单片机学习小组
直播中
王冬梅
8年用户 137经验值
私信 关注
基于STM32f103ZET6库版本BMP180驱动程序
BMP180 驱动程序,基于 STM32f103ZET6 ,开发平台:Keil 5 ,库版本:HAL
(BMP180 driver, based on STM32f103ZET6, development platform: Keil 5, library version: HAL.)
使用硬件IIC的方式,读取 BMP180 中的寄存器值(0xAA)
利用LPME1函数修改,硬件IIC可完成目标,但不规范
开发平台:Keil 5
单片机源程序如下:
  •   * File Name          : main.c
  •   * Description        : Main program body
  •   * COPYRIGHT(c) 2018 STMicroelectronics
  •   * Redistribution and use in source and binary forms, with or without modification,
  •   * are permitted provided that the following conditions are met:
  •   *   1. Redistributions of source code must retain the above copyright notice,
  •   *      this list of conditions and the following disclaimer.
  •   *   2. Redistributions in binary form must reproduce the above copyright notice,
  •   *      this list of conditions and the following disclaimer in the documentation
  •   *      and/or other materials provided with the distribution.
  •   *   3. Neither the name of STMicroelectronics nor the names of its contributors
  •   *      may be used to endorse or promote products derived from this software
  •   *      without specific prior written permission.
  •   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  •   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  •   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  •   * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  •   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  •   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  •   * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  •   * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  •   * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  •   * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  • /* Includes ------------------------------------------------------------------*/
  • #include "stm32f1xx_hal.h"
  • #include "i2c.h"
  • #include "spi.h"
  • #include "usart.h"
  • #include "gpio.h"
  • /* USER CODE BEGIN Includes */
  • #include "bmp180.h"
  • /* USER CODE END Includes */
  • /* Private variables ---------------------------------------------------------*/
  • /* USER CODE BEGIN PV */
  • /* USER CODE END PV */
  • /* Private function prototypes -----------------------------------------------*/
  • void SystemClock_Config(void);
  • void Error_Handler(void);
  • /* USER CODE BEGIN PFP */
  • /* USER CODE END PFP */
  • /* USER CODE BEGIN 0 */
  • /* USER CODE END 0 */
  • int main(void)
  •     /* USER CODE BEGIN 1 */
  •     /* USER CODE END 1 */
  •     /* MCU Configuration----------------------------------------------------------*/
  •     /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  •     HAL_Init();
  •     /* Configure the system clock */
  •     SystemClock_Config();
  •     /* Initialize all configured peripherals */
  •     MX_GPIO_Init();
  •     MX_I2C1_Init();
  •     //MX_SPI1_Init();
  •     MX_USART1_UART_Init();
  •     /* USER CODE BEGIN 2 */
  •     float Temp = 10.0;
  •     float data[2] = {0};
  •     /* USER CODE END 2 */
  •     /* Infinite loop */
  •     /* USER CODE BEGIN WHILE */
  •     while (1)
  •     /* USER CODE END WHILE */
  •     /* USER CODE BEGIN 3 */
  •         //for(int i = 1000; i > 0; i--);
  •         //lpme1_example();
  •         lpme1_get_acc(data);
  •         //printf("Temperature: %.1f rn", Temp);
  •     /* USER CODE END 3 */
  • /** System Clock Configuration
  •     RCC_OscInitTypeDef RCC_OscInitStruct;
  •     RCC_ClkInitTypeDef RCC_ClkInitStruct;
  •     RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  •     RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  •     RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  •     RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  •     RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  •     RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  •     if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  •         Error_Handler();
  •     RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  •                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  •     RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  •     RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  •     RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  •     RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  •     if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  •         Error_Handler();
  •     HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  •     HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  •     /* SysTick_IRQn interrupt configuration */
  •     HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  • /* USER CODE BEGIN 4 */
  • /* USER CODE END 4 */
  •   * @brief  This function is executed in case of error occurrence.
  •   * @param  None
  •   * @retval None
  •   /* USER CODE BEGIN Error_Handler */
  •   /* User can add his own implementation to report the HAL error return state */
  •   while(1)
  •   /* USER CODE END Error_Handler */
  • #ifdef USE_FULL_ASSERT
  •    * @brief Reports the name of the source file and the source line number
  •    * where the assert_param error has occurred.
  •    * @param file: pointer to the source file name
  •    * @param line: assert_param error line source number
  • …………限于本文篇幅 余下代码请从电子发烧友下载附件…………
所有资料51hei提供下载:
    Cube_Demo_2_BMP180.zip
更多回帖
