单片机学习小组
直播中
李波波
8年用户 206经验值
私信 关注
STM32F107验证通过的CRC校验程序
STM32F107之CRC循环冗余校验码
下载:
    CRC循环冗余校验码.rar
  •   * @file    CRC/CRC_Calculation/main.c
  •   * @author  MCD Application Team
  •   * @version V3.5.0
  •   * @date    08-April-2011
  •   * @brief   Main program body.
  •   * @attention
  •   * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  •   * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  •   * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  •   * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  •   * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  •   * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
    © COPYRIGHT 2011 STMicroelectronics
  • /* Includes ------------------------------------------------------------------*/
  • #include "stm32f10x.h"
  • /** @addtogroup STM32F10x_StdPeriph_Examples
  • /** @addtogroup CRC_Calculation
  • /* Private typedef -----------------------------------------------------------*/
  • /* Private define ------------------------------------------------------------*/
  • #define BUFFER_SIZE    114
  • /* Private macro -------------------------------------------------------------*/
  • /* Private variables ---------------------------------------------------------*/
  • static const uint32_t DataBuffer[BUFFER_SIZE] =
  •     0x00001021, 0x20423063, 0x408450a5, 0x60c670e7, 0x9129a14a, 0xb16bc18c,
  •     0xd1ade1ce, 0xf1ef1231, 0x32732252, 0x52b54294, 0x72f762d6, 0x93398318,
  •     0xa35ad3bd, 0xc39cf3ff, 0xe3de2462, 0x34430420, 0x64e674c7, 0x44a45485,
  •     0xa56ab54b, 0x85289509, 0xf5cfc5ac, 0xd58d3653, 0x26721611, 0x063076d7,
  •     0x569546b4, 0xb75ba77a, 0x97198738, 0xf7dfe7fe, 0xc7bc48c4, 0x58e56886,
  •     0x78a70840, 0x18612802, 0xc9ccd9ed, 0xe98ef9af, 0x89489969, 0xa90ab92b,
  •     0x4ad47ab7, 0x6a961a71, 0x0a503a33, 0x2a12dbfd, 0xfbbfeb9e, 0x9b798b58,
  •     0xbb3bab1a, 0x6ca67c87, 0x5cc52c22, 0x3c030c60, 0x1c41edae, 0xfd8fcdec,
  •     0xad2abd0b, 0x8d689d49, 0x7e976eb6, 0x5ed54ef4, 0x2e321e51, 0x0e70ff9f,
  •     0xefbedfdd, 0xcffcbf1b, 0x9f598f78, 0x918881a9, 0xb1caa1eb, 0xd10cc12d,
  •     0xe16f1080, 0x00a130c2, 0x20e35004, 0x40257046, 0x83b99398, 0xa3fbb3da,
  •     0xc33dd31c, 0xe37ff35e, 0x129022f3, 0x32d24235, 0x52146277, 0x7256b5ea,
  •     0x95a88589, 0xf56ee54f, 0xd52cc50d, 0x34e224c3, 0x04817466, 0x64475424,
  •     0x4405a7db, 0xb7fa8799, 0xe75ff77e, 0xc71dd73c, 0x26d336f2, 0x069116b0,
  •     0x76764615, 0x5634d94c, 0xc96df90e, 0xe92f99c8, 0xb98aa9ab, 0x58444865,
  •     0x78066827, 0x18c008e1, 0x28a3cb7d, 0xdb5ceb3f, 0xfb1e8bf9, 0x9bd8abbb,
  •     0x4a755a54, 0x6a377a16, 0x0af11ad0, 0x2ab33a92, 0xed0fdd6c, 0xcd4dbdaa,
  •     0xad8b9de8, 0x8dc97c26, 0x5c644c45, 0x3ca22c83, 0x1ce00cc1, 0xef1fff3e,
  •     0xdf7caf9b, 0xbfba8fd9, 0x9ff86e17, 0x7e364e55, 0x2e933eb2, 0x0ed11ef0
  • __IO uint32_t CRCValue = 0;
  • /* Private function prototypes -----------------------------------------------*/
  • void Delay(__IO uint32_t nCount);
  • /* Private functions ---------------------------------------------------------*/
  •   * @brief  Main program.
  •   * @param  None
  •   * @retval None
  • int main(void)
  •   /*!< At this stage the microcontroller clock setting is already configured,
  •        this is done through SystemInit() function which is called from startup
  •        file (startup_stm32f10x_xx.s) before to branch to application main.
  •        To reconfigure the default setting of SystemInit() function, refer to
  •        system_stm32f10x.c file
  •   /* Enable CRC clock */
  •   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_CRC, ENABLE);
  •   /* Compute the CRC of "DataBuffer" */
  •   CRCValue = CRC_CalcBlockCRC((uint32_t *)DataBuffer, BUFFER_SIZE);
  •   while (1)
  •   * @brief  Inserts a delay time.
  •   * @param  nCount: specifies the delay time length.
  •   * @retval None
  •   for(; nCount != 0; nCount--);
  • #ifdef  USE_FULL_ASSERT
  •   * @brief  Reports the name of the source file and the source line number
  •   *         where the assert_param error has occurred.
  •   * @param  file: pointer to the source file name
  •   * @param  line: assert_param error line source number
  •   * @retval None
  • void assert_failed(uint8_t* file, uint32_t line)
  •   /* User can add his own implementation to report the file name and line number,
  •      ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
  •   /* Infinite loop */
  •   while (1)
  • #endif
  • /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
更多回帖
