TI论坛
直播中
徐磊
7年用户 921经验值
私信 关注
[问答]
请问EK-TM4C123GXL的ButtonsPoll例程函数ui8SwitchClockA和ui8SwitchClockB的作用是什么?
在阅读EK-TM4C123GXL关于FreeRTOS的例程时,有个地方没搞懂。下面这个函数用来检测按键状态,其中ui8SwitchClockA和ui8SwitchClockB的作用是什么?
该函数是否能实现软件去抖动,如何实现的?谢谢指导。
uint8_t
ButtonsPoll(uint8_t *pui8Delta, uint8_t *pui8RawState)
uint32_t ui32Delta;
uint32_t ui32Data;
static uint8_t ui8SwitchClockA = 0;
static uint8_t ui8SwitchClockB = 0;
// Read the raw state of the push buttons. Save the raw state
// (inverting the bit sense) if the caller supplied storage for the
// raw value.
ui32Data = (ROM_GPIOPinRead(BUTTONS_GPIO_BASE, ALL_BUTTONS));
if(pui8RawState)
*pui8RawState = (uint8_t)~ui32Data;
// Determine the switches that are at a different state than the debounced
// state.
ui32Delta = ui32Data ^ g_ui8ButtonStates;
// Increment the clocks by one.
ui8SwitchClockA ^= ui8SwitchClockB;
ui8SwitchClockB = ~ui8SwitchClockB;
// Reset the clocks corresponding to switches that have not changed state.
ui8SwitchClockA &= ui32Delta;
ui8SwitchClockB &= ui32Delta;
// Get the new debounced switch state.
g_ui8ButtonStates &= ui8SwitchClockA | ui8SwitchClockB;
g_ui8ButtonStates |= (~(ui8SwitchClockA | ui8SwitchClockB)) & ui32Data;
// Determine the switches that just changed debounced state.
ui32Delta ^= (ui8SwitchClockA | ui8SwitchClockB);
// Store the bit mask for the buttons that have changed for return to
// caller.
if(pui8Delta)
*pui8Delta = (uint8_t)ui32Delta;
// Return the debounced buttons states to the caller. Invert the bit
// sense so that a '1' indicates the button is pressed, which is a
// sensible way to interpret the return value.
return(~g_ui8ButtonStates);
回帖(3)
韦明
2018-8-15 06:24:48
是可以实现软件的去抖动的。这个函数应当是放在定时器中的,具体的算法,我也没看懂。ui8SwitchClockB和ui8SwitchClockA 应当是前后两次扫描到的按键的键值,然后进行的比较吧。
举报
徐磊
2018-8-15 06:30:19
为了便于分析,假定有八个按键。
这段代码通过抑或求变化状态,比较明显。就不做详细分析,主要是ui32Delta = ui32Data ^ g_ui8ButtonStates这一行代码。
去抖动的实现通过ui8SwitchClockA 和 ui8SwitchClockB来实现。g_ui8ButtonStates和pui8Delta的最终返回值都需要通过A和B来mask。
只有当A与B都为0x00时,二者状态才会改变。A和B都为0x00就必须要求ui32Delta=0x00,也就是相邻的采样按键状态保持一致。
举报
韦明
2018-8-15 06:43:58
引用: 60user101 发表于 2018-8-15 06:30
为了便于分析,假定有八个按键。
赞一个,要弄懂别人的算法,是很不容易的。学习了。
举报
更多回帖
