PDM_OVERFLOW;
else [
streamNotification.status = PDMCC26XX_STREAM_STOPPING;
/* Only notify when PCM buffer is complete */
* ======== PDMCC26XX_getNewPcmBuffer ========
* This function gets a new queue element from the available queue and then
* tries to allocate the memory space needed for a new buffer.
* @return true if a new PCM buffer was succesfully allocated, false if the
* available queue was empty or the memory allocation function did not
* succeed.
static PDMCC26XX_queuePCM * PDMCC26XX_getNewPcmBuffer(PDMCC26XX_Handle handle) [
PDMCC26XX_queuePCM *buf;
/* Allocate memory for a new queue element */
buf = object->mallocFxn(sizeof(PDMCC26XX_queuePCM));
/* If allocation went OK, allocate more... */
if (buf != NULL) [
/* Dynamically allocated memory for new pcm buffer */
buf->pBufferPCM = object->mallocFxn(object->retBufSizeInBytes);
/* If new memory was allocated correctly, return pointer. */
if (buf->pBufferPCM != NULL) [
return buf;
else [
/* Was not able to allocate memory for the pcm buffer, deallocate
* the memory used by queue element.
object->freeFxn(buf, sizeof(PDMCC26XX_queuePCM));
return NULL;
* ======== PDMCC26XX_rollbackDriverInitialisation ========
* This function rolls back different parts of the PDM driver initialisation depending on the rollbackVector.
* Passing ~0 as the rollbackVector will reverse all failable initialisations.
* Only those parts of the driver that can fail when calling PDMCC26XX_open can be included as entries in the rollbackVector.
static void PDMCC26XX_rollbackDriverInitialisation(PDMCC26XX_Handle handle, uint32_t rollbackVector)[
unsigned int key;
if (rollbackVector & PDM_ROLLBACK_I2S_DRIVER) [
/* Release ownership and revert to init settings. */
PDMCC26XX_I2S_close(i2sHandle);
if (rollbackVector & PDM_ROLLBACK_PIN) [
/* Release the allocated pins back to the pin driver */
PIN_close(object->pinHandle);
if (rollbackVector & PDM_ROLLBACK_ACTIVE_PCM_BUFFER) [
* Free the activePcmBuffer if it is not NULL. It can be NULL if either insufficient time was provided after PDMCC26XX_open for
* the open event in the task function to run and allocate the memory or if we ran out of heap space earlier and the PDMCC26XX_getNewPcmBuffer
* function returned NULL.
if(activePcmBuffer != NULL)[
/* Free up memory used for activePcmBuffer */
object->freeFxn(activePcmBuffer->pBufferPCM, object->retBufSizeInBytes);
object->freeFxn(activePcmBuffer, sizeof(PDMCC26XX_queuePCM));
/* Make sure the activePcmBuffer doesn't point anywhere anymore as the target no longer exists. */
activePcmBuffer = NULL;
if (rollbackVector & PDM_ROLLBACK_OPEN) [
/* Mark the module as available */
Hwi_restore(key);
举报
更多回帖
