TI论坛
直播中
李梓
8年用户 246经验值
私信 关注
请教Am335x作为master, slave add如何设置呢?
大家好:
我是根据Startware中的 MLO 使用I2C0与PMIC例程来修改的。程序调试卡在  while(I2CMasterBusBusy(SOC_I2C_1_REGS) == 0); 详情如下:
一. 按照套路 修改pinmux,修改时钟初始化等,具体如下:
1. 使用I2C1  脚位E17、E18。
  1. void  I2C_PinMuxSetup(void)
  2. [
  3. //I2C1_SCL  E17
  4. HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_RTSN(0))  = 0x73;
  5. //I2C1_SDA  E18
  6. HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_CTSN(0)) =  0x73;
  7. ]
  8. 2. 时钟初始化参考 startware_02_01_01platformevmAm335xhsi3c.c中的void I2C1ModuleClkConfig(void),代码如下:
  9. void I2C_1_ModuleClkConfig(void) (只是更改名称而已)
  10. [
  11. HWREG(SOC_PRCM_REGS + CM_PER_L3S_CLKSTCTRL) |=                              CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
  12.     while((HWREG(SOC_PRCM_REGS + CM_PER_L3S_CLKSTCTRL) &      CM_PER_L3S_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
  13.     HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKSTCTRL) |=                              CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
  14.     while((HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKSTCTRL) &      CM_PER_L3_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
  15.     HWREG(SOC_PRCM_REGS + CM_PER_L3_INSTR_CLKCTRL) |=                              CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
  16.     while((HWREG(SOC_PRCM_REGS + CM_PER_L3_INSTR_CLKCTRL) &                                CM_PER_L3_INSTR_CLKCTRL_MODULEMODE) !=                                    CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE);
  17.     HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKCTRL) |=                              CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
  18.     while((HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKCTRL) &         CM_PER_L3_CLKCTRL_MODULEMODE) != CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE);
  19.     HWREG(SOC_PRCM_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) |=                              CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
  20.     while((HWREG(SOC_PRCM_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &                               CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL) !=                                 CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
  21.     HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKSTCTRL) |=                              CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
  22.     while((HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKSTCTRL) &                              CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=                                CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
  23.     HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKCTRL) |=                              CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
  24.     while((HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKCTRL) &       CM_PER_L4LS_CLKCTRL_MODULEMODE) != CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
  25.     HWREG(SOC_PRCM_REGS + CM_PER_I2C1_CLKCTRL) |=                              CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
  26.     while((HWREG(SOC_PRCM_REGS + CM_PER_I2C1_CLKCTRL) &       CM_PER_I2C1_CLKCTRL_MODULEMODE) != CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
  27.     while(!(HWREG(SOC_PRCM_REGS + CM_PER_L3S_CLKSTCTRL) &             CM_PER_L3S_CLKSTCTRL_CLKACtiVITY_L3S_GCLK));
  28.     while(!(HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKSTCTRL) &             CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
  29.     while(!(HWREG(SOC_PRCM_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &            (CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK |             CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK)));
  30.     while(!(HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKSTCTRL) &            (CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |             CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
  31. ]
  32. 3. 修改I2C0的SetupReception(),改为I2C1的,代码如下:
  33. void I2C_1_SetupReception(unsigned int recvlen)
  34. [
  35. I  2CSetDataCount(SOC_I2C_1_REGS, 1);
  36.     I2C_1_CleanupInterrupts();
  37.     I2CMasterControl(SOC_I2C_1_REGS, I2C_CFG_MST_TX);     I2CMasterStart(SOC_I2C_1_REGS);
  38.     while(I2CMasterBusBusy(SOC_I2C_1_REGS) == 0);   //调试时此处一直为真,不知为何?
  39.     I2CMasterDataPut(SOC_I2C_1_REGS, dataToSlave[txCount]);
  40.    I2CMasterIntClearEx(SOC_I2C_1_REGS, I2C_INT_TRANSMIT_READY);
  41. 。。。。
二. 另请教Am335x作为master, slave add如何设置呢? 我调试时使用0x40  , 35390的datasheet 如附件
不知还有哪里设置有问题,所以请大家帮助,先行谢过。
更多回帖
