单片机学习小组
直播中
白旭蕊
8年用户 201经验值
私信 关注
1602显示程序资料下载
#include
#include
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           无符号8位整型变量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  有符号8位整型变量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           无符号16位整型变量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           有符号16位整型变量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           无符号32位整型变量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           有符号32位整型变量 */
typedef float          F32;      /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         F64;      /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
***it LCD_RS = P0^7;
***it LCD_RW = P0^6;
***it LCD_EN = P0^5;
***it LED = P1^0;
#define Data P2
#define   Data_0_time    4
//独立按键接口 可自行修改
函数名称:delay();
函数功能:粗略延时
void delay1(U16 i)
         U16 j,k;
         for(j=i;j>0;j--)
         for(k=125;k>0;k--);
void DelayUs2x(U8 t)
         while(--t);
void DelayMs(U8 t)
     while(t--)
      //大致延时1mS
        DelayUs2x(245);
        DelayUs2x(245);
void Delay(U16 j)
          U8 i;
          for(;j>0;j--)
                 for(i=0;i<27;i++);
void  Delay_10us(void)
    U8 i;
    i--;
    i--;
    i--;
    i--;
    i--;
    i--;
函数名称:bit lcd_busy()
函数功能:检查LCD忙状态
输入值  :无
返回值  :
bit lcd_busy()
     bit result;
     LCD_RS = 0;
     LCD_EN = 1;
     delay1(1);
     result = (bit)(Data&0x80);
     LCD_EN = 0;
     return(result);
函数名称:void LCD1602_WriteCmd(unsigned char cmd)
函数功能:写指令数据到LCD
输入值  :指令
返回值  :无
     LCD_RS = 0;
     LCD_EN = 0;
     delay1(1);
     Data = cmd;
     delay1(5);
     LCD_EN = 1;
     delay1(5);
     LCD_EN = 0;
     delay1(10);
函数名称:void LCD1602_WriteData(unsigned char dat)
函数功能:写显示数据到LCD
输入值  :数据
返回值  :无
void LCD1602_WriteData(U8 dat)
     LCD_RS = 1;
     LCD_EN = 0;
     Data = dat;
     delay1(1);
     LCD_EN = 1;
     delay1(1);
     LCD_EN = 0;
     delay1(10);
函数名称:void lcd_init(void)
函数功能:LCD1602初始化函数
输入值  :无
返回值  :无
void lcd_init(void)
     LCD_RW = 0;
     delay1(15);
     LCD1602_WriteCmd(0x01);      //清除LCD的显示内容
     LCD1602_WriteCmd(0x38);      //16*2显示,5*7点阵,8位数据
     delay1(5);
     delay1(5);
     delay1(5);
     LCD1602_WriteCmd(0x0c);      //开显示,不显示光标
     delay1(5);
     delay1(5);
函数名称:void LCD1602_WriteChar(unsigned char x,unsigned char y,unsigned char Dat)
函数功能:写单个字符到指定坐标
输入值  :x:行 (可取0~1) y:列 (可取0~15) Dat:为要显示的数据
返回值  :无
void LCD1602_WriteChar(U8 x,U8 y,U8 Dat)
   if(x==0)
     LCD1602_WriteCmd(0x80+y);
     LCD1602_WriteData(Dat);
     delay1(5);
   if(x != 0)
     LCD1602_WriteCmd(0x80+0x40+y);
     delay1(5);
函数功能:写字符串到指定坐标    (x,y)为首个字符的显示位置
返回值  :无
void LCD1602_WriteString(U8 x,U8 y,U8 *String)
   U8 i;
   for(i=0;String!='\0';i++)
     LCD1602_WriteChar(x,y++,String);
void init(void)
     TMOD = 0x20;          //定时器T1使用工作方式2
         TH1 = 253;        // 设置初值
         TL1 = 253;
         TR1 = 1;          // 开始计时
         SCON = 0x50;          //工作方式1,波特率9600bps,允许接收
         ES = 1;
         EA = 1;           // 打开所以中断
void main(void)
         int a;
         lcd_init();
         init();
         while (1)
            LCD1602_WriteString(0,0,"GangBanHou:");
            LCD1602_WriteString(1,3,"mm");
            LCD1602_WriteChar(1,0,'f');
            a++;
            DelayMs(500);
            LCD1602_WriteChar(1,1,a+'0');
        1602显示程序.zip
  2016-4-28 11:35 上传
点击文件名下载附件
39.58 KB, 下载次数: 3
1602显示程序
更多回帖
