单片机学习小组
直播中
姚秋月
8年用户 255经验值
私信 关注
system_stm32f10x.c文件内容分析
这个文件完成了写声明配置,他和对应的头文件的关系,头文件里做了些什么工作,为什么要这样
完成系统时钟的配置。
  • #include "STM32f10x.h"
  • #if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  • #define SYSCLK_FREQ_24MHz  24000000
  • #else
  •    #define SYSCLK_FREQ_72MHz  72000000
  • #endif
  • #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
  • #endif
  • #define VECT_TAB_OFFSET  0x0
  • #ifdef SYSCLK_FREQ_HSE
  •   uint32_t SystemCoreClock         = SYSCLK_FREQ_HSE;
  • #elif defined SYSCLK_FREQ_24MHz
  •   uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHz;
  • #elif defined SYSCLK_FREQ_36MHz
  •   uint32_t SystemCoreClock         = SYSCLK_FREQ_36MHz;
  • #elif defined SYSCLK_FREQ_48MHz
  •   uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHz;
  • #elif defined SYSCLK_FREQ_56MHz
  •   uint32_t SystemCoreClock         = SYSCLK_FREQ_56MHz;
  • #elif defined SYSCLK_FREQ_72MHz
  •   uint32_t SystemCoreClock         = SYSCLK_FREQ_72MHz;
  • #else
  •   uint32_t SystemCoreClock         = HSI_VALUE;
  • #endif
  • __I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
  • static void SetSysClock(void);
  •   static void SetSysClockToHSE(void);
  •   static void SetSysClockTo24(void);
  •   static void SetSysClockTo36(void);
  •   static void SetSysClockTo48(void);
  •   static void SetSysClockTo56(void);
  •   static void SetSysClockTo72(void);
  • #endif
  • #ifdef DATA_IN_ExtSRAM
  •   static void SystemInit_ExtMemCtl(void);
  • #endif
  • void SystemInit (void)
  •   RCC->CR |= (uint32_t)0x00000001;
  • #ifndef STM32F10X_CL
  •   RCC->CFGR &= (uint32_t)0xF8FF0000;
  • #else
  •   RCC->CFGR &= (uint32_t)0xF0FF0000;
  • #endif
  •   RCC->CR &= (uint32_t)0xFEF6FFFF;
  •   RCC->CR &= (uint32_t)0xFFFBFFFF;
  •   RCC->CFGR &= (uint32_t)0xFF80FFFF;
  • #ifdef STM32F10X_CL
  •   RCC->CR &= (uint32_t)0xEBFFFFFF;
  •   RCC->CIR = 0x00FF0000;
  •   RCC->CFGR2 = 0x00000000;
  • #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  •   RCC->CIR = 0x009F0000;
  • #else
  • #endif
  •     SystemInit_ExtMemCtl();
  •   #endif
  • #endif
  •   SetSysClock();
  • #ifdef VECT_TAB_SRAM
  •   SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET;
  • #else
  •   SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET;
  • #endif
  • void SystemCoreClockUpdate (void)
  •   uint32_t tmp = 0, pllmull = 0, pllsource = 0;
  •   uint32_t prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
  • #endif
  • #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  •   uint32_t prediv1factor = 0;
  • #endif
  •   tmp = RCC->CFGR & RCC_CFGR_SWS;
  •   switch (tmp)
  •     case 0x00:
  •       SystemCoreClock = HSI_VALUE;
  •       break;
  •     case 0x04:
  •       SystemCoreClock = HSE_VALUE;
  •       break;
  •     case 0x08:
  •       pllmull = RCC->CFGR & RCC_CFGR_PLLMULL;
  •       pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
  •       pllmull = ( pllmull >> 18) + 2;
  •       if (pllsource == 0x00)
  •         SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
  •       else
  •        prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
  •        SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
  • #else
  •         if ((RCC->CFGR & RCC_CFGR_PLLXTPRE) != (uint32_t)RESET)
  •           SystemCoreClock = (HSE_VALUE >> 1) * pllmull;
  •         else
  •           SystemCoreClock = HSE_VALUE * pllmull;
  • #endif
  • #else
  •       pllmull = pllmull >> 18;
  •       if (pllmull != 0x0D)
  •          pllmull += 2;
  •       else
  •         pllmull = 13 / 2;
  •       else
  •         prediv1source = RCC->CFGR2 & RCC_CFGR2_PREDIV1SRC;
  •         if (prediv1source == 0)
  •         else
  •           prediv2factor = ((RCC->CFGR2 & RCC_CFGR2_PREDIV2) >> 4) + 1;
  •           pll2mull = ((RCC->CFGR2 & RCC_CFGR2_PLL2MUL) >> 8 ) + 2;
  •           SystemCoreClock = (((HSE_VALUE / prediv2factor) * pll2mull) / prediv1factor) * pllmull;
  • #endif
  •       break;
  •     default:
  •       break;
  •   tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
  •   SystemCoreClock >>= tmp;
  •   SetSysClockToHSE();
  •   SetSysClockTo24();
  •   SetSysClockTo36();
  •   SetSysClockTo48();
  •   SetSysClockTo56();
  •   SetSysClockTo72();
  • #endif
  • void SystemInit_ExtMemCtl(void)
  •   RCC->AHBENR = 0x00000114;
  •   RCC->APB2ENR = 0x000001E0;
  •   GPIOD->CRL = 0x44BB44BB;
  •   GPIOD->CRH = 0xBBBBBBBB;
  •   GPIOE->CRL = 0xB44444BB;
  •   GPIOE->CRH = 0xBBBBBBBB;
  •   GPIOF->CRL = 0x44BBBBBB;
  •   GPIOF->CRH = 0xBBBB4444;
  •   GPIOG->CRL = 0x44BBBBBB;
  •   GPIOG->CRH = 0x44444B44;
  •   FSMC_Bank1->BTCR[4] = 0x00001011;
  •   FSMC_Bank1->BTCR[5] = 0x00000200;
  • #endif
  •   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  •   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  •   do
  •     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  •     StartUpCounter++;
  •   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  •   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  •     HSEStatus = (uint32_t)0x01;
  •   else
  •     HSEStatus = (uint32_t)0x00;
  •   if (HSEStatus == (uint32_t)0x01)
  • #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
  •     FLASH->ACR |= FLASH_ACR_PRFTBE;
  •     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  •     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
  • #else
  •     if (HSE_VALUE <= 24000000)
  • else
  •       FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
  • #endif
  • #endif
  •     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  •     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  •     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
  •     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  •     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_HSE;
  •     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x04)
  •   else
  •   do
  •     StartUpCounter++;
  •   else
  • #endif
  •     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  •                             RCC_CFGR_PLLMULL6);
  •     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  •                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  •     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  •                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
  •     RCC->CR |= RCC_CR_PLL2ON;
  •     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  • #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  •     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLMULL6);
  • #else
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL6);
  • #endif
  •     RCC->CR |= RCC_CR_PLLON;
  •     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  •     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  •     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  •   else
  •   do
  •     StartUpCounter++;
  •   else
  •                             RCC_CFGR_PLLMULL9);
  • #else
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL9);
  • #endif
  •   else
  •   do
  •     StartUpCounter++;
  •   else
  •     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
  •                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  • #else
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
  • #endif
  •   else
  •   do
  •     StartUpCounter++;
  •   else
  •     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
  •                             RCC_CFGR_PLLMULL7);
  • #else
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL7);
  • #endif
  •   else
  •   do
  •     StartUpCounter++;
  •   else
  • #else
  •                                         RCC_CFGR_PLLMULL));
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
  • #endif
  •   else
  • #endif
更多回帖
