TI论坛
直播中
曹玥
7年用户 224经验值
私信 关注
[问答]
请问DM368无法进入IE怎么办?
各位高手,本人使用RDK5.1,修改Sensor为OV2715后,编译内核及文件系统通过TFTP烧录后,不能进入IE且Camera不能ping通主机,主机可以ping通Camera,BNC也没有影像显示。启动信息如下:
DM36x initialization passed!
TI UBL Base Version: 1.50
Boot Loader BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000008.
Boot Mode Task Completed
IPNC UBL Version: 2.1.0
Platform: DM368-432
Jumping to entry point at 0x81080000
U-Boot 1.3.4 (Jan 29 2013 - 21:09:36) DM368-IPNC-4.1.0
I2C: ready
DRAM: 128 MB
NAND: NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Bad block table not found for chip 0
loop oob 81021ad8 Bad block table written to 0x07fe0000, version 0x01
loop oob 81021ad8 Bad block table written to 0x07fc0000, version 0x01
128 MiB
In: serial
Out: serial
Err: serial
ARM Clock :- 432MHz
DDR Clock :- 340MHz
Ethernet PHY: GENERIC @ 0x01
Hit any key to stop autoboot: 0
Loading from NAND 128MiB 3,3V 8-bit, offset 0x500000
Image Name: Linux-2.6.37_IPNC_DM368_5.1.0
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3711968 Bytes = 3.5 MB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Linux version 2.6.37_IPNC_DM368_5.1.0 (root@ubuntu) (gcc version 4.3.3 (GCC) ) #2 PREEMPT Thu Jun 12 22:34:39 PDT 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x IPNC
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 12192
[ 0.000000] Kernel command line: mem=48M console=ttyS1,115200n8 noinitrd ip=192.168.1.110 rw ubi.mtd=3,2048 rootfstype=ubifs root=ubi0:rootfs cmemk.phys_start=0x83000000 cmemk.phys_end=0x88000000 cmemk.phys_start_1=0x00001000 cmemk.phys_end_1=0x00008000 cmemk.pools_1=1x28672 cmemk.allowOverlap=1 cmemk.useHeapIfPoolUnavailable=1 nohz=off highres=off clocksource=acpi_pm lpj=1077248 eth=00:0C:0C:A0:07:DF
[ 0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: 00:0C:0C:A0:07:DF
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44916k/44916k available, 4236k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xc3800000 - 0xfea00000 ( 946 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3000000 ( 48 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc002a000 ( 136 kB)
[ 0.000000] .text : 0xc002a000 - 0xc036b000 (3332 kB)
[ 0.000000] .data : 0xc036c000 - 0xc03923e0 ( 153 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptable hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000299] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000356] pid_max: default: 32768 minimum: 301
[ 0.000584] Security Framework initialized
[ 0.000740] Mount-cache hash table entries: 512
[ 0.001592] CPU: Testing write buffer coherency: ok
[ 0.003333] devtmpfs: initialized
[ 0.006456] DaVinci: 8 gpio irqs
[ 0.007105] NET: Registered protocol family 16
[ 0.043289] dm365_rmd_cs_rdk_150_wl_init
[ 0.123546] bio: create slab at 0
[ 0.128456] SCSI subsystem initialized
[ 0.133185] u***core: registered new interface driver u***fs
[ 0.134554] u***core: registered new interface driver hub
[ 0.135487] u***core: registered new device driver u***
[ 0.138876] vpss vpss: dm365_vpss vpss probed
[ 0.138940] vpss vpss: dm365_vpss vpss probe success
[ 0.143241] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.146900] Switching to clocksource timer0_1
[ 0.231079] NET: Registered protocol family 2
[ 0.231389] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.232166] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.232307] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.232395] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.232427] TCP reno registered
[ 0.232466] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.232524] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.233033] NET: Registered protocol family 1
[ 0.302252] JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.305877] msgmni has been set to 87
[ 0.309960] io scheduler noop registered (default)
[ 0.311990] CSL: Module install successful, device major num = 254
[ 0.312036] CSL: Module version 0.10.00, built on Jun 11 2014 07:04:46
[ 0.312087] I2C: Module install successful, device major num = 253
[ 0.312127] DMA: Module install successful, device major num = 252
[ 0.312154] DRV: Module install successful
[ 0.312178] DRV: Module built on Jun 11 2014 07:04:49
[ 0.312204] DRV: EDMACC.QUEPRI = 00002777
[ 0.312227] DRV: SYSTEM.MSTPRI0 = 00440011
[ 0.312250] DRV: SYSTEM.MSTPRI1 = 00000444
[ 0.312272] DRV: ISP.BCR = 00000002
[ 0.312295] DRV: SYSTEM.MISC = 00000399
[ 0.312318] EDMAK module: built on Jun 11 2014 at 07:00:11
[ 0.312348] Reference Linux version 2.6.37
[ 0.312373] File /home/Dvsdk/DM365/rdk5.1/Release/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[ 0.314088] IRQK module: built on Jun 11 2014 at 06:56:57
[ 0.314139] Reference Linux version 2.6.37
[ 0.314166] File /home/Dvsdk/DM365/rdk5.1/Release/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 0.315887] irqk initialized
[ 0.317633] CMEMK module: built on Jun 11 2014 at 07:00:06
[ 0.317685] Reference Linux version 2.6.37
[ 0.317713] File /home/Dvsdk/DM365/rdk5.1/Release/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.322981] allocated heap buffer 0xc4000000 of size 0x5000000
[ 0.323023] heap fallback enabled - will try heap if pool buffer is not available
[ 0.323064] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 0.323098] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 0.323246] cmemk initialized
[ 0.323301] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.421388] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.481280] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 1.010287] console [ttyS1] enabled
[ 1.052986] brd: module loaded
[ 1.065544] NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung )
[ 1.074183] Bad block table not found for chip 0
[ 1.080395] Bad block table not found for chip 0
[ 1.085031] Scanning device for bad blocks
[ 1.196810] Creating 7 MTD partitions on "davinci_nand.0":
[ 1.202437] 0x000000000000-0x000000300000 : "bootloader"
[ 1.212684] 0x000000300000-0x000000500000 : "params"
[ 1.222686] 0x000000500000-0x000000900000 : "kernel"
[ 1.232822] 0x000000900000-0x000003100000 : "filesystem1"
[ 1.243651] 0x000003100000-0x000003900000 : "data1"
[ 1.253586] 0x000003900000-0x000006100000 : "filesystem2"
[ 1.264060] 0x000006100000-0x000008000000 : "data2"
[ 1.274141] davinci_nand davinci_nand.0: controller rev. 2.3
[ 1.283272] UBI: attaching mtd3 to ubi0
[ 1.287137] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.293726] UBI: logical eraseblock size: 126976 bytes
[ 1.299142] UBI: smallest flash I/O unit: 2048
[ 1.304031] UBI: sub-page size: 512
[ 1.308662] UBI: VID header offset: 2048 (aligned 2048)
[ 1.314779] UBI: data offset: 4096
[ 1.590471] UBI: max. sequence number: 11
[ 1.607841] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 2, need 3
[ 1.621026] UBI: attached mtd3 to ubi0
[ 1.624796] UBI: MTD device name: "filesystem1"
[ 1.630421] UBI: MTD device size: 40 MiB
[ 1.635313] UBI: number of good PEBs: 320
[ 1.639932] UBI: number of bad PEBs: 0
[ 1.644487] UBI: number of corrupted PEBs: 0
[ 1.648942] UBI: max. allowed volumes: 128
[ 1.653631] UBI: wear-leveling threshold: 4096
[ 1.658343] UBI: number of internal volumes: 1
[ 1.662849] UBI: number of user volumes: 1
[ 1.667299] UBI: available PEBs: 0
[ 1.671794] UBI: total number of reserved PEBs: 320
[ 1.676679] UBI: number of PEBs reserved for bad PEB handling: 2
[ 1.682738] UBI: max/mean erase counter: 2/0
[ 1.687017] UBI: image sequence number: 95924502
[ 1.691810] UBI: background thread "ubi_bgt0d" started, PID 419
[ 1.699940] spi_davinci spi_davinci.0: Controller at 0xfec66000
[ 1.760121] davinci_mdio davinci_mdio.0: davinci mdio revision 1.4
[ 1.766332] davinci_mdio davinci_mdio.0: detected phy mask fffffffd
[ 1.774239] davinci_mdio.0: probed
[ 1.777686] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
[ 1.786572] i2c /dev entries driver
[ 1.792640] Linux media interface: v0.10
[ 1.797351] Linux video capture interface: v2.00
[ 1.804377] vpbe-osd vpbe-osd: OSD sub device probe success
[ 1.811007] vpbe-venc vpbe-venc: VENC sub device probe success
[ 1.817881] vpbe-v4l2 vpbe-v4l2: vpbe v4l2 device registered
[ 1.823922] Setting default output to Composite
[ 1.828476] Setting default mode to ntsc
[ 1.832693] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[ 1.839410] vpbe-v4l2 vpbe-v4l2: layer=c28d6600,layer->video_dev=c28d66e8
[ 1.847339] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[ 1.854290] vpbe-v4l2 vpbe-v4l2: layer=c294fe00,layer->video_dev=c294fee8
[ 1.863192] watchdog watchdog: heartbeat 60 sec
[ 1.873896] Error: Driver 'davinci-mcbsp' is already registered, aborting...
[ 1.884186] asoc: cq93vc-hifi <-> davinci-vcif mapping ok
[ 1.894104] ALSA device list:
[ 1.897103] #0: DaVinci DM365 EVM
[ 1.902070] nf_conntrack version 0.5.0 (701 buckets, 2804 max)
[ 1.910293] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.915923] TCP cubic registered
[ 1.919211] NET: Registered protocol family 17
[ 1.991878] net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=181b8b0)
[ 2.060099] IP-Config: Guessing netmask 255.255.255.0
[ 2.065596] IP-Config: Complete:
[ 2.068674] device=eth0, addr=192.168.1.110, mask=255.255.255.0, gw=255.255.255.255,
[ 2.076902] host=192.168.1.110, domain=, nis-domain=(none),
[ 2.082978] bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
[ 2.147596] UBIFS: recovery needed
[ 2.198442] UBIFS: recovery completed
[ 2.202229] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2.208258] UBIFS: file system size: 38473728 bytes (37572 KiB, 36 MiB, 303 LEBs)
[ 2.215986] UBIFS: journal size: 5332992 bytes (5208 KiB, 5 MiB, 42 LEBs)
[ 2.223360] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 2.229203] UBIFS: default compressor: lzo
[ 2.233356] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.240251] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 2.249151] devtmpfs: mounted
[ 2.252395] Freeing init memory: 136K
INIT: version 2.86 booting
[ 2.842777] UBI: attaching mtd4 to ubi1
[ 2.846644] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 2.853025] UBI: logical eraseblock size: 126976 bytes
[ 2.858434] UBI: smallest flash I/O unit: 2048
[ 2.863212] UBI: sub-page size: 512
[ 2.867840] UBI: VID header offset: 2048 (aligned 2048)
[ 2.873905] UBI: data offset: 4096
[ 2.932578] UBI: max. sequence number: 20
[ 2.952177] UBI: attached mtd4 to ubi1
[ 2.955947] UBI: MTD device name: "data1"
[ 2.961050] UBI: MTD device size: 8 MiB
[ 2.965854] UBI: number of good PEBs: 64
[ 2.970507] UBI: number of bad PEBs: 0
[ 2.974963] UBI: number of corrupted PEBs: 0
[ 2.979410] UBI: max. allowed volumes: 128
[ 2.984091] UBI: wear-leveling threshold: 4096
[ 2.988802] UBI: number of internal volumes: 1
[ 2.993531] UBI: number of user volumes: 1
[ 2.997988] UBI: available PEBs: 0
[ 3.002510] UBI: total number of reserved PEBs: 64
[ 3.007312] UBI: number of PEBs reserved for bad PEB handling: 2
[ 3.013389] UBI: max/mean erase counter: 2/1
[ 3.017668] UBI: image sequence number: -176616394
[ 3.022636] UBI: background thread "ubi_bgt1d" started, PID 488
UBI device number 1, total 64 LEBs (8126464 bytes, 7.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 3.649786] UBIFS: recovery needed
[ 3.736226] UBIFS: recovery completed
[ 3.739923] UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 3.746558] UBIFS: file system size: 6221824 bytes (6076 KiB, 5 MiB, 49 LEBs)
[ 3.753944] UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
[ 3.761146] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 3.766988] UBIFS: default compressor: lzo
[ 3.771144] UBIFS: reserved for root: 293871 bytes (286 KiB)
[ 3.990427] PHY: 0:01 - Link is Up - 100/Full
mknod: /dev/spidev0.0: File exists
Starting mounting local filesystems: mount Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
queue id:32769
AlramThread created
Share memory init success
Creat queue id:65538
queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
mount: mounting /dev/root on / failed: No such file or directory
mount: mounting none on /dev/shm failed: No such file or directory
failed (2: ).
Check_device_version : DEVICE VER = 0 !!
CPU is DM368
IPNC BUILD VERSION: DM368 IPNC RDK V5.10.00.04
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
./av_server.out DM368 NTSC TI2A AEWB 720P H264 4000000 VBR AUTO MENUOFF &
sh: ./av_server.out: not found
ApproDrvInit: 7
Creat queue id:131076
queue id:131076
Starting internet superserver: inetd.
[ 4.954889] crc_ccitt: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/crc-ccitt.ko': -1 Invalid module format
[ 5.002593] crc32c: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/crc32c.ko': -1 Invalid module format
insmod: can't read '/opt/ipnc/modules/deflate.ko': No such file or directory
insmod: can't read '/opt/ipnc/modules/des_generic.ko': No such file or directory
insmod: can't read '/opt/ipnc/modules/md5.ko': No such file or directory
[ 5.058000] sha1_generic: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/sha1_generic.ko': -1 Invalid module format
[ 5.079072] libcrc32c: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/libcrc32c.ko': -1 Invalid module format
insmod: can't read '/opt/ipnc/modules/mmc_core.ko': No such file or directory
insmod: can't read '/opt/ipnc/modules/mmc_block.ko': No such file or directory
[ 5.125049] davinci_mmc: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/davinci_mmc.ko': -1 Invalid module format
[ 5.157370] scsi_transport_iscsi: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/scsi_transport_iscsi.ko': -1 Invalid module format
[ 5.192244] libiscsi: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/libiscsi.ko': -1 Invalid module format
[ 5.216905] libiscsi_tcp: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/libiscsi_tcp.ko': -1 Invalid module format
[ 5.240278] iscsi_tcp: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/iscsi_tcp.ko': -1 Invalid module format
[ 5.272950] mu***_hdrc: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/mu***_hdrc.ko': -1 Invalid module format
[ 5.296776] cppi_dma: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/cppi_dma.ko': -1 Invalid module format
[ 5.318184] davinci: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/davinci.ko': -1 Invalid module format
[ 5.345671] u***mon: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/u***mon.ko': -1 Invalid module format
[ 5.371019] loop: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/loop.ko': -1 Invalid module format
[ 5.395833] tun: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/tun.ko': -1 Invalid module format
[ 5.416239] slhc: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/slhc.ko': -1 Invalid module format
[ 5.437686] netconsole: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/netconsole.ko': -1 Invalid module format
[ 5.464806] ppp_generic: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/ppp_generic.ko': -1 Invalid module format
[ 5.485903] ppp_deflate: disagrees about version of symbol module_layout
insmod: error inserting '/opt/ipnc/modules/ppp_deflate.ko': -1 Invalid module format
mkdosfs 2.11 (12 Mar 2005)
unable to get drive geometry, using default 255/63/dev/ram0 has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 8192 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 6 sectors, and provides 2036 clusters.
Root directory contains 512 slots.
Volume ID is 00000006, no volume label.
queue id:0
TimeOut occure in boot_proc.
Program exit.
ApproDrvInit: 3
queue id:131076
INIT: Entering runlevel: 5/dev/pts failed: No such file or direc
Starting telnet daemon.
Starting syslogd/klogd: done
getty: ioctl() TIOCSPGR
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org 192.168.1.110 console
Arago 2009.11 192.168.1.110 console
192.168.1.110 login: root
-sh: can't access tty; job control turned off
root@192:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0C:0C:A0:07:DF
inet addr:192.168.1.110 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
TX packets:29 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:60 (60.0 B) TX bytes:5287 (5.1 KiB)
Interrupt:52 Base address:0x7000
eth0:3 Link encap:Ethernet HWaddr 00:0C:0C:A0:07:DF
inet addr:169.254.7.124 Bcast:169.254.255.255 Mask:255.255.0.0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
回帖(1)
赵鑫
2018-7-25 10:00:42
av_server.out not found
举报
更多回帖
