| 核心板主型号 (cord board model) | CPU | 内存容量 (Memory) | 存储容量 (Storage) | 启动方式 (boot mode) | 烧录方式 (burning mode) | 其它 (others) |
| MY-IMX8M_CB314 | MIMX8MQ6DVAJZAA | 1G/2G | eMMC:4G~32G | eMMC | 拨码进入 (Dial-up entry) | 标配:内存2G,存储16G (standard configuration:memory 2G,storage 16G) |
| 显示模块 (display module) | HDMI | 1路(1 way) |
| MIPI-CSI | 2路(2 way) | |
| 以太网 (Ethernet) | RGMII | 1路(1 way) |
| 音频 (Audio) | SAI | 6路(6 way) |
| PCI Express | PCle | 2路(2 way) |
| 存储 (storage) | SD/MMC卡 (SD/MMC card) | 2路(2 way) |
| Nand Flash | 1路(1 way) | |
| USB | USB 2.0 | 2路(2 way) |
| USB 3.0 | 2路(2 way) | |
| SPI | SPI | 3路(3 way) |
| UART | UART | 4路(4 way) |
| ADC | ADC | 2路(2 way) |
| 12C | 12C | 4路(4 way) |
| 调试 (debug) | JTAG | 1路(1 way) |
| Pin NO. | Pin Name | 管脚电压 (Pin voltage) | Pin NO. | Pin Name | 管脚电压 (Pin voltage) |
| P1 | GND | 0V | S1 | GND | 0V |
| P2 | GND | 0V | S2 | RGMII_INT | 1.8V |
| P3 | GND | 0V | S3 | NFC_WAKE | 1.8V |
| P4 | RGMII_RXD2 | 3.3V | S4 | NFC_REG_ON | 3.3V |
| P5 | RGMII_TXD1 | 3.3V | S5 | SPI0_CSn0 | 3.3V |
| P6 | RGMII_RXD3 | 3.3V | S6 | SPI0_CSn0 | 3.3.V |
| P7 | RGMII_RXDV | 3.3V | S7 | NFC_HOST_WAKE | 3.3V |
| P8 | RGMII_TXD0 | 3.3V | S8 | SDMMC_D3 | 3.3V |
| P9 | RGMII_TXEN | 3.3V | S9 | SDMMC_CMD | 3.3V |
| P10 | RGMII_RXER | 3.3V | S10 | SDMMC_D2 | 3.3V |
| P11 | GND | 0V | S11 | SDMMC_DET | 3.3V |
| P12 | RGMII_CLK | 3.3V | S12 | SDMMC_D1 | 3.3V |
| P13 | GND | 0V | S13 | SDMMC_CLK | 3.3V |
| P14 | RGMII_RXD0 | 3.3V | S14 | SDMMC_D0 | 3.3V |
| P15 | RGMII_RXD1 | 3.3V | S15 | SDMMC_WP | 3.3V |
| P16 | RGMII_TXD2 | 3.3V | S16 | FLASH0_ALE | 1.8V |
| P17 | RGMII_TXD3 | 3.3V | S17 | FLASH0_CLE | 1.8V |
| P18 | RGMII_TXCLK | 3.3V | S18 | FLASH0_RDY | 1.8V |
| P19 | RGMII_RXCLK | 3.3V | S19 | FLASH0_CS0 | 1.8V |
| P20 | RGMII_MDC | 3.3V | S20 | MIPI_RST | 1.8V |
| P21 | RGMII_MDIO | 3.3V | S21 | UART1_CTS | 3.3V |
| P22 | RGMII_RST | 3.3V | S22 | UART1_RX | 3.3V |
| P23 | RGMII_CRS | 3.3V | S23 | UART1_TX | 3.3V |
| P24 | GND | 0V | S24 | UART1_RTS | 3.3V |
| P25 | SDIO0_D3 | 2.2V | S25 | GPIO5_C2 | 3.3V |
| P26 | SDIO0_CMD | 2.2V | S26 | SPI0_TXD | 3.3V |
| P27 | SDIO0_D0 | 2.2V | S27 | SPI0_RXD | 3.3V |
| P28 | SDIO0_D2 | 2.2V | S28 | SPI0_CSn1 | 3.3V |
| P29 | SDIO0_D1 | 2.2V | S29 | WIFI_REG_ON | 2.2V |
| P30 | SDIO0_CLK | 2.2V | S30 | BT_HOST_WAKE | 2.2V |
| P31 | GND | 0V | S31 | GPIO4_D3 | 2.2V |
| P32 | GND | 0V | S32 | WIFI_HOST_WAKE | 2.2V |
| P33 | GND | 0V | S33 | BT_RST | 2.2V |
| P34 | GND | 0V | S34 | BT_WAKE | 2.2V |
| P35 | GND | 0V | S35 | GND | 0V |
| P36 | GND | 0V | S36 | GND | 0V |
| P37 | UART0_CTS | 2.2V | S37 | I2S0_CLK | 3.3V |
| P38 | UART0_RTS | 2.2V | S38 | GND | 0V |
| P39 | UART0_TXD | 2.2V | S39 | I2S0_SCLK | 3.3V |
| P40 | UART0_RXD | 2.2V | S40 | I2S0_SDI | 3.3V |
| P41 | I2C2_SCL | 3.3V | S41 | I2S0_LRCK_TX | 3.3V |
| P42 | I2C2_SDA | 3.3V | S42 | I2S0_LRCK_RX | 3.3V |
| P43 | SPDIF_TX | 3.3V | S43 | I2S0_SDO0 | 3.3V |
| P44 | GND | 0V | S44 | I2S0_SDO3 | 3.3V |
| P45 | EDP_TX0P | 1.8V | S45 | I2S0_SDO2 | 3.3V |
| P46 | EDP_TX0N | 1.8V | S46 | I2S0_SDO1 | 3.3V |
| P47 | GND | 0V | S47 | HDMI_HPD | 1.8V |
| P48 | EDP_TX1P | 1.8V | S48 | GND | 0V |
| P49 | EDP_TX1N | 1.8V | S49 | HDMI_TXCP | 1.8V |
| P50 | GND | 0V | S50 | HDMI_TXCN | 1.8V |
| P51 | EDP_TX2P | 1.8V | S51 | GND | 0V |
| P52 | EDP_TX2N | 1.8V | S52 | HDMI_TX0P | 1.8V |
| P53 | GND | 0V | S53 | HDMI_TX0N | 1.8V |
| P54 | EDP_TX3P | 1.8V | S54 | GND | 0V |
| P55 | EDP_TX3N | 1.8V | S55 | HDMI_TX1N | 1.8V |
| P56 | GND | 0V | S56 | HDMI_TX1P | 1.8V |
| P57 | EDPAUXP | 1.8V | S57 | GND | 0V |
| P58 | EDPAUXN | 1.8V | S58 | HDMI_TX2N | 1.8V |
| P59 | GND | 0V | S59 | HDMI_TX2P | 1.8V |
| P60 | MIPI_RX_D0N | 1.8V | S60 | GND | 0V |
| P61 | MIPI_RX_D0P | 1.8V | S61 | MIPI_TX/RX_D0P | 1.8V |
| P62 | GND | 0V | S62 | MIPI_TX/RX_D0N | 1.8V |
| P63 | MIPI_RX_D1N | 1.8V | S63 | GND | 0V |
| P64 | MIPI_RX_D1P | 1.8V | S64 | MIPI_TX/RX_D1P | 1.8V |
| P65 | GND | 0V | S65 | MIPI_TX/RX_D1N | 1.8V |
| P66 | MIPI_RX_CLKN | 1.8V | S66 | GND | 0V |
| P67 | MIPI_RX_CLKP | 1.8V | S67 | MIPI_TX/RX_CLKP | 1.8V |
| P68 | GND | 0V | S68 | MIPI_TX/RX_CLKN | 1.8V |
| P69 | MIPI_RX_D2N | 1.8V | S69 | GND | 1.8V |
| P70 | MIPI_RX_D2P | 1.8V | S70 | MIPI_TX/RX_D2P | 1.8V |
| P71 | GND | 0V | S71 | MIPI_TX/RX_D2N | 1.8V |
| P72 | MIPI_RX_D3N | 1.8V | S72 | GND | 0V |
| P73 | MIPI_RX_D3P | 1.8V | S73 | MIPI_TX/RX_D3P | 1.8V |
| P74 | GND | 0V | S74 | MIPI_TX/RX_D3N | 1.8V |
| P75 | GND | 0V | S75 | GND | 0V |
| P76 | LVDS_D4P | 3.3V | S76 | GND | 0V |
| P77 | LVDS_D4N | 3.3V | S77 | GND | 0V |
| P78 | LVDS_D3P | 3.3V | S78 | MIPI_TX_D1P | 1.8V |
| P79 | LVDS_D3N | 3.3V | S79 | MIPI_TX_D1N | 1.8V |
| P80 | LVDS_D2P | 3.3V | S80 | GND | 0V |
| P81 | LVDS_D2N | 3.3V | S81 | MIPI_TX_D0P | 1.8V |
| P82 | LVDS_CLK0P | 3.3V | S82 | MIPI_TX_D0N | 1.8V |
| P83 | LVDS_CLK0N | 3.3V | S83 | GND | 0V |
| P84 | LVDS_D1P | 3.3V | S84 | MIPI_TX_CLKP | 1.8V |
| P85 | LVDS_D1N | 3.3V | S85 | MIPI_TX_CLKN | 1.8V |
| P86 | LVDS_D0P | 3.3V | S86 | GND | 0V |
| P87 | LVDS_D0N | 3.3V | S87 | MIPI_TX_D2P | 1.8V |
| P88 | LVDS_D8P | 3.3V | S88 | MIPI_TX_D2N | 1.8V |
| P89 | LVDS_D8N | 3.3V | S89 | GND | 0V |
| P90 | LVDS_D9N | 3.3V | S90 | MIPI_TX_D3P | 1.8V |
| P91 | LVDS_D9P | 3.3V | S91 | MIPI_TX_D3N | 1.8V |
| P92 | LVDS_D7N | 3.3V | S92 | GND | 0V |
| P93 | LVDS_D7P | 3.3V | S93 | CIF_D5 | 1.8V |
| P94 | LVDS_CLK1N | 3.3V | S94 | CIF_D1 | 1.8V |
| P95 | LVDS_CLK1P | 3.3V | S95 | CIF_D2 | 1.8V |
| P96 | LVDS_D6P | 3.3V | S96 | CIF_D3 | 1.8V |
| P97 | LVDS_D6N | 3.3V | S97 | CIF_D0 | 1.8V |
| P98 | LVDS_D5P | 3.3V | S98 | CIF_CLK | 1.8V |
| P99 | LVDS_D5N | 3.3V | S99 | CIF_D7 | 1.8V |
| P100 | LCDC0_VSYNC | 3.3V | S100 | CIF_D4 | 1.8V |
| P101 | GND | 0V | S101 | CIF_D6 | 1.8V |
| P102 | LCDC0_DCLK | 3.3V | S102 | CIF_PDN1 | 1.8V |
| P103 | GND | 0V | S103 | CIF_CLKO | 1.8V |
| P104 | LCDC0_HSYNC | 3.3V | S104 | CIF_VSYNC | 1.8V |
| P105 | LCDC0_DEN | 3.3V | S105 | CIF_PDN0 | 1.8V |
| P106 | I2C3_SCL | 1.8V | S106 | CIF_HREF | 1.8V |
| P107 | I2C3_SDA | 1.8V | S107 | GND | 0V |
| P108 | GPIO2_B6 | 1.8V | S108 | UART3_TX | 3.3V |
| P109 | GPIO2_B5 | 1.8V | S109 | 5V_DRV | 3.3V |
| P110 | GND | 0V | S110 | GYR_INT | 3.3V |
| P111 | ADC_IN0 | 1.8V | S111 | EDP_BL | 3.3V |
| P112 | ADC_IN2 | 1.8V | S112 | UART3_CTS | 3.3V |
| P113 | RECOVER | 1.8V | S113 | FLASH_TRIGOUT | 3.3V |
| P114 | GND | 0V | S114 | LCDC_BL | 3.3V |
| P115 | EFUSE_PWR | 3.3V | S115 | TOUCH_RST | 3.3V |
| P116 | PMUGPIO0_B5 | 3.3V | S116 | LCD_EN | 3.3V |
| P117 | OTG_VBUS_DRV | 3.3V | S117 | LCD_RST | 3.3V |
| P118 | PHONE_CTL | 3.3V | S118 | TOUCH_INT | 3.3V |
| P119 | UART2_RXD | 3.3V | S119 | I2C1_SCL | 3.3V |
| P120 | UART2_TXD | 3.3V | S120 | I2C1_SDA | 3.3V |
| P121 | HDMI_CEC | 3.3V | S121 | GSEN_INT | 3.3V |
| P122 | SPK_CTL | 3.3V | S122 | SPI2_MISO | 3.3V |
| P123 | FLASH_EN | 3.3V | S123 | SPI2_CLK | 3.3V |
| P124 | UART3_RTS | 3.3V | S124 | SPI2_nCS0 | 3.3V |
| P125 | EDP_HPD | 3.3V | S125 | SPI2_MOSI | 3.3V |
| P126 | UART3_RX | 3.3V | S126 | JTAG_TCK | 3.3V |
| P127 | BL_EN | 3.3V | S127 | JTAG_TDO | 3.3V |
| P128 | LED4 | 3.3V | S128 | JTAG_TDI | 3.3V |
| P129 | LED3 | 3.3V | S129 | JTAG_TMS | 3.3V |
| P130 | LED2 | 3.3V | S130 | nJTAG_TRST | 3.3V |
| P131 | LED1 | 3.3V | S131 | USB2UART_nRST | 3.3V |
| P132 | KEY_VOL_N | 3.3V | S132 | OTG_ID | 3.3V |
| P133 | KEY_VOL_P | 3.3V | S133 | OTG_DET | 3.3V |
| P134 | I2C5_SDA | 3.3V | S134 | GND | 0V |
| P135 | I2C5_SCL | 3.3V | S135 | HOST1_DP | 5V |
| P136 | I2C4_SDA | 3.3V | S136 | HOST1_DM | 5V |
| P137 | I2C4_SCL | 3.3V | S137 | GND | 0V |
| P138 | PWR_KEY | 5V | S138 | HOST2_DP | 5V |
| P139 | RESET_KEY | 5V | S139 | HOST2_DM | 5V |
| P140 | PMIC_PWRON | 5V | S140 | GND | 0V |
| P141 | OTP_RESET | 3.3V | S141 | OTG_DP | 5V |
| P142 | HSIC_STROBE | 1.0V | S142 | OTG_DM | 5V |
| P143 | HSIC_DATA | 1.0V | S143 | GND | |
| P144 | RTC_CLKOUT2 | 32.768KHz | S144 | VCC_EFUSE | 3.0V |
| P145 | GND | 0V | S145 | VCCA_33 | 3.3V |
| P146 | GND | 0V | S146 | VCC18_DVP | 1.8V |
| P147 | GND | 0V | S147 | VCC28_DVP | 2.8V |
| P148 | GND | 0V | S148 | RTC_PWRIN | 3.4V |
| P149 | GND | 0V | S149 | VCC_18 | 1.8V |
| P150 | GND | 0V | S150 | VCC_IO | 3.3V |
| P151 | GND | 0V | S151 | VCC_IO | 3.3V |
| P152 | GND | 0V | S152 | 5VIN | 5V |
| P153 | GND | 0V | S153 | 5VIN | 5V |
| P154 | GND | 0V | S154 | 5VIN | 5V |
| P155 | GND | 0V | S155 | 5VIN | 5V |
| P156 | GND | 0V | S156 | 5VIN | 5V |
| S157 | 5VIN | 5V | |||
| S158 | 5VIN | 5V |
| Pin NO. | Pin Name | CPU Ball Name | 功能描述 (functional description) | 管脚电压 (Pin voltage) |
| P1 | 5V_CORE | —— | —— | 5V(input) |
| P2 | ||||
| P3 | ||||
| P4 | ||||
| P5 | ||||
| P6 | GND | —— | —— | —— |
| P7 | ||||
| P8 | ||||
| P9 | ||||
| P10 | ||||
| P11 | CSI_P1_DP3 | D21 | MIPI_CSI1_D3_P | 1.8V |
| P12 | CSI_P1_DN3 | C21 | MIPI_CSI1_D3_N | |
| P13 | GND | —— | —— | —— |
| P14 | CSI_P1_DP1 | D22 | MIPI_CSI1_D1_P | 1.8V |
| P15 | CSI_P1_DN1 | C22 | MIPI_CSI1_D1_N | |
| P16 | GND | —— | —— | —— |
| P17 | CSI_P1_DP2 | C23 | MIPI_CSI1_D2_P | 1.8V |
| P18 | CSI_P1_DN2 | B24 | MIPI_CSI1_D2_N | |
| P19 | GND | —— | —— | —— |
| P20 | CSI_P1_DP0 | B23 | MIPI_CSI1_D0_P | 1.8V |
| P21 | CSI_P1_DN0 | A23 | MIPI_CSI1_D0_N | |
| P22 | GND | —— | —— | —— |
| P23 | CSI_P1_CKP | B22 | MIPI_CSI1_CLK_P | 1.8V |
| P24 | CSI_P1_CKN | A22 | MIPI_CSI1_CLK_N | |
| P25 | GND | —— | —— | —— |
| P26 | CSI_P2_DP2 | B21 | MIPI_CSI2_D2_P | 1.8V |
| P27 | CSI_P2_DN2 | A21 | MIPI_CSI2_D2_N | |
| P28 | GND | —— | —— | —— |
| P29 | CSI_P2_DP1 | B20 | MIPI_CSI2_D1_P | 1.8V |
| P30 | CSI_P2_DN1 | A20 | MIPI_CSI2_D1_N | |
| P31 | GND | —— | —— | —— |
| P32 | CSI_P2_CKP | B19 | MIPI_CSI2_CLK_P | 1.8V |
| P33 | CSI_P2_CKN | A19 | MIPI_CSI2_CLK_N | |
| P34 | GND | —— | —— | —— |
| P35 | CSI_P2_DN3 | C19 | MIPI_CSI2_D3_N | 1.8V |
| P36 | CSI_P2_DP3 | D19 | MIPI_CSI2_D3_P | |
| P37 | GND | —— | —— | —— |
| P38 | CSI_P2_DP0 | D20 | MIPI_CSI2_D0_P | 1.8V |
| P39 | CSI_P2_DN0 | C20 | MIPI_CSI2_D0_N | |
| P40 | GND | —— | —— | —— |
| P41 | ||||
| P42 | ||||
| P43 | UART3_CTS | B4 | ECSPI1_MISO | 3.3V |
| UART3_CTS_B | ||||
| GPIO5_IO08 | ||||
| P44 | UART3_RTS | D4 | ECSPI1_SS0 | 3.3V |
| UART3_RTS_B | ||||
| GPIO5_IO09 | ||||
| P45 | UART3_TXD | B7 | UART3_TXD | 3.3V |
| UART1_RTS_B | ||||
| GPIO5_IO27 | ||||
| P46 | UART3_RXD | A6 | UART3_RX | 3.3V |
| UART1_CTS_B | ||||
| GPIO5_IO26 | ||||
| P47 | UART2_TXD | D6 | UART2_TX | 3.3V |
| ECSPI3_SS0 | ||||
| GPIO5_IO25 | ||||
| P48 | UART2_RXD | B6 | UART2_RX | 3.3V |
| ECSPI3_MISO | ||||
| GPIO5_IO24 | ||||
| P49 | UART1_TXD | D6 | UART1_TX | 3.3V |
| ECSPI3_MOSI | ||||
| GPIO5_IO23 | ||||
| P50 | UART1_RXD | C7 | UART1_RX | 3.3V |
| ECSPI3_SCLK | ||||
| GPIO5_IO22 | ||||
| P51 | GND | —— | —— | —— |
| P52 | SPDIF_EXT_CLK | E6 | SPDIF1_EXT_CLK | 3.3V |
| PWM1_OUT | ||||
| GPIO5_IO05 | ||||
| P53 | GND | —— | —— | —— |
| P54 | SPDIF_EXT_TX | F6 | SPDIF1_OUT | 3.3V |
| PWM3_OUT | ||||
| GPIO5_IO03 | ||||
| P55 | SPDIF_RX | G6 | SPDIF1_IN | 3.3V |
| PWM2_OUT | ||||
| GPIO5_IO04 | ||||
| P56 | GND | —— | —— | —— |
| P57 | SAI1_MCLK | A3 | SAI1_MCLK | 3.3V |
| SAI5_MCLK | ||||
| SAI1_TX_BCLK | ||||
| GPIO4_IO20 | ||||
| P58 | GND | —— | —— | —— |
| P59 | SAI1_TXD6 | B3 | SAI1_TX_DATA6 | 3.3V |
| SAI6_RX_SYNC | ||||
| SAI6_TX_SYNC | ||||
| CORESIGHT_TRACE14 | ||||
| GPIO4_IO18 | ||||
| SRC_BOOT_CFG14 | ||||
| P60 | SAI1_TXD2 | B2 | SAI1_TX_DATA3 | 3.3V |
| SAI5_TX_DATA3 | ||||
| CORESIGHT_TRACE11 | ||||
| GPIO4_IO15 | ||||
| SRC_BOOT_CFG11 | ||||
| P61 | SAI1_TXD5 | C2 | SAI1_TX_DATA5 | 3.3V |
| SAI6_RX_DATA0 | ||||
| SAI6_TX_DATA0 | ||||
| CORESIGHT_TRACE13 | ||||
| GPIO4_IO17 | ||||
| SRC_BOOT_CFG13 | ||||
| P62 | SAI1_TXD7 | C1 | SAI1_TX_DATA7 | 3.3V |
| SAI6_MCLK | ||||
| CORESIGHT_TRACE15 | ||||
| GPIO4_IO19 | ||||
| SRC_BOOT_CFG15 | ||||
| P63 | SAI1_TXD4 | D2 | SAI1_TX_DATA4 | 3.3V |
| SAI6_RX_BCLK | ||||
| SAI6_TX_BCLK | ||||
| CORESIGHT_TRACE12 | ||||
| GPIO4_IO16 | ||||
| SRC_BOOT_CFG12 | ||||
| P64 | SAI1_TXD3 | D1 | SAI1_TX_DATA3 | 3.3V |
| GPIO4_IO15 | ||||
| P65 | SAI1_TXD1 | E2 | SAI1_TX_DATA1 | 3.3V |
| SAI5_TX_DATA1 | ||||
| CORESIGHT_TRACE9 | ||||
| GPIO4_IO13 | ||||
| SRC_BOOT_CFG9 | ||||
| P66 | SAI1_TXC | E1 | SAI1_TX_BCLK | 3.3V |
| SAI5_TX_BCLK | ||||
| CORESIGHT_EVENTI | ||||
| GPIO4_IO11 | ||||
| P67 | SAI1_TXD0 | F2 | SAI1_TX_DATA0 | 3.3V |
| SAI5_TX_DATA0 | ||||
| CORESIGHT_TRACE8 | ||||
| GPIO4_IO12 | ||||
| SRC_BOOT_CFG8 | ||||
| P68 | SAI1_RXD5 | F1 | SAI1_RX_DATA5 | 3.3V |
| SAI1_RX_SYNC | ||||
| CORESIGHT_TRACE5 | ||||
| GPIO4_IO07 | ||||
| SRC_BOOT_CFG5 | ||||
| P69 | SAI1_RXD6 | G2 | SAI1_RX_DATA6 | 3.3V |
| SAI6_TX_SYNC | ||||
| SAI6_RX_SYNC | ||||
| CORESIGHT_TRACE6 | ||||
| GPIO4_IO08 | ||||
| SRC_BOOT_CFG6 | ||||
| P70 | SAI1_RXD7 | G1 | SAI1_RX_DATA7 | 3.3V |
| SAI6_MCLK | ||||
| SAI1_TX_SYNC | ||||
| SAI1_TX_DATA4 | ||||
| CORESIGHT_TRACE7 | ||||
| GPIO4_IO09 | ||||
| SRC_BOOT_CFG7 | ||||
| P71 | SAI1_RXD2 | H2 | SAI1_RX_DATA2 | 3.3V |
| SAI5_RX_DATA2 | ||||
| GPIO4_IO04 | ||||
| SRC_BOOT_CFG2 | ||||
| P72 | SAI1_TXFS | H1 | SAI1_TX_SYNC | 3.3V |
| SAI5_TX_SYNC | ||||
| CORESIGHT_EVENTO | ||||
| GPIO4_IO10 | ||||
| P73 | SAI1_RXD3 | J2 | SAI1_RX_DATA3 | 3.3V |
| SAI5_RX_DATA3 | ||||
| CORESIGHT_TRACE3 | ||||
| GPIO4_IO05 | ||||
| SRC_BOOT_CFG3 | ||||
| P74 | GND | —— | —— | —— |
| P75 | ||||
| P76 | SAI1_RXD4 | G2 | SAI1_RX_DATA4 | 3.3V |
| SAI6_TX_BCLK | ||||
| SAI6_RX_BCLK | ||||
| CORESIGHT_TRACE4 | ||||
| GPIO4_IO06 | ||||
| SRC_BOOT_CFG4 | ||||
| P77 | SAI1_RXD0 | K2 | SAI1_RX_DATA0 | 3.3V |
| SAI5_RX_DATA0 | ||||
| CORESIGHT_TRACE0 | ||||
| GPIO4_IO00 | ||||
| SRC_BOOT_CFG0 | ||||
| P78 | SAI1_RXC | K1 | SAI1_RX_BCLK | 3.3V |
| SAI5_RX_BCLK | ||||
| CORESIGHT_TRACE_CTL | ||||
| GPIO4_IO01 | ||||
| P79 | SAI1_RXD1 | L2 | SAI1_RX_DATA1 | 3.3V |
| SAI5_RX_DATA1 | ||||
| CORESIGHT_TRACE1 | ||||
| GPIO4_IO03 | ||||
| SRC_BOOT_CFG1 | ||||
| P80 | SAI1_RXFS | L1 | SAI1_RX_SYNC | 3.3V |
| SAI5_RX_SYNC | ||||
| CORESIGHT_TRACE_CLK | ||||
| GPIO4_IO00 | ||||
| P81 | GND | —— | —— | —— |
| P82 | HDMI_DDC_SDA | P3 | HDMI_DDC_SDA | 1.8V |
| P83 | HDMI_DDC_SCL | P3 | HDMI_DDC_SCL | |
| P84 | GND | —— | —— | —— |
| P85 | HDMI_CLKN | M2 | HDMI_TX_N_LN_3 | 1.8V |
| P86 | HDMI_CLKP | M1 | HDMI_TX_P_LN_3 | |
| P87 | GND | —— | —— | —— |
| P88 | HDMI_TXN2 | N1 | HDMI_TX_N_LN_2 | 1.8V |
| P89 | HDMI_TXP2 | N2 | HDMI_TX_P_LN_2 | |
| P90 | GND | —— | —— | —— |
| P91 | HDMI_TXN0 | T2 | HDMI_TX_N_LN_0 | 1.8V |
| P92 | HDMI_TXP0 | T1 | HDMI_TX_P_LN_0 | |
| P93 | GND | —— | —— | —— |
| P94 | HDMI_TXP1 | U2 | HDMI_TX_P_LN_1 | 1.8V |
| P95 | HDMI_TXN1 | U1 | HDMI_TX_N_LN_1 | |
| P96 | GND | —— | —— | —— |
| P97 | HDMI_AUXN | V2 | HDMI_AUX_N | 1.8V |
| P98 | HDMI_TXN1 | V1 | HDMI_AUX_P | |
| P99 | GND | —— | —— | —— |
| P100 | HDMI_HPD | W2 | HDMI_HPD | 1.8V |
| P101 | GND | —— | —— | —— |
| P102 | HDMI_CEC | W3 | HDMI_CEC | 1.8V |
| P103 | JTAG_NTRST | U6 | JTAG_TRST_B | 3.3V |
| P104 | JTAG_TDO | U5 | JTAG_TDO | 3.3V |
| P105 | JTAG_TCK | T5 | JTAG_TCK | 3.3V |
| P106 | JTAG_TMS | V5 | JTAG_TMS | 3.3V |
| P107 | JTAG_TDI | W5 | JTAG_TDI | 3.3V |
| P108 | I2C2_SDA | F7 | I2C2_SDA | 3.3V |
| ENET1_1588_EVENT1_OUT | ||||
| GPIO5_IO17 | ||||
| P109 | I2C2_SCL | G7 | I2C2_SCL | 3.3V |
| ENET1_1588_EVENT1_IN | ||||
| GPIO5_IO16 | ||||
| P110 | I2C1_SDA | E8 | I2C1_SDA | 3.3V |
| ENET1_MDIO | ||||
| GPIO5_IO15 | ||||
| P111 | I2C1_SCL | E7 | I2C1_SCL | 3.3V |
| ENET1_MDC | ||||
| GPIO5_IO14 | ||||
| P112 | I2C3_SCL | G8 | I2C3_SCL | 3.3V |
| PWM4_OUT | ||||
| GPT2_CLK | ||||
| GPIO5_IO18 | ||||
| P113 | I2C3_SDA | E9 | I2C3_SDA | 3.3V |
| PWM3_OUT | ||||
| GPT3_CLK | ||||
| GPIO5_IO19 | ||||
| P114 | GND | —— | —— | —— |
| P115 | WL_REG_ON | D7 | UART4_TX | 3.3V |
| UART2_RTS_B | ||||
| PCIE2_CLKREQ_B | ||||
| GPIO5_IO29 | ||||
| P116 | WL_NPERST | C6 | UART4_RX | 3.3V |
| UART2_CTS_B | ||||
| PCIE1_CLKREQ_B | ||||
| GPIO5_IO28 | ||||
| P117 | WIFI_PCIE_NCLKREQ | —— | —— | —— |
| P118 | PCIE1_NCLKREQ | F8 | I2C4_SCL | 3.3V |
| PWM2_OUT | ||||
| GPIO5_IO20 | ||||
| P119 | PCIE2_NCLKREQ | F9 | I2C4_SDA | 3.3V |
| PWM1_OUT | ||||
| GPIO5_IO21 | ||||
| P120 | PCIE_NCLKREQ | —— | —— | —— |
| P121 | GND | —— | —— | —— |
| P122 | PCIE2_RXP | D25 | PCIE2_RXN_P | 3.3V |
| P123 | PCIE2_RXN | D24 | PCIE2_RXN_N | |
| P124 | GND | —— | —— | —— |
| P125 | PCIE2_REF_CLKN_CN | F24 | PCIE2_REF_PAD_CLK_N | 3.3V |
| P126 | PCIE2_REF_CLKP_CN | F25 | PCIE2_REF_PAD_CLK_P | |
| P127 | GND | —— | —— | —— |
| P128 | PCIE2_TXP | E25 | PCIE2_TXN_P | 3.3V |
| P129 | PCIE2_TXN | E24 | PCIE2_TXN_N | |
| P130 | GND | —— | —— | —— |
| P131 | ||||
| P132 | ||||
| P133 | ||||
| P134 | PCIE1_RXN | H24 | PCIE1_RXN_N | 3.3V |
| P135 | PCIE1_RXP | H25 | PCIE1_RXN_P | |
| P136 | GND | —— | —— | —— |
| P137 | PCIE1_TXN | J24 | PCIE1_TXN_N | 3.3V |
| P138 | PCIE1_TXP | J25 | PCIE1_TXN_P | |
| P139 | GND | —— | —— | —— |
| P140 | WIFI_PCIE_CLKN | —— | —— | —— |
| P141 | WIFI_PCIE_CLKP | —— | —— | —— |
| P142 | GND | —— | —— | —— |
| P143 | ||||
| P144 | ||||
| P145 | ||||
| P146 | CLK1_P | R23 | CLK1_P | 1.8V(input) |
| P147 | CLK1_N | T23 | CLK1_N | |
| P148 | GND | —— | —— | —— |
| P149 | POR_B | W20 | SRC_POR_B | 3.3V |
| P150 | WL_NWAKE | M20 | RAWNAND_DQS | 3.3V |
| QSPI_A_DQS | ||||
| GPIO3_IO14 | ||||
| P151 | WIFI_PCIE_CLKP | —— | —— | —— |
| P152 | PMIC_STBY_REQ | V21 | CCM_PMIC_STBY_REQ | 3.3V |
| P153 | ONOFF | W21 | XTALOSC_ONOFF | 3.3V |
| P154 | BOOT_MODE1 | V6 | SRC_BOOT_MODE1 | 3.3V |
| P155 | BOOT_MODE0 | W6 | SRC_BOOT_MODE0 | 3.3V |
| P156 | GND | —— | —— | —— |
| S1 | 5V_CORE | —— | —— | 5V(input) |
| S2 | ||||
| S3 | ||||
| S4 | ||||
| S5 | ||||
| S6 | GND | —— | —— | —— |
| S7 | ||||
| S8 | ||||
| S9 | ||||
| S10 | ||||
| S11 | VDD_PHY_3V3 | —— | —— | 3.3V(input) |
| S12 | ||||
| S13 | VDD_PHY_1V8 | —— | —— | 1.8V(input) |
| S14 | GND | —— | —— | —— |
| S15 | ||||
| S16 | ||||
| S17 | DSI_DN2 | A18 | MIPI_DSI_D2_N | 1.8V |
| S18 | DSI_DP2 | B18 | MIPI_DSI_D2_P | |
| S19 | GND | —— | —— | —— |
| S20 | DSI_DN0 | A17 | MIPI_DSI_D0_N | 1.8V |
| S21 | DSI_DP0 | B17 | MIPI_DSI_D0_P | |
| S22 | GND | —— | —— | —— |
| S23 | DSI_DN1 | A16 | MIPI_DSI_D1_N | 1.8V |
| S24 | DSI_DP1 | B16 | MIPI_DSI_D1_P | |
| S25 | GND | —— | —— | —— |
| S26 | DSI_DN3 | A15 | MIPI_DSI_D3_N | 1.8V |
| S27 | DSI_DP3 | B15 | MIPI_DSI_D3_P | |
| S28 | GND | —— | —— | —— |
| S29 | DSI_CKP | D16 | MIPI_DSI_CLK_P | 1.8V |
| S30 | DSI_CKN | C16 | MIPI_DSI_CLK_N | |
| S31 | GND | —— | —— | —— |
| S32 | USB1_ID | C16 | USB1_ID | 3.3V |
| S33 | USB1_DN | B14 | USB1_DN | 3.3V |
| S34 | USB1_DP | A14 | USB1_DP | 3.3V |
| S35 | USB1_VBUS | D14 | USB1_VBUS | 3.3V |
| S36 | GND | —— | —— | —— |
| S37 | USB1_TXN | B13 | USB1_TXN | 3.3V |
| S38 | USB1_TXP | A13 | USB1_TXP | |
| S39 | GND | —— | —— | —— |
| S40 | USB1_RXN | B12 | USB1_RXN | 3.3V |
| S41 | USB1_RXP | A12 | USB1_RXP | |
| S42 | GND | —— | —— | —— |
| S43 | USB2_ID | C9 | USB2_ID | 3.3V |
| S44 | USB2_DN | B10 | USB2_DN | |
| S45 | USB2_DP | A10 | USB2_DP | 3.3V |
| S46 | USB2_VBUS | D9 | USB2_VBUS | |
| S47 | GND | —— | —— | —— |
| S48 | USB2_TXN | B9 | USB2_TXN | 3.3V |
| S49 | USB2_TXP | A9 | USB2_TXP | |
| S50 | GND | —— | —— | —— |
| S51 | USB2_RXN | B8 | USB2_RXN | 3.3V |
| S52 | USB2_RXP | A8 | USB2_RXP | |
| S53 | GND | —— | —— | —— |
| S54 | USB1_SS_SEL | K19 | RAWNAND_RE_B | 3.3V |
| QSPI_B_DQS | ||||
| GPIO3_IO15 | ||||
| S55 | DSI_EN | D5 | ECSPI1_SCLK | 3.3V |
| UART3_RX | ||||
| GPIO5_IO06 | ||||
| S56 | PCIE_NDIS | C5 | ECSPI2_SCLK | 3.3V |
| UART4_RX | ||||
| GPIO5_IO10 | ||||
| S57 | PCIE_NWAKE | E5 | ECSPI2_MOSI | 3.3V |
| UART4_TX | ||||
| GPIO5_IO11 | ||||
| S58 | BT_RF_KILL | A5 | ECSPI2_SS0 | 3.3V |
| UART4_RTS_B | ||||
| GPIO5_IO13 | ||||
| S59 | PCIE_NRST | B5 | ECSPI2_MISO | 3.3V |
| UART4_CTS_B | ||||
| GPIO5_IO12 | ||||
| S60 | DSI_TS_NINT | A4 | ECSPI1_MISO | 3.3V |
| UART3_TX | ||||
| GPIO5_IO07 | ||||
| S61 | GND | —— | —— | —— |
| S62 | SAI2_RXD | H6 | SAI2_RX_DATA0 | 3.3V |
| GPIO4_IO23 | ||||
| S63 | SAI2_TXD | G5 | SAI2_TX_DATA0 | 3.3V |
| GPIO4_IO26 | ||||
| S64 | SAI2_RXC | H3 | SAI2_RX_BCLK | 3.3V |
| SAI5_TX_BCLK | ||||
| GPIO4_IO22 | ||||
| S65 | SAI2_MCLK | H5 | SAI2_MCLK | 3.3V |
| SAI5_MCLK | ||||
| GPIO4_IO27 | ||||
| S66 | GND | —— | —— | —— |
| S67 | SAI2_RXFS | J4 | SAI2_RX_SYNC | 3.3V |
| SAI5_TX_SYNC | ||||
| GPIO4_IO21 | ||||
| S68 | SAI2_TXC | J5 | SAI2_TX_BCLK | 3.3V |
| SAI5_TX_DATA2 | ||||
| GPIO4_IO25 | ||||
| S69 | SAI2_TXFS | H4 | SAI2_TX_SYNC | 3.3V |
| GPIO4_IO24 | ||||
| S70 | GND | —— | —— | —— |
| S71 | SAI3_RXFS | G4 | SAI3_RX_SYNC | 3.3V |
| GPT1_CAPTURE1 | ||||
| SAI5_RX_SYNC | ||||
| GPIO4_IO28 | ||||
| S72 | SAI3_RXD | F3 | SAI3_RX_DATA0 | 3.3V |
| GPT1_COMPARE1 | ||||
| GPIO4_IO30 | ||||
| S73 | SAI3_RXC | F4 | SAI3_RX_BCLK | 3.3V |
| GPT1_CAPTURE2 | ||||
| SAI5_RX_BCLK | ||||
| GPIO4_IO29 | ||||
| S74 | SAI3_TXD | C3 | SAI3_TX_DATA0 | 3.3V |
| GPT1_COMPARE3 | ||||
| GPIO5_IO01 | ||||
| S75 | GND | —— | —— | —— |
| S76 | ||||
| S77 | SAI3_TXC | C4 | SAI3_TX_BCLK | 3.3V |
| GPT1_COMPARE2 | ||||
| GPIO5_IO00 | ||||
| S78 | SAI3_TXFS | G3 | SAI3_TX_SYNC | 3.3V |
| GPT1_CLK | ||||
| GPIO4_IO31 | ||||
| S79 | SAI3_MCLK | D3 | SAI3_MCLK | 3.3V |
| PWM4_OUT | ||||
| SAI5_MCLK | ||||
| GPIO5_IO02 | ||||
| S80 | GND | —— | —— | —— |
| S81 | SAI5_MCLK | K4 | SAI5_MCLK | 3.3V |
| SAI1_TX_BCLK | ||||
| SAI4_MCLK | ||||
| GPIO3_IO25 | ||||
| S82 | GND | —— | —— | —— |
| S83 | SAI5_RXD3 | K5 | SAI5_RX_DATA3 | 3.3V |
| SAI1_TX_DATA5 | ||||
| SAI1_TX_SYNC | ||||
| GPIO3_IO24 | ||||
| S84 | SAI5_RXD1 | L4 | SAI5_RX_DATA1 | 3.3V |
| SAI1_TX_DATA3 | ||||
| SAI1_TX_SYNC | ||||
| SAI5_TX_SYNC | ||||
| GPIO3_IO22 | ||||
| S85 | GND | —— | —— | —— |
| S86 | SAI5_RXC | L5 | SAI5_RX_BCLK | 3.3V |
| SAI1_TX_DATA1 | ||||
| GPIO3_IO20 | ||||
| S87 | GND | —— | —— | —— |
| S88 | SAI5_RXD2 | M4 | SAI5_RX_DATA2 | 3.3V |
| SAI1_TX_SYNC | ||||
| SAI5_TX_BCLK | ||||
| GPIO3_IO23 | ||||
| S89 | SAI5_RXD0 | M5 | SAI5_RX_DATA0 | 3.3V |
| SAI1_TX_DATA2 | ||||
| GPIO3_IO21 | ||||
| S90 | SAI5_RXFS | N4 | SAI5_RX_SYNC | 3.3V |
| SAI1_TX_DATA0 | ||||
| GPIO3_IO19 | ||||
| S91 | GND | —— | —— | —— |
| S92 | ||||
| S93 | NWDOG | R4 | GPIO1_IO02 | 3.3V |
| WDOG1_WDOG_B | ||||
| WDOG1_WDOG_ANY | ||||
| S94 | DSI_BL_PWM | T7 | GPIO1_IO01 | 3.3V |
| PWM1_OUT | ||||
| ANAMIX_REF_CLK_24M | ||||
| CCM_EXT_CLK2 | ||||
| S95 | REF_CLK_32K | T6 | GPIO1_IO00 | 3.3V |
| CCM_ENET_PHY_REF_CLK_ROOT | ||||
| ANAMIX_REF_CLK_32K | ||||
| CCM_EXT_CLK1 | ||||
| S96 | GND | —— | —— | —— |
| S97 | CLKO_25MHZ | K7 | GPIO1_IO14 | 3.3V |
| USB2_OTG_PW | ||||
| PWM3_OUT | ||||
| CCM_CLKO1 | ||||
| S98 | CLKO2 | J6 | GPIO1_IO15 | 3.3V |
| USB2_OTG_OC | ||||
| PWM4_OUT | ||||
| CCM_CLKO2 | ||||
| S99 | ENET_WOL | K7 | GPIO1_IO10 | 3.3V |
| USB1_OTG_ID | ||||
| S100 | AUD_NMUTE | N7 | GPIO1_IO08 | 3.3V |
| ENET1_1588_EVENT0_IN | ||||
| USDHC2_RESET_B | ||||
| S101 | PWM_LED | K6 | GPIO1_IO13 | 3.3V |
| USB1_OTG_OC | ||||
| PWM2_OUT | ||||
| S102 | ENET_NINT | L6 | GPIO1_IO11 | 3.3V |
| USB2_OTG_ID | ||||
| CCM_PMIC_READY | ||||
| S103 | ENET_NRST | M6 | GPIO1_IO09 | 3.3V |
| ENET1_1588_EVENT0_OUT | ||||
| SDMA2_EXT_EVENT0 | ||||
| S104 | IR_CAP | L7 | GPIO1_IO12 | 3.3V |
| USB1_OTG_PWR | ||||
| SDMA2_EXT_EVENT1 | ||||
| S105 | CSI_P1_PWDN | P4 | GPIO1_IO03 | 3.3V |
| USDHC1_VSELECT | ||||
| SDMA1_EXT_EVENT0 | ||||
| S106 | CSI_NRST | N5 | GPIO1_IO06 | 3.3V |
| ENET1_MDC | ||||
| USDHC1_CD_B | ||||
| CCM_EXT_CLK3 | ||||
| S107 | CSI_P2_PWDN | P7 | GPIO1_IO05 | 3.3V |
| M4_NMI | ||||
| S108 | SD2_VSELECT | P5 | GPIO1_IO04 | 3.3V |
| USDHC2_VSELECT | ||||
| SDMA1_EXT_EVENT1 | ||||
| S109 | GND | —— | —— | —— |
| S110 | ENET_RD0 | U19 | ENET1_RGMII_RD0 | 2.5V |
| GPIO1_IO26 | ||||
| S111 | ENET_RD0 | U21 | ENET1_RGMII_RD0 | 2.5V |
| GPIO1_IO27 | ||||
| S112 | ENET_RX_CTL | T21 | ENET1_RGMII_RX_CTL | 2.5V |
| GPIO1_IO24 | ||||
| S113 | ENET_RD2 | U20 | ENET1_RGMII_RD2 | 2.5V |
| GPIO1_IO28 | ||||
| S114 | ENET_RD3 | V19 | ENET1_RGMII_RD3 | 2.5V |
| GPIO1_IO29 | ||||
| S115 | ENET_RXC | T20 | ENET1_RGMII_RXC | 2.5V |
| ENET1_RX_ER | ||||
| GPIO1_IO25 | ||||
| S116 | GND | —— | —— | —— |
| S117 | ENET_TD1 | R21 | ENET1_RGMII_TD1 | 2.5V |
| GPIO1_IO20 | ||||
| S118 | ENET_TD0 | R20 | ENET1_RGMII_TD0 | 2.5V |
| GPIO1_IO21 | ||||
| S119 | ENET_TD3 | P20 | ENET1_RGMII_TD3 | 2.5V |
| GPIO1_IO18 | ||||
| S120 | ENET_TXC | T19 | ENET1_RGMII_TXC | 2.5V |
| ENET1_TX_ER | ||||
| GPIO1_IO23 | ||||
| S121 | ENET_TD2 | R19 | ENET1_RGMII_TD2 | 2.5V |
| ENET1_TX_CLK | ||||
| GPIO1_IO19 | ||||
| S122 | ENET_TX_CTL | P19 | ENET1_RGMII_TX_CTL | 2.5V |
| GPIO1_IO22 | ||||
| S123 | GND | —— | —— | —— |
| S124 | ENET_MDIO | N19 | ENET1_MDIO | 2.5V |
| GPIO1_IO17 | ||||
| S125 | ENET_MDC | N20 | ENET1_MDC | 2.5V |
| GPIO1_IO16 | ||||
| S126 | GND | —— | —— | —— |
| S127 | SDIO_WAKE | M21 | USDHC2_WP | 3.3V |
| GPIO2_IO20 | ||||
| S128 | SD2_DATA2 | P22 | USDHC2_DATA2 | 3.3V |
| GPIO2_IO17 | ||||
| S129 | SD2_NRST | R22 | USDHC2_RESET_B | 3.3V |
| GPIO2_IO1 | ||||
| S130 | SD2_DATA1 | N21 | USDHC2_DATA1 | 3.3V |
| GPIO2_IO16 | ||||
| S131 | SD2_DATA0 | N22 | USDHC2_DATA0 | 3.3V |
| GPIO2_IO15 | ||||
| S132 | SD2_CMD | M22 | USDHC2_CMD | 3.3V |
| GPIO2_IO14 | ||||
| S133 | SD2_DATA3 | P21 | USDHC2_DATA3 | 3.3V |
| GPIO2_IO18 | ||||
| S134 | SD2_NCD | L21 | USDHC2_CD_B | 3.3V |
| GPIO2_IO12 | ||||
| S135 | GND | —— | —— | —— |
| S136 | SD2_CLK | L22 | USDHC2_CLK | 3.3V |
| GPIO2_IO13 | ||||
| S137 | GND | —— | —— | —— |
| S138 | ||||
| S139 | QSPIA_NSS0 | H19 | RAWNAND_CE0_B | 3.3V |
| QSPI_A_SS0_B | ||||
| GPIO3_IO01 | ||||
| S140 | NAND_DATA3 | J21 | RAWNAND_DATA03 | 3.3V |
| QSPI_A_DATA3 | ||||
| GPIO3_IO09 | ||||
| S141 | NAND_DATA1 | J20 | RAWNAND_DATA01 | 3.3V |
| QSPI_A_DATA1 | ||||
| GPIO3_IO07 | ||||
| S142 | NAND_DATA2 | H22 | RAWNAND_DATA02 | 3.3V |
| QSPI_A_DATA2 | ||||
| GPIO3_IO08 | ||||
| S143 | GND | —— | —— | —— |
| S144 | QSPIA_SCLK | G19 | RAWNAND_ALE | 3.3V |
| QSPI_A_SCLK | ||||
| GPIO3_IO00 | ||||
| S145 | GND | —— | —— | —— |
| S146 | NAND_DATA0 | G20 | RAWNAND_DATA00 | 3.3V |
| QSPI_A_DATA0 | ||||
| GPIO3_IO06 | ||||
| S147 | NAND_NREADY | K20 | RAWNAND_READY_B | 3.3V |
| GPIO3_IO16 | ||||
| S148 | NAND_DATA7 | M19 | RAWNAND_DATA07 | 3.3V |
| QSPI_B_DATA3 | ||||
| GPIO3_IO13 | ||||
| S149 | NAND_DATA4 | L20 | RAWNAND_DATA04 | 3.3V |
| QSPI_B_DATA0 | ||||
| GPIO3_IO10 | ||||
| S150 | NAND_NWP | K21 | RAWNAND_WP_B | 3.3V |
| GPIO3_IO18 | ||||
| S151 | NAND_DATA5 | J22 | RAWNAND_DATA05 | 3.3V |
| QSPI_B_DATA1 | ||||
| GPIO3_IO11 | ||||
| S152 | NAND_NWE | K22 | RAWNAND_WE_B | 3.3V |
| GPIO3_IO17 | ||||
| S153 | NAND_NCE3 | H20 | RAWNAND_CE3_B | 3.3V |
| QSPI_B_SS1_B | ||||
| GPIO3_IO04 | ||||
| S154 | BT_DEV_WAKE | G21 | RAWNAND_CE1_B | 3.3V |
| QSPI_A_SS1_B | ||||
| GPIO3_IO02 | ||||
| S155 | NAND_CLE | H21 | RAWNAND_CLE | 3.3V |
| QSPI_B_SCLK | ||||
| GPIO3_IO05 | ||||
| S156 | NAND_DATA6 | L19 | RAWNAND_DATA06 | 3.3V |
| QSPI_B_DATA2 | ||||
| GPIO3_IO12 | ||||
| S157 | TCPC_NINT | F21 | RAWNAND_CE2_B | 3.3V |
| QSPI_B_SS0_B | ||||
| GPIO3_IO03 | ||||
| S158 | GND | —— | —— | —— |
更多回帖
