TI论坛
直播中
李桂芝
7年用户 165经验值
私信 关注
[问答]
请问TM4C1294应用升级该如何实现?哪里有配套的例程
小弟最近拿到一块EK-TM41294的demo板,调试远程升级功能。
背景:
目前用tivaware_C_Series-2.1.3.156 固件例子中的boot_serial程序可以实现串口升级。
该目录下没有网口升级例子,于是在SW-DK-TM4C129X-2.1.3.156.exe 例程中找到boot_demo_emac_flash例子
把例子移植到Tivaware_C_Series-2.1.3.156,使用该库的驱动及对应库,可以编译生成bin程序,烧录进去后
可以看到板卡MAC和设置的IP,然后程序就一直在这个位置,使用LM flash program 配置成网络模式升级也失败,连接不上,不知道有没有人做过该例子?
贴上源码
// Demonstrate the use of the boot loader.
int
main(void)
// tContext sContext;
uint32_t ui32IPAddr;
SysCtlMOSCConfigSet(SYSCTL_MOSC_HIGHFREQ);
// Run from the PLL at 120 MHz.
g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN | SYSCTL_USE_PLL |
SYSCTL_CFG_VCO_480), 120000000);
// Configure the device pins.
PinoutSet(true,false);
// Initialize the display driver.
/// Kentec320x240x16_SSD2119Init(g_ui32SysClock);
// Initialize the graphics context.
// GrContextInit(&sContext, &g_sKentec320x240x16_SSD2119);
// Draw the application frame.
// FrameDraw(&sContext, "boot-demo-emac-flash");
// Initialize the peripherals that each of the boot loader flavors
// supports. Although this example is only intended for use with the
// Ethernet boot loader, we initialize the other two peripherals too just
// in case it is used with the USB or serial boot loaders.
SetupForUART();
SetupForEthernet();
// SetupForUSB();
// Add the compile-time defined widgets to the widget tree.
// WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sBackground);
// Paint the widget tree to make sure they all appear on the display.
// WidgetPaint(WIDGET_ROOT);
// We don't have an IP address yet so clear the variable to tell us to
// check until we are assigned one.
ui32IPAddr = 0;
UARTprintf("g_bFirmwareUpdate=%dnr",g_bFirmwareUpdate);
// Loop forever, processing widget messages.
while(!g_bFirmwareUpdate)
// UARTprintf("ui32IPAddr=%xnr",ui32IPAddr);
// Do we have an IP address yet? If not, check to see if we've been
// assigned one since the last time we checked.
#if 1
if(ui32IPAddr == 0 || ui32IPAddr == 0xFFFFFFFF)
// What is our current IP address?
ui32IPAddr = lwIPLocalIPAddrGet();
// If it's non zero, update the display.
if(ui32IPAddr!= 0 && ui32IPAddr != 0xFFFFFFFF)
UARTprintf("IP: %d.%d.%d.%dnr",ui32IPAddr & 0xff, (ui32IPAddr >> 8) & 0xff,
(ui32IPAddr >> 16) & 0xff, ui32IPAddr >> 24);
// WidgetPaint((tWidget *)&g_sIPAddr);
#endif
// Process any messages from or for the widgets.
// WidgetMessageQueueProcess();
// If we drop out, the user has sent "Magic Package" via LMFlash
// so we tidy up and transfer control to the boot loader.
// Tell the user that we got their instruction.
// CanvasTextSet(&g_sStatus, "Updating...");
// WidgetPaint((tWidget *)&g_sStatus);
UARTprintf("Updating...nr");
// Process all remaining messages on the queue (including the paint message
// we just posted).
// Transfer control to the bootloader.
SoftwareUpdateBegin(g_ui32SysClock);
// The previous function never returns but we need to stick in a return
// code here to keep the compiler from generating a warning.
return(0);
网络配置如下:
// Perform the initialization steps required to start up the Ethernet controller
// and lwIP stack.
void
SetupForEthernet(void)
uint32_t ui32User0, ui32User1;
uint8_t pui8MACAddr[8];
// Configure SysTick for a 100Hz interrupt.
ROM_SysTickPeriodSet(g_ui32SysClock / TICKS_PER_SECOND);
ROM_SysTickEnable();
ROM_SysTickIntEnable();
// Get the MAC address from the UART0 and UART1 registers in NV ram.
ROM_FlashUserGet(&ui32User0, &ui32User1);
if((ui32User0 == 0xffffffff) || (ui32User1 == 0xffffffff))
// We should never get here. This is an error if the MAC address has
// not been programmed into the device. Exit the program.
UARTprintf("MAC Address Not Programmed!nr");
while(1)
// Convert the 24/24 split MAC address from NV ram into a MAC address
// array.
pui8MACAddr[0] = ui32User0 & 0xff;
pui8MACAddr[1] = (ui32User0 >> 8) & 0xff;
pui8MACAddr[2] = (ui32User0 >> 16) & 0xff;
pui8MACAddr[3] = ui32User1 & 0xff;
pui8MACAddr[4] = (ui32User1 >> 8) & 0xff;
pui8MACAddr[5] = (ui32User1 >> 16) & 0xff;
// Format this address into the string used by the relevant widget.
UARTprintf("MAC: %02X-%02X-%02X-%02X-%02X-%02Xnr",
pui8MACAddr[0], pui8MACAddr[1], pui8MACAddr[2], pui8MACAddr[3],
pui8MACAddr[4], pui8MACAddr[5]);
// Remember that we don't have an IP address yet.
// usnprintf(g_pcIPAddr, SIZE_IP_ADDR_BUFFER, "IP: Not assigned");
UARTprintf("IP: Not assignednr");
// Initialize the lwIP TCP/IP stack.
// lwIPInit(g_ui32SysClock, pui8MACAddr, 0, 0, 0, IPADDR_USE_AUTOIP);
lwIPInit(g_ui32SysClock, pui8MACAddr,0xC0A8010C ,0xFFFFFF0, 0xC0A80101 , IPADDR_USE_STATIC);
// Setup the device locator service.
// LocatorInit();
// LocatorMACAddrSet(pui8MACAddr);
// Start the remote software update module.
UARTprintf("SoftwareUpdateInitnr");
SoftwareUpdateInit(SoftwareUpdateRequestCallback);   //这句一直没有运行,不知道为什么
回帖(8)
韦明
2018-8-14 06:17:34
使用网口升级的话,应该是boot_emac_flash和boot_demo_flash都烧录的。你是否只烧录了前者呢?
举报
李桂芝
2018-8-14 06:36:40
是的,我的理解是boot_emac_flash 其实就是支持网口升级的bootloader,那为何它不能通过网口升级应用程序呢?
举报
刘丽艳
2018-8-14 06:54:47
如果直接用ROM里的ETHERNET BOOT LOADER + LM FLASH PROGRAMMER可以么?
        Holly
举报
李桂芝
2018-8-14 07:04:09
        Holly
资料文档对这两个例子就这两个说明:
举报
更多回帖
