Cypress技术论坛
直播中
李维洲
7年用户 233经验值
私信 关注
[问答]
请问CWW8932支持WPA/WPA2混合模式吗?
你好,
我想知道WPA/WPA2混合模式是否支持SOFTAP,以下设置:
cyw89342fw_bcmdhd_rsdb.bin(释放89359_p8.2)bcmdhd 1.363.43(释放89359_p8.2)wpa_supplicant(释放89359_p8.2)
文件提出“模式在WPA或WPA2模式(“89359个用户手册- RSDB并发模式”)。但是似乎没有任何提及WPA/WPA2混合模式。这是支持的吗?
谢谢!
以上来自于百度翻译
        以下为原文
                                            Hi,
I'd like to know if WPA/WPA2 mixed mode is supported on SoftAP with the following setup:
  • CYW89342
  • fw_bcmdhd_RSDB.bin (from release 89359_P8.2)
  • bcmdhd 1.363.43 (from release 89359_P8.2)
  • wpa_supplicant (from release 89359_P8.2)
The documentation to bring up SoftAP mode in either WPA or WPA2 mode works ("89359 PCIe User Manual - RSDB Concurrency Modes"). However there doesn't seem to be any mention of WPA/WPA2 mixed mode. Is this supported?
Thanks!
回帖(1)
h1654155275.5741
2018-8-15 00:11:02
CYW8932不支持在广阔的市场上,也不支持CyPress IOT社区。
为开发工具和技术支持,请与当地柏树/分销团队合作,使您成为这个平台上的早期采用者。
以上来自于百度翻译
        以下为原文
                                            The CYW89342 is not supported within the broad market or here on the Cypress IoT community.
For development tool and technical support, please work with the local Cypress/Distribution team that enabled you as an early adopter on this platform.
举报
更多回帖
