arm中文社区
直播中
黎菁菁
8年用户 574经验值
私信 关注
[经验]
ARM mini2440裸奔 跑LCD手写代码
ARM裸奔跑代码,LCD 实现手写功能,(mini2440)裸奔又进了一步,更一步熟悉ARM体系结构
全部代码下载:    TOUCH----shouxie.rar
部分源码预览:
  • ; NAME: 2440INIT.S
  • ; DESC: C start up codes
  • ;       Configure memory, ISR ,stacks
  • ;        Initialize C-variables
  • ; HISTORY:
  • ; 2002.02.25:kwtark: ver 0.0
  • ; 2002.03.20:purnnamu: Add some functions for testing STOP,Sleep mode
  • ; 2003.03.14:DonGo: Modified for 2440.
  •         GET option.inc
  •         GET memcfg.inc
  •         GET 2440addr.inc
  • BIT_SELFREFRESH EQU        (1<<22)
  • ;Pre-defined constants
  • USERMODE    EQU         0x10
  • FIQMODE     EQU         0x11
  • IRQMODE     EQU         0x12
  • SVCMODE     EQU         0x13
  • ABORTMODE   EQU         0x17
  • UNDEFMODE   EQU         0x1b
  • MODEMASK    EQU         0x1f
  • NOINT       EQU         0xc0
  • ;The location of stacks
  • UserStack        EQU        (_STACK_BASEADDRESS-0x3800)        ;0x33ff4800 ~
  • SVCStack        EQU        (_STACK_BASEADDRESS-0x2800)        ;0x33ff5800 ~
  • UndefStack        EQU        (_STACK_BASEADDRESS-0x2400)        ;0x33ff5c00 ~
  • AbortStack        EQU        (_STACK_BASEADDRESS-0x2000)        ;0x33ff6000 ~
  • IRQStack        EQU        (_STACK_BASEADDRESS-0x1000)        ;0x33ff7000 ~
  • FIQStack        EQU        (_STACK_BASEADDRESS-0x0)        ;0x33ff8000 ~
  • ;Check if tasm.exe(armasm -16 ...@ADS 1.0) is used.
  •         GBLL    THUMBCODE
  •         [ {CONFIG} = 16
  • THUMBCODE SETL  {TRUE}
  •             CODE32
  • THUMBCODE SETL  {FALSE}
  •                  MACRO
  •         MOV_PC_LR
  •                  [ THUMBCODE
  •             bx lr
  •             mov        pc,lr
  •         MEND
  •                  MACRO
  •         MOVEQ_PC_LR
  •                  [ THUMBCODE
  •         bxeq lr
  •             moveq pc,lr
  •         MEND
  •                  MACRO
  • $HandlerLabel HANDLER $HandleLabel
  • $HandlerLabel
  •         sub        sp,sp,#4        ;decrement sp(to store jump address)
  •         stmfd        sp!,{r0}        ;PUSH the work register to stack(lr does not push because it return to original address)
  •         ldr     r0,=$HandleLabel;load the address of HandleXXX to r0
  •         ldr     r0,[r0]         ;load the contents(service routine start address) of HandleXXX
  •         str     r0,[sp,#4]      ;store the contents(ISR) of HandleXXX to stack
  •         ldmfd   sp!,{r0,pc}     ;POP the work register and pc(jump to ISR)
  •         MEND
  •         IMPORT  |Image$RO$Base|        ; Base of ROM code
  •         IMPORT  |Image$RO$Limit|  ; End of ROM code (=start of ROM data)
  •         IMPORT  |Image$RW$Base|   ; Base of RAM to initialise
  •         IMPORT  |Image$ZI$Base|   ; Base and limit of area
  •         IMPORT  |Image$ZI$Limit|  ; to zero initialise
  •         IMPORT        MMU_SetAsyncBusMode
  •         IMPORT        MMU_SetFastBusMode        ;
  •         IMPORT  Main    ; The main entry of mon program
  •         AREA    Init,CODE,READONLY
  •         ENTRY
  •         EXPORT        __ENTRY
  • __ENTRY
  • ResetEntry
  •         ;1)The code, which converts to Big-endian, should be in little endian code.
  •         ;2)The following little endian code will be compiled in Big-Endian mode.
  •         ;  The code byte order should be changed as the memory bus width.
  •         ;3)The pseudo instruction,DCD can not be used here because the linker generates error.
  •         ASSERT        :DEF:ENDIAN_CHANGE
  •         [ ENDIAN_CHANGE
  •             ASSERT  :DEF:ENTRY_BUS_WIDTH
  •             [ ENTRY_BUS_WIDTH=32
  •                 b        ChangeBigEndian            ;DCD 0xea000007
  •             [ ENTRY_BUS_WIDTH=16
  •                 andeq        r14,r7,r0,lsl #20   ;DCD 0x0007ea00
  •             [ ENTRY_BUS_WIDTH=8
  •                 streq        r0,[r0,-r10,ror #1] ;DCD 0x070000ea
  •             b        ResetHandler
  •         b        HandlerUndef        ;handler for Undefined mode
  •         b        HandlerSWI        ;handler for SWI interrupt
  •         b        HandlerPabort        ;handler for PAbort
  •         b        HandlerDabort        ;handler for DAbort
  •         b        .                ;reserved
  •         b        HandlerIRQ        ;handler for IRQ interrupt
  •         b        HandlerFIQ        ;handler for FIQ interrupt
  • ;@0x20
  •         b        EnterPWDN        ; Must be @0x20.
  • ChangeBigEndian
  • ;@0x24
  •             DCD        0xee110f10        ;0xee110f10 => mrc p15,0,r0,c1,c0,0
  •             DCD        0xe3800080        ;0xe3800080 => orr r0,r0,#0x80;  //Big-endian
  •             DCD        0xee010f10        ;0xee010f10 => mcr p15,0,r0,c1,c0,0
  •             DCD 0x0f10ee11
  •             DCD 0x0080e380
  •             DCD 0x0f10ee01
  •             DCD 0x100f11ee
  •             DCD 0x800080e3
  •             DCD 0x100f01ee
  •         DCD 0xffffffff  ;swinv 0xffffff is similar with NOP and run well in both endian mode.
  •         DCD 0xffffffff
  •         DCD 0xffffffff
  •         DCD 0xffffffff
  •         DCD 0xffffffff
  •         b ResetHandler
  • HandlerFIQ      HANDLER HandleFIQ
  • HandlerIRQ      HANDLER HandleIRQ
  • HandlerUndef    HANDLER HandleUndef
  • HandlerSWI      HANDLER HandleSWI
  • HandlerDabort   HANDLER HandleDabort
  • HandlerPabort   HANDLER HandlePabort
  • IsrIRQ
  •         sub        sp,sp,#4       ;reserved for PC
  •         stmfd        sp!,{r8-r9}
  •         ldr        r9,=INTOFFSET
  •         ldr        r9,[r9]
  •         ldr        r8,=HandleEINT0
  •         add        r8,r8,r9,lsl #2
  •         ldr        r8,[r8]
  •         str        r8,[sp,#8]
  •         ldmfd        sp!,{r8-r9,pc}
  •         LTORG
  • ; ENTRY
  • ResetHandler
  •         ldr        r0,=WTCON       ;watch dog disable
  •         ldr        r1,=0x0
  •         str        r1,[r0]
  •         ldr        r0,=INTMSK
  •         ldr        r1,=0xffffffff  ;all interrupt disable
  •         str        r1,[r0]
  •         ldr        r0,=INTSUBMSK
  •         ldr        r1,=0x7fff                ;all sub interrupt disable
  •         str        r1,[r0]
  •         [ {TRUE}
  •         ;rGPFDAT = (rGPFDAT & ~(0xf<<4)) | ((~data & 0xf)<<4);
  •         ; Led_Display
  •         ldr        r0,=GPBCON
  •         ldr        r1,=0x00555555
  •         str        r1,[r0]
  •         ldr        r0,=GPBDAT
  •         ldr        r1,=0x07fe
  •         str        r1,[r0]
  •         ;To reduce PLL lock time, adjust the LOCKTIME register.
  •         ldr        r0,=LOCKTIME
  •         ldr        r1,=0xffffff
  •         str        r1,[r0]
  •     [ PLL_ON_START
  •         ; Added for confirm clock divide. for 2440.
  •         ; Setting value Fclk:Hclk:Pclk
  •         ldr        r0,=CLKDIVN
  •         ldr        r1,=CLKDIV_VAL                ; 0=1:1:1, 1=1:1:2, 2=1:2:2, 3=1:2:4, 4=1:4:4, 5=1:4:8, 6=1:3:3, 7=1:3:6.
  •         str        r1,[r0]
  • ;        MMU_SetAsyncBusMode and MMU_SetFastBusMode over 4K, so do not call here
  • ;        call it after copy
  • ;        [ CLKDIV_VAL>1                 ; means Fclk:Hclk is not 1:1.
  • ;        bl MMU_SetAsyncBusMode
  • ;        bl MMU_SetFastBusMode        ; default value.
  •         ;program has not been copied, so use these directly
  •         [ CLKDIV_VAL>1                 ; means Fclk:Hclk is not 1:1.
  •         mrc p15,0,r0,c1,c0,0
  •         orr r0,r0,#0xc0000000;R1_nF:OR:R1_iA
  •         mcr p15,0,r0,c1,c0,0
  •         bic r0,r0,#0xc0000000;R1_iA:OR:R1_nF
  •         ;Configure UPLL
  •         ldr        r0,=UPLLCON
  •         ldr        r1,=((U_MDIV<<12)+(U_PDIV<<4)+U_SDIV)
  •         str        r1,[r0]
  •         nop        ; Caution: After UPLL setting, at least 7-clocks delay must be inserted for setting hardware be completed.
  •         nop
  •         nop
  •         nop
  •         nop
  •         nop
  •         nop
  •         ;Configure MPLL
  •         ldr        r0,=MPLLCON
  •         ldr        r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV)  ;Fin=16.9344MHz
  •         str        r1,[r0]
  •         ;Check if the boot is caused by the wake-up from SLEEP mode.
  •         ldr        r1,=GSTATUS2
  •         ldr        r0,[r1]
  •         tst        r0,#0x2
  •         ;In case of the wake-up from SLEEP mode, go to SLEEP_WAKEUP handler.
  •         bne        WAKEUP_SLEEP
  •         EXPORT StartPointAfterSleepWakeUp
  • StartPointAfterSleepWakeUp
  •         ;Set memory control registers
  •          ;ldr        r0,=SMRDATA
  •          adrl        r0, SMRDATA        ;be careful!
  •         ldr        r1,=BWSCON        ;BWSCON Address
  •         add        r2, r0, #52        ;End address of SMRDATA
  • 0
  •         ldr        r3, [r0], #4
  •         str        r3, [r1], #4
  •         cmp        r2, r0
  •         bne        %B0
  • ;;;;;;;;;;;;;       When EINT0 is pressed,  Clear SDRAM
  • ; check if EIN0 button is pressed
  •        ldr        r0,=GPFCON
  •         ldr        r1,=0x0
  •         str        r1,[r0]
  •         ldr        r0,=GPFUP
  •         ldr        r1,=0xff
  •         str        r1,[r0]
  •         ldr        r1,=GPFDAT
  •         ldr        r0,[r1]
  •        bic        r0,r0,#(0x1e<<1)  ; bit clear
  •         tst        r0,#0x1
  •         bne %F1
  • ; Clear SDRAM Start
  •         ldr        r0,=GPFCON
  •         ldr        r1,=0x55aa
  •         str        r1,[r0]
  • ;        ldr        r0,=GPFUP
  • ;        ldr        r1,=0xff
  • ;        str        r1,[r0]
  •         ldr        r0,=GPFDAT
  •         ldr        r1,=0x0
  •         str        r1,[r0]        ;LED=****
  •         mov r1,#0
  •         mov r2,#0
  •         mov r3,#0
  •         mov r4,#0
  •         mov r5,#0
  •         mov r6,#0
  •         mov r7,#0
  •         mov r8,#0
  •         ldr        r9,=0x4000000   ;64MB
  •         ldr        r0,=0x30000000
  • 0
  •         stmia        r0!,{r1-r8}
  •         subs        r9,r9,#32
  •         bne        %B0
  • ;Clear SDRAM End
  • 1
  •                  ;Initialize stacks
  •         bl        InitStacks
  •         ldr        r0, =BWSCON
  •         ldr        r0, [r0]
  •         ands        r0, r0, #6                ;OM[1:0] != 0, NOR FLash boot
  •         bne        copy_proc_beg                ;do not read nand flash
  •         adr        r0, ResetEntry                ;OM[1:0] == 0, NAND FLash boot
  •         cmp        r0, #0                                ;if use Multi-ice,
  •         bne        copy_proc_beg                ;do not read nand flash for boot
  •         ;nop
  • nand_boot_beg
  •         mov        r5, #NFCONF
  •         ;set timing value
  •         ldr        r0,        =(7<<12)|(7<<8)|(7<<4)
  •         str        r0,        [r5]
  •         ;enable control
  •         ldr        r0, =(0<<13)|(0<<12)|(0<<10)|(0<<9)|(0<<8)|(1<<6)|(1<<5)|(1<<4)|(1<<1)|(1<<0)
  •         str        r0, [r5, #4]
  •         bl        ReadNandID
  •         mov        r6, #0
  •         ldr        r0, =0xec73
  •         cmp        r5,        r0
  •         beq        %F1
  •         ldr        r0, =0xec75
  •         cmp        r5, r0
  •         beq        %F1
  •         mov        r6, #1
  • 1
  •         bl        ReadNandStatus
  •         mov        r8, #0
  •         ldr        r9, =ResetEntry
  • 2
  •         ands        r0, r8, #0x1f
  •         bne                %F3
  •         mov                r0, r8
  •         bl                CheckBadBlk
  •         cmp                r0, #0
  •         addne        r8, r8, #32
  •         bne                %F4
  • 3
  •         mov        r0, r8
  •         mov        r1, r9
  •         bl        ReadNandPage
  •         add        r9, r9, #512
  •         add        r8, r8, #1
  • 4
  •         cmp        r8, #5120
  •         bcc        %B2
  •         mov        r5, #NFCONF                        ;DsNandFlash
  •         ldr        r0, [r5, #4]
  •         bic r0, r0, #1
  •         str        r0, [r5, #4]
  •         ldr        pc, =copy_proc_beg
  • copy_proc_beg
  •         ldr        r2, BaseOfROM
  •         cmp        r0, r2
  •         ldreq        r0, TopOfROM
  •         beq        InitRam
  •         ldr r3, TopOfROM
  • 0
  •         ldmia        r0!, {r4-r7}
  •         stmia        r2!, {r4-r7}
  •         cmp        r2, r3
  •         bcc        %B0
  •         sub        r2, r2, r3
  •         sub        r0, r0, r2
  • InitRam
  •         ldr        r2, BaseOfBSS
  •         ldr        r3, BaseOfZero
  • 0
  •         cmp        r2, r3
  •         ldrcc        r1, [r0], #4
  •         strcc        r1, [r2], #4
  •         bcc        %B0
  •         mov        r0,        #0
  •         ldr        r3,        EndOfBSS
  • 1
  •         cmp        r2,        r3
  •         strcc        r0, [r2], #4
  •         bcc        %B1
  •         ldr        pc, =%F2                ;goto compiler address
  • 2
  •         ;bl        Led_Test
  •           ; Setup IRQ handler
  •         ldr        r0,=HandleIRQ       ;This routine is needed
  •         ldr        r1,=IsrIRQ          ;if there is not 'subs pc,lr,#4' at 0x18, 0x1c
  •         str        r1,[r0]
  • ;        ;Copy and paste RW data/zero initialized data
  • ;        ldr        r0, =|Image$RO$Limit| ; Get pointer to ROM data
  • ;        ldr        r1, =|Image$RW$Base|  ; and RAM copy
  • ;        ldr        r3, =|Image$ZI$Base|
  • ;        ;Zero init base => top of initialised data
  • ;        cmp        r0, r1      ; Check that they are different
  • ;        beq        %F2
  • ;1
  • ;        cmp        r1, r3      ; Copy init data
  • ;        ldrcc        r2, [r0], #4    ;--> LDRCC r2, [r0] + ADD r0, r0, #4
  • ;        strcc        r2, [r1], #4    ;--> STRCC r2, [r1] + ADD r1, r1, #4
  • ;        bcc        %B1
  • ;2
  • ;        ldr        r1, =|Image$ZI$Limit| ; Top of zero init segment
  • ;        mov        r2, #0
  • ;3
  • ;        cmp        r3, r1      ; Zero init
  • ;        strcc        r2, [r3], #4
  • ;        bcc        %B3
  •     [ :LNOT:THUMBCODE
  •                  bl        Main        ;Do not use main() because ......
  •                  ;ldr        pc, =Main        ;
  •                  b        .
  •     [ THUMBCODE         ;for start-up code for Thumb mode
  •                  orr        lr,pc,#1
  •                  bx        lr
  •                  CODE16
  •                  b        .
  •                 CODE32
  • ;function initializing stacks
  • InitStacks
  •         ;Do not use DRAM,such as stmfd,ldmfd......
  •         ;SVCstack is initialized before
  •         ;Under toolkit ver 2.5, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
  •         mrs        r0,cpsr
  •         bic        r0,r0,#MODEMASK
  •         orr        r1,r0,#UNDEFMODE|NOINT
  •         msr        cpsr_cxsf,r1                ;UndefMode
  •         ldr        sp,=UndefStack                ; UndefStack=0x33FF_5C00
  •         orr        r1,r0,#ABORTMODE|NOINT
  •         msr        cpsr_cxsf,r1                ;AbortMode
  •         ldr        sp,=AbortStack                ; AbortStack=0x33FF_6000
  •         orr        r1,r0,#IRQMODE|NOINT
  •         msr        cpsr_cxsf,r1                ;IRQMode
  •         ldr        sp,=IRQStack                ; IRQStack=0x33FF_7000
  •         orr        r1,r0,#FIQMODE|NOINT
  •         msr        cpsr_cxsf,r1                ;FIQMode
  •         ldr        sp,=FIQStack                ; FIQStack=0x33FF_8000
  •         bic        r0,r0,#MODEMASK|NOINT
  •         orr        r1,r0,#SVCMODE
  •         msr        cpsr_cxsf,r1                ;SVCMode
  •         ldr        sp,=SVCStack                ; SVCStack=0x33FF_5800
  •         ;USER mode has not be initialized.
  •         mov        pc,lr
  •         ;The LR register will not be valid if the current mode is not SVC mode.
  • ReadNandID
  •         mov      r7,#NFCONF
  •         ldr      r0,[r7,#4]                ;NFChipEn();
  •         bic      r0,r0,#2
  •         str      r0,[r7,#4]
  •         mov      r0,#0x90                ;WrNFCmd(RdIDCMD);
  •         strb     r0,[r7,#8]
  •         mov      r4,#0                        ;WrNFAddr(0);
  •         strb     r4,[r7,#0xc]
  • 1                                                        ;while(NFIsBusy());
  •         ldr      r0,[r7,#0x20]
  •         tst      r0,#1
  •         beq      %B1
  •         ldrb     r0,[r7,#0x10]        ;id  = RdNFDat()<<8;
  •         mov      r0,r0,lsl #8
  •         ldrb     r1,[r7,#0x10]        ;id |= RdNFDat();
  •         orr      r5,r1,r0
  •         ldr      r0,[r7,#4]                ;NFChipDs();
  •         orr      r0,r0,#2
  •         str      r0,[r7,#4]
  •         mov                 pc,lr
  • ReadNandStatus
  •         mov                 r7,#NFCONF
  •         bic      r0,r0,#2
  •         str      r0,[r7,#4]
  •         mov      r0,#0x70                ;WrNFCmd(QUERYCMD);
  •         strb     r0,[r7,#8]
  •         ldrb     r1,[r7,#0x10]        ;r1 = RdNFDat();
  •         orr      r0,r0,#2
  •         str      r0,[r7,#4]
  •         mov                 pc,lr
  • WaitNandBusy
  •         mov      r1,#NFCONF
  •         strb     r0,[r1,#8]
  • 1                                                        ;while(!(RdNFDat()&0x40));
  •         ldrb     r0,[r1,#0x10]
  •         tst      r0,#0x40
  •         beq                 %B1
  •         mov      r0,#0                        ;WrNFCmd(READCMD0);
  •         strb     r0,[r1,#8]
  •         mov      pc,lr
  • CheckBadBlk
  •         mov                r7, lr
  •         mov                r5, #NFCONF
  •         bic      r0,r0,#0x1f        ;addr &= ~0x1f;
  •         ldr      r1,[r5,#4]                ;NFChipEn()
  •         bic      r1,r1,#2
  •         str      r1,[r5,#4]
  •         mov      r1,#0x50                ;WrNFCmd(READCMD2)
  •         strb     r1,[r5,#8]
  •         mov      r1, #5;6                ;6->5
  •         strb     r1,[r5,#0xc]        ;WrNFAddr(5);(6) 6->5
  •         strb     r0,[r5,#0xc]        ;WrNFAddr(addr)
  •         mov      r1,r0,lsr #8        ;WrNFAddr(addr>>8)
  •         strb     r1,[r5,#0xc]
  •         cmp      r6,#0                        ;if(NandAddr)
  •         movne    r0,r0,lsr #16        ;WrNFAddr(addr>>16)
  •         strneb   r0,[r5,#0xc]
  • ;        bl                WaitNandBusy        ;WaitNFBusy()
  •         ;do not use WaitNandBusy, after WaitNandBusy will read part A!
  •         mov        r0, #100
  • 1
  •         subs        r0, r0, #1
  •         bne        %B1
  • 2
  •         ldr        r0, [r5, #0x20]
  •         tst        r0, #1
  •         beq        %B2
  •         ldrb        r0, [r5,#0x10]        ;RdNFDat()
  •         sub                r0, r0, #0xff
  •         mov      r1,#0                        ;WrNFCmd(READCMD0)
  •         strb     r1,[r5,#8]
  •         ldr      r1,[r5,#4]                ;NFChipDs()
  •         orr      r1,r1,#2
  •         str      r1,[r5,#4]
  •         mov                pc, r7
  • ReadNandPage
  •         mov                 r7,lr
  •         mov      r4,r1
  •         mov      r5,#NFCONF
  •         bic      r1,r1,#2
  •         str      r1,[r5,#4]
  •         strb     r1,[r5,#8]
  •         strb     r1,[r5,#0xc]        ;WrNFAddr(0)
  •         strb     r1,[r5,#0xc]
  •         ldr      r0,[r5,#4]                ;InitEcc()
  •         orr      r0,r0,#0x10
  •         str      r0,[r5,#4]
  •         bl       WaitNandBusy        ;WaitNFBusy()
  •         mov      r0,#0                        ;for(i=0; i<512; i++)
  • 1
  •         ldrb     r1,[r5,#0x10]        ;buf = RdNFDat()
  •         strb     r1,[r4,r0]
  •         add      r0,r0,#1
  •         bic      r0,r0,#0x10000
  •         cmp      r0,#0x200
  •         bcc      %B1
  •         ldr      r0,[r5,#4]                ;NFChipDs()
  •         orr      r0,r0,#2
  •         str      r0,[r5,#4]
  •         mov                 pc,r7
  •         LTORG
  • ;GCS0->SST39VF1601
  • ;GCS1->16c550
  • ;GCS2->IDE
  • ;GCS3->CS8900
  • ;GCS4->DM9000
  • ;GCS5->CF Card
  • ;GCS6->SDRAM
  • ;GCS7->unused
  • SMRDATA DATA
  • ; Memory configuration should be optimized for best performance
  • ; The following parameter is not optimized.
  • ; Memory access cycle parameter strategy
  • ; 1) The memory settings is  safe parameters even at HCLK=75Mhz.
  • ; 2) SDRAM refresh period is for HCLK<=75Mhz.
  •         DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
  •         DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC))   ;GCS0
  •         DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC))   ;GCS1
  •         DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC))   ;GCS2
  •         DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC))   ;GCS3
  •         DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC))   ;GCS4
  •         DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC))   ;GCS5
  •         DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN))    ;GCS6
  •         DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN))    ;GCS7
  •         DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Tsrc<<18)+(Tchr<<16)+REFCNT)
  •         DCD 0x32            ;SCLK power saving mode, BANKSIZE 128M/128M
  •         DCD 0x30            ;MRSR6 CL=3clk
  •         DCD 0x30            ;MRSR7 CL=3clk
  • BaseOfROM        DCD        |Image$RO$Base|
  • TopOfROM        DCD        |Image$RO$Limit|
  • BaseOfBSS        DCD        |Image$RW$Base|
  • BaseOfZero        DCD        |Image$ZI$Base|
  • EndOfBSS        DCD        |Image$ZI$Limit|
  •         ALIGN
  • ;Function for entering power down mode
  • ; 1. SDRAM should be in self-refresh mode.
  • ; 2. All interrupt should be maksked for SDRAM/DRAM self-refresh.
  • ; 3. LCD controller should be disabled for SDRAM/DRAM self-refresh.
  • ; 4. The I-cache may have to be turned on.
  • ; 5. The location of the following code may have not to be changed.
  • ;void EnterPWDN(int CLKCON);
  • EnterPWDN
  •         mov r2,r0                ;r2=rCLKCON
  •         tst r0,#0x8                ;SLEEP mode?
  •         bne ENTER_SLEEP
  • ENTER_STOP
  •         ldr r0,=REFRESH
  •         ldr r3,[r0]                ;r3=rREFRESH
  •         mov r1, r3
  •         orr r1, r1, #BIT_SELFREFRESH
  •         str r1, [r0]                ;Enable SDRAM self-refresh
  •         mov r1,#16                        ;wait until self-refresh is issued. may not be needed.
  • 0        subs r1,r1,#1
  •         bne %B0
  •         ldr r0,=CLKCON                ;enter STOP mode.
  •         str r2,[r0]
  •         mov r1,#32
  • 0        subs r1,r1,#1        ;1) wait until the STOP mode is in effect.
  •         bne %B0                ;2) Or wait here until the CPU&Peripherals will be turned-off
  •                         ;   Entering SLEEP mode, only the reset by wake-up is available.
  •         ldr r0,=REFRESH ;exit from SDRAM self refresh mode.
  •         str r3,[r0]
  •         MOV_PC_LR
  • ENTER_SLEEP
  •         ;NOTE.
  •         ;1) rGSTATUS3 should have the return address after wake-up from SLEEP mode.
  •         ldr r0,=REFRESH
  •         ldr r1,[r0]                ;r1=rREFRESH
  •         mov r1,#16                        ;Wait until self-refresh is issued,which may not be needed.
  • 0        subs r1,r1,#1
  •         bne %B0
  •         ldr        r1,=MISCCR
  •         ldr        r0,[r1]
  •         orr        r0,r0,#(7<<17)  ;Set SCLK0=0, SCLK1=0, SCKE=0.
  •         str        r0,[r1]
  •         ldr r0,=CLKCON                ; Enter sleep mode
  •         str r2,[r0]
  •         b .                        ;CPU will die here.
  • WAKEUP_SLEEP
  •         ;Release SCLKn after wake-up from the SLEEP mode.
  •         ldr        r1,=MISCCR
  •         ldr        r0,[r1]
  •         bic        r0,r0,#(7<<17)  ;SCLK0:0->SCLK, SCLK1:0->SCLK, SCKE:0->=SCKE.
  •         str        r0,[r1]
  •          ldr        r0,=SMRDATA        ;be careful!
  • 0
  •         ldr        r3, [r0], #4
  •         str        r3, [r1], #4
  •         cmp        r2, r0
  •         bne        %B0
  •         mov r1,#256
  • 0        subs r1,r1,#1        ;1) wait until the SelfRefresh is released.
  •         bne %B0
  •         ldr r1,=GSTATUS3         ;GSTATUS3 has the start address just after SLEEP wake-up
  •         ldr r0,[r1]
  •         mov pc,r0
  • ; Clock division test
  • ; Assemble code, because VSYNC time is very short
  •         EXPORT CLKDIV124
  •         EXPORT CLKDIV144
  • CLKDIV124
  •         ldr     r0, = CLKDIVN
  •         ldr     r1, = 0x3                ; 0x3 = 1:2:4
  •         str     r1, [r0]
  • ;        wait until clock is stable
  •         nop
  •         nop
  •         nop
  •         nop
  •         nop
  •         ldr     r0, = REFRESH
  •         ldr     r1, [r0]
  •         bic                r1, r1, #0xff
  •         bic                r1, r1, #(0x7<<8)
  •         orr                r1, r1, #0x470        ; REFCNT135
  •         str     r1, [r0]
  •         nop
  •         nop
  •         nop
  •         nop
  •         nop
  •         mov     pc, lr
  • CLKDIV144
  •         ldr     r0, = CLKDIVN
  •         ldr     r1, = 0x4                ; 0x4 = 1:4:4
  •         str     r1, [r0]
  •         nop
  •         nop
  •         nop
  •         nop
  •         nop
  •         ldr     r0, = REFRESH
  •         ldr     r1, [r0]
  •         bic                r1, r1, #0xff
  •         orr                r1, r1, #0x630        ; REFCNT675 - 1520
  •         str     r1, [r0]
  •         nop
  •         nop
  •         nop
  •         nop
  •         nop
  •         mov     pc, lr
  •         ALIGN
  •         AREA RamData, DATA, READWRITE
  •         ^   _ISR_STARTADDRESS                ; _ISR_STARTADDRESS=0x33FF_FF00
  • HandleReset         #   4
  • HandleUndef         #   4
  • HandleSWI                #   4
  • HandlePabort    #   4
  • HandleDabort    #   4
  • HandleReserved  #   4
  • HandleIRQ                #   4
  • HandleFIQ                #   4
  • ;Do not use the label 'IntVectorTable',
  • ;The value of IntVectorTable is different with the address you think it may be.
  • ;IntVectorTable
  • ;@0x33FF_FF20
  • HandleEINT0                #   4
  • HandleEINT1                #   4
  • HandleEINT2                #   4
  • HandleEINT3                #   4
  • HandleEINT4_7        #   4
  • HandleEINT8_23        #   4
  • HandleCAM                #   4                ; Added for 2440.
  • HandleBATFLT        #   4
  • HandleTICK                #   4
  • HandleWDT                #   4
  • HandleTIMER0         #   4
  • HandleTIMER1         #   4
  • HandleTIMER2         #   4
  • HandleTIMER3         #   4
  • HandleTIMER4         #   4
  • HandleUART2          #   4
  • ;@0x33FF_FF60
  • HandleLCD                 #   4
  • HandleDMA0                #   4
  • HandleDMA1                #   4
  • HandleDMA2                #   4
  • HandleDMA3                #   4
  • HandleMMC                #   4
  • HandleSPI0                #   4
  • HandleUART1                #   4
  • HandleNFCON                #   4                ; Added for 2440.
  • HandleUSBD                #   4
  • HandleUSBH                #   4
  • HandleIIC                #   4
  • HandleUART0         #   4
  • HandleSPI1                 #   4
  • HandleRTC                 #   4
  • HandleADC                 #   4
  • ;@0x33FF_FFA0
  •         END
更多回帖
