工程资源中心
直播中
颜婷
7年用户 198经验值
私信 关注
[电源设计]
PMP9166技术参考资料及物料清单下载
This reference design uses the TPS54218 in a synchronous buck-boost configuration to generate a negative 0.5V output from a 3.3V input. Switching at 1MHz, the total solution size is extremely compact. An external LM4040 reference provides a precision pull-up voltage and is necessary to regulate the  (...)
更多回帖
