DISBEG EQU 30H CALB EQU P1.7 tiMCON EQU 2FH ORG 0000H LJMP MAIN ORG 0003H RETI ORG 000BH LJMP INTT0 ORG 0013H RETI ORG 001BH LJMP INTT1 ORG 0023H RETI TAB: DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH I_TAB: DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH DLY1M: MOV R6,#14H DL_LOOP: MOV R7,#19H DL_LOOP1:DJNZ R7,DL_LOOP1 DJNZ R6,DL_LOOP RET DLY20M:CLR CALB LCALL D_II_PLAY LCALL D_II_PLAY LCALL D_II_PLAY SETB CALB RET DL_LOOPS:LCALL DL05S LCALL DL05S RET DL05S: MOV R3,#20H DL05S1: LCALL D_II_PLAY DJNZ R3,DL05S1 RET CTIME: MOV A,#10H MOV B,79H MUL AB ADD A,78H MOV TIMCON,A CLOOP: LCALL DLY20M LCALL DL_LOOPS LCALL DL_LOOPS LCALL DL_LOOPS DJNZ TIMCON,CLOOP CLR 08H MAIN: MOV R0,#00H MOV R7,#80H MLOOP: MOV @R0,#00H INC R0 DJNZ R7,MLOOP MOV 20H,#00H MOV 7AH,#0AH MOV TMOD,#11H MOV TL0,#0B0H MOV TH0,#3CH MOV TL1,#0B0H MOV TH1,#3CH SETB EA SETB ET0 SETB TR0 MOV R4,#14H MOV DISBEG,#70H MLOOP1:LCALL D_II_PLAY JNB P1.0,T_SETSC JNB P1.1,DLY5 JNB P1.2,FUNBT JNB P1.3,TSET JB 08H,CTIME AJMP MLOOP1 FUNBT: LJMP DLY6 TSET: LCALL DLY20M JB P1.3,MLOOP1 TS_LOOP:JNB P1.3,TS_LOOP JB 05H,CLRBELL MOV DISBEG,#50H MOV 50H,#0CH MOV 51H,#0AH MINCHG:SETB EA LCALL D_II_PLAY JNB P1.2,DLY1 JNB P1.0,DLY3 JNB P1.3,DLY AJMP MINCHG CLRBELL:CLR 05H CLR CALB AJMP MLOOP1 DLY:LCALL DLY20M JB P1.3,MINCHG LJMP DLY8 T_SETSC:LJMP R_SETTIM DLY1:LCALL DLY20M JB P1.2,MINCHG DLY2: LCALL D_II_PLAY JNB P1.2,DLY2 CLR EA MOV R0,#53H LCALL ADD_1 MOV A,R3 CLR C CJNE A,#60H,ADD_M ADD_M:JC MINCHG ACALL CLR_H AJMP MINCHG DLY3:LCALL DLY20M JB P1.0,MINCHG DLY4:LCALL D_II_PLAY JNB P1.0,DLY4 CLR EA MOV R0,#53H LCALL SUB_M LJMP MINCHG DLY5:LCALL DLY20M JB P1.1,T_MLOOP1 JNB P1.1,$ CPL 03H JNB 03H,DIS_SET MOV DISBEG,#60H MOV 60H,#00H MOV 61H,#00H MOV 62H,#00H MOV 63H,#00H MOV 64H,#00H MOV 65H,#00H MOV TL1,#0F0H MOV TH1,#0D8H SETB TR1 SETB ET1 T_MLOOP1:LJMP MLOOP1 DIS_SET:MOV DISBEG,#70H CLR ET1 CLR TR1 T_MLOOP11:LJMP MLOOP1 DLY6:LCALL DLY20M JB P1.2,T_MLOOP11 T_EST11:JNB P1.2,T_EST11 CLR ET1 CLR TR1 T_EST22:JNB P1.1,DLY5 JB P1.2,T_EST21 LCALL DLY20M JB P1.2,T_EST22 T_EST55:JNB P1.2,T_EST51 MOV 60H,#00H MOV 61H,#00H MOV 62H,#00H MOV 63H,#00H MOV 64H,#00H MOV 65H,#00H T_EST33:JNB P1.1,DLY5 JB P1.2,T_EST31 LCALL DLY20M JB P1.2,T_EST33 T_EST44:JNB P1.2,T_EST41 SETB ET1 SETB TR1 AJMP MLOOP1 T_EST411:LCALL D_II_PLAY AJMP T_EST11 T_EST21:LCALL D_II_PLAY AJMP T_EST22 T_EST31:LCALL D_II_PLAY AJMP T_EST33 T_EST41:LCALL D_II_PLAY AJMP T_EST44 T_EST51:LCALL D_II_PLAY AJMP T_EST55 INTT0:PUSH ACC PUSH PSW CLR ET0 CLR TR0 MOV A,#0B7H ADD A,TL0 MOV TL0,A MOV A,#3CH ADDC A,TH0 MOV TH0,A SETB TR0 DJNZ R4,I_INT0 A_DDS:MOV R4,#14H CPL 07H MOV R0,#71H ACALL ADD_1 MOV A,R3 CLR C CJNE A,#60H,A_DDM A_DDM:JC I_INT0 ACALL CLR_H MOV R0,#77H ACALL ADD_1 MOV A,R3 CLR C CJNE A,#60H,A_DDH A_DDH:JC I_INT0 ACALL CLR_H LCALL DLY20M SETB 08H MOV R0,#79H ACALL ADD_1 MOV A,R3 CLR C CJNE A,#24H,RSTART RSTART:JC I_INT0 ACALL CLR_H I_INT0:MOV 72H,76H MOV 73H,77H MOV 74H,78H MOV 75H,79H LCALL BELL POP PSW POP ACC SETB ET0 RETI INTT1:PUSH ACC PUSH PSW JB 03H,R_ADDS MOV TL1,#0B0H MOV TH1,#3CH DJNZ R2,I_INT1 MOV R2,#06H CPL 02H JB 02H,FLASH0 MOV 72H,76H MOV 73H,77H MOV 74H,78H MOV 75H,79H I_INT1:POP PSW POP ACC RETI FLASH0:JB 01H,FLASH1 MOV 72H,7AH MOV 73H,7AH MOV 74H,78H MOV 75H,79H AJMP I_INT1 FLASH1:MOV 72H,76H MOV 73H,77H MOV 74H,7AH MOV 75H,7AH AJMP I_INT1 R_ADDS:CLR TR1 MOV A,#0F7H ADD A,TL1 MOV TL1,A MOV A,#0D8H ADDC A,TH1 MOV TH1,A SETB TR1 MOV R0,#61H ACALL ADD_1 CLR C MOV A,R3 JZ R_ADDM AJMP I_INT01 R_ADDM:ACALL CLR_H MOV R0,#63H ACALL ADD_1 MOV A,R3 CLR C CJNE A,#60H,R_ADDH R_ADDH:JC I_INT01 LCALL CLR_H MOV R0,#65H ACALL ADD_1 I_INT01:POP PSW POP ACC RETI ADD_1:MOV A,@R0 DEC R0 SWAP A ORL A,@R0 ADD A,#01H DA A MOV R3,A ANL A,#0FH MOV @R0,A MOV A,R3 INC R0 SWAP A ANL A,#0FH MOV @R0,A RET SUB_M:MOV A,@R0 DEC R0 SWAP A ORL A,@R0 JZ SUB_M1 DEC A SUB_M11:MOV R3,A ANL A,#0FH CLR C SUBB A,#0AH SUB_M111:JC SUB_M110 MOV @R0,#09H SUB_M10:MOV A,R3 INC R0 SWAP A ANL A,#0FH MOV @R0,A RET SUB_M1:MOV A,#59H AJMP SUB_M11 SUB_M110:MOV A,R3 SUB_H:MOV A,@R0 DEC R0 SWAP A ORL A,@R0 JZ SUB_H1 DEC A SUB_H11:MOV R3,A ANL A,#0FH CLR C SUBB A,#0AH SUB_H111:JC SUB_H110 MOV @R0,#09H SUB_H10:MOV A,R3 INC R0 SWAP A ANL A,#0FH MOV @R0,A RET SUB_H1:MOV A,#23H AJMP SUB_H11 SUB_H110:MOV A,R3 CLR_H:CLR A MOV @R0,A DEC R0 MOV @R0,A RET R_SETTIM:CLR ET0 CLR TR0 LCALL DL_LOOPS LCALL DLY20M JB P1.0,SLEEP MOV R2,#06H MOV 70H,#00H MOV 71H,#00H SETB ET1 SETB TR1 SET_2:JNB P1.0,SET_1 SETB 00H SET_4:JB P1.0,SET_3 LCALL DL05S LCALL DLY20M JNB P1.0,R_SETHH MOV R0,#77H LCALL ADD_1 MOV A,R3 CLR C CJNE A,#60H,SET_LOOP SET_LOOP:JC SET_4 LCALL CLR_H CLR C AJMP SET_4 SLEEP:SETB ET0 SETB TR0 SET_LOOP1:JB P1.0,SET_LOOP1 LCALL DLY20M JB P1.0,SET_LOOP1 SET_LOOP2:JNB P1.0,SET_LOOP2 LJMP MLOOP1 R_SETHH:CLR 00H SETB 01H SET_LOOP3:JNB P1.0,SET_5 SET_6:JB P1.0,SET_7 LCALL DL05S LCALL DLY20M JNB P1.0,STOP MOV R0,#79H LCALL ADD_1 MOV A,R3 CLR C CJNE A,#24H,C_YHH C_YHH:JC SET_6 LCALL CLR_H AJMP SET_6 STOP:JNB P1.0,STOP1 LCALL DLY20M JNB P1.0,STOP CLR 01H CLR 00H CLR 02H CLR TR1 CLR ET1 SETB TR0 SETB ET0 LJMP MLOOP1 SET_1:LCALL D_II_PLAY AJMP SET_2 SET_3:LCALL D_II_PLAY JNB P1.1,DLY7 AJMP SET_4 SET_5:LCALL D_II_PLAY AJMP SET_LOOP3 SET_7:LCALL D_II_PLAY JNB P1.1,DLY7B AJMP SET_6 STOP1:LCALL D_II_PLAY AJMP STOP DLY7:LCALL DLY20M JB P1.1,SET_41 DLY7_M:JNB P1.1,DLY7_M MOV R0,#77H LCALL SUB_M LJMP SET_4 SET_41:LJMP SET_4 DLY7B:LCALL DLY20M JB P1.1,SET_61 DLY7_H:JNB P1.1,DLY7_H MOV R0,#79H LCALL SUB_H LJMP SET_6 SET_61:LJMP SET_6 D_II_PLAY:MOV R1,DISBEG MOV R5,#0FEH PLAY:MOV A,R5 MOV P2,A MOV A,@R1 MOV DPTR,#TAB MOVC A,@A+DPTR MOV P0,A MOV A,R5 JB ACC.2,D_LOOP CLR P0.7 D_LOOP:JB ACC.4,D_LOOP1 CLR P0.7 D_LOOP1:LCALL DLY1M INC R1 MOV A,R5 JNB ACC.5,CLOSE RL A MOV R5,A MOV P0,#0FFH AJMP PLAY CLOSE:MOV P2,#0FFH MOV P0,#0FFH RET SD_II_PLAY:MOV R1,DISBEG MOV R5,#0FEH I_PLAY:MOV A,R5 MOV P2,A MOV A,@R1 MOV DPTR,#I_TAB MOVC A,@A+DPTR MOV P0,A MOV A,R5 LCALL DLY1M INC R1 MOV A,R5 JNB ACC.5,CLOSES RL A MOV R5,A AJMP I_PLAY CLOSES:MOV P2,#0FFH MOV P0,#0FFH RET DLY8:LCALL D_II_PLAY JNB P1.3,DLY8 MOV 50H,#0AH MOV 51H,#0CH R_BTIM:SETB EA LCALL D_II_PLAY JNB P1.2,DLY12 JNB P1.0,DLY14 JNB P1.3,DLY9 JNB P1.1,DLY10 AJMP R_BTIM DLY9:LCALL DLY20M JB P1.3,R_BTIM DLY8M:LCALL D_II_PLAY JNB P1.3,DLY8M MOV DISBEG,#70H LJMP MLOOP1 DLY10:LCALL DLY20M JB P1.1,R_BTIM DLY11:LCALL D_II_PLAY JNB P1.1,DLY11 CPL 05H JNB 05H,R_BTIM11 MOV 50H,#00H AJMP R_BTIM R_BTIM11:MOV 50H,#0AH AJMP R_BTIM DLY12:LCALL DLY20M JB P1.2,R_BTIM DLY13:LCALL D_II_PLAY JNB P1.2,DLY13 CLR EA MOV R0,#55H LCALL ADD_1 MOV A,R3 CLR C CJNE A,#24H,A_DDH33N A_DDH33N:JC R_BTIM ACALL CLR_H AJMP R_BTIM DLY14:LCALL DLY20M JB P1.0,R_BTIM DLY15:LCALL D_II_PLAY JNB P1.0,DLY15 CLR EA MOV R0,#55H LCALL SUB_H LJMP R_BTIM BELL:JNB 05H,BBELL MOV A,79H CJNE A,55H,BBELL MOV A,78H CLR C BELL_1:CJNE A,54H,BBELL MOV A,77H CLR C CJNE A,53H,BBELL MOV A,76H CLR C BELL_2:CJNE A,52H,BBELL JNB 07H,BBELL CLR CALB RET BBELL:SETB CALB RET END |
更多回帖
