默认你是说上电后还是初始化后,初始化后是32Mhz.
上电时,都是关闭的,进入active 16MRC和32M晶振都会打开,然后就根据你的选择。
#define HAL_BOARD_INIT()
uint16 i;
SLEEPCMD &= ~OSC_PD; /* turn on 16MHz RC and 32MHz XOSC */
while (!(SLEEPSTA & XOSC_STB)); /* wait for 32MHz XOSC stable */
asm("NOP"); /* chip bug workaround */
for (i=0; i<504; i++) asm("NOP"); /* Require 63us delay for all revs */
CLKCONCMD = (CLKCONCMD_32MHZ | OSC_32KHZ); /* Select 32MHz XOSC and the source for 32K clock */
while (CLKCONSTA != (CLKCONCMD_32MHZ | OSC_32KHZ)); /* Wait for the change to be effective */
SLEEPCMD |= OSC_PD; /* turn off 16MHz RC */
/* Turn on cache prefetch mode */
PREFETCH_ENABLE();
HAL_TURN_OFF_LED1();
LED1_DDR |= LED1_BV;
HAL_TURN_OFF_LED2();
LED2_DDR |= LED2_BV;
HAL_TURN_OFF_LED3();
LED3_DDR |= LED3_BV;
/* configure tristates */
P0INP |= PUSH2_BV;
uint16 i;
PREFETCH_ENABLE();
P0INP |= PUSH2_BV;
举报
