ADI 技术
直播中
石胜厚
8年用户 1145经验值
私信 关注
[问答]
请问AD8015芯片能否采用直流光进行光电检测?
回帖(1)
陈桂兰
2018-8-9 07:17:40
可以但不合适。“The AD8015 is a wide bandwidth, single supply transimpedance amplifier optimized for use in a fiber optic receiver circuit. It is a complete, single chip solution for converting photodiode current into a differential voltage output. The 240 MHz bandwidth enables AD8015 application in FDDI receivers and SONET/SDH receivers with data rates up to 155 Mbps.”可见,AD8015并不适合对DC输入电流信号进行IV转换,它的直流误差是很大的。
建议用高精度的运放做IV转换,比如AD8605.
举报
更多回帖
