TI论坛
直播中
侯晓萃
8年用户 194经验值
私信 关注
买的英蓓特BeagleBone Black,用了两个月都没问题,现在插上电源,电源指示灯闪一下就灭了,无法启动怎么办?
BBB用了两个月都没问题,刚才突然就没办法启动了,现在插上电源,电源指示灯闪一下就灭了,我检查了下貌似也没有短路,怎么会这样哇
回帖(11)
王玉宁
2018-6-21 01:15:39
貌似没有短路?
请根据BBB的原理图仔细检查下各路电源是否正常
举报
范逊敏
2018-6-21 01:21:31
引用: 林宇宣55 发表于 2018-6-21 01:15
貌似没有短路?
电源是什么供电的,检查一下电源
举报
朱志兴
2018-6-21 01:39:49
應該是壞了,請RMA
我兩塊BBB也都出現
原因是不正常斷電,已經有許多人反映這問題
官網已經明白說明,可笑的是TI FAE卻沒有人知道!!!
http://www.elinux.org/Beagleboard:BeagleBoneBlack#Improper_Power_Down....All_Revisions
Improper Power Down....All Revisions
We have been noticing a very small number of boards that are experiencing power issues, where the LED flashes and the board does not power up. We have been chasing this for a while now and due to the small number of boards that have the issue and the fact that the issue can also be caused by having things connected to IO pins not powered correctly, it has been hard to nail down. Our initial take was that it was a manufacturing issue on some boards, but we could never prove that. Based on the latest information we have gathered, this appears to be an instance where the PMIC does not power down the processor in the right order due to the violent removal of the power cables, either USB or DC. So, we are recommending that the power button be used to power off the board or by issuing the Halt command. After that you can remove the power cable. If everyone follows this process, we should see a decrease in these issues, but it will take a while for the results, either good or bad, to show up. This will also help prevent the contamination of the eMMC and the SD cards by allowing the kernel to shutdown properly before power is removed.
举报
侯晓萃
2018-6-21 01:58:18
引用: rfffwef 发表于 2018-6-21 01:21
电源是什么供电的,检查一下电源
一直用的是5V,2A的电源,换了一个还是这样,用USB供电也是这样,指示灯就只闪一下,然后就灭了。
举报
更多回帖
