TI论坛
直播中
乔银栓
7年用户 249经验值
私信 关注
请问一下有关于AM335x平台上移植uCOS方面的参考吗,或者有什么经验吗?
您好,
    请问一下你们有关于AM335x平台上移植uCOS方面的参考吗,或者有什么经验吗?
回帖(4)
王山崎
2018-6-21 03:33:22
TI官方不支持UCOS
可以到其他网站搜搜
举报
李维兴
2018-6-21 03:51:35
不知道您要在AM335x平台上移植uCOS是出于什么考虑呢?简单操作还是实时性要求呢?
举报
乔银栓
2018-6-21 04:05:04
是对于实时性的处理,我看过ti官方的sy***ios系统,但是关于这方面的demo比较少,我也试着去使用了一下,不知道为何仿真就出错,这是我的代码:
Int main()
    Task_Handle task;
    Error_Block eb;
    Task_Params taskParams;
    /* Enabling functional clocks for GPIO1 instance. */
    GPIO1ModuleClkConfig();
   /* Selecting GPIO1[23] pin for use. */
   GPIO1Pin23PinMuxSetup();
   UARTSetup();
   /* Enabling the GPIO module. */
   GPIOModuleEnable(GPIO_INSTANCE_ADDRESS);
   /* Resetting the GPIO module. */
   GPIOModuleReset(GPIO_INSTANCE_ADDRESS);
   /* Setting the GPIO pin as an output pin. */
   GPIODirModeSet(GPIO_INSTANCE_ADDRESS,
   GPIO_INSTANCE_PIN_NUMBER,
   GPIO_DIR_OUTPUT);
    UARTPuts("Enter StarterWare Application...rnn", -1);
   System_printf("enter main()n");
 Task_Params_init(&taskParams);
 taskParams.stackSize = 20480;
 taskParams.priority = 1;
 Error_init(&eb);
 task = Task_create(taskFxn, &taskParams, &eb);
 taskParams.priority = 2;
 task = Task_create(taskFx1, &taskParams, &eb);
 taskParams.priority = 3;
  task = Task_create(taskFx2, &taskParams, &eb);
 if (task == NULL) [
  System_printf("Task_create() failed!n");
  BIOS_exit(0);
 BIOS_start();    /* does not return */
 return(0);
仿真后的结果:
[CortxA8]  0x44e000ac  R8  = 0x4030d028
R1 = 0x00000000  R9  = 0x4030d008
R2 = 0x00000064  R10 = 0x4030d484
R3 = 0xfffffffd  R11 = 0x00029940
R4 = 0x00000000  R12 = 0xffffffff
R5 = 0x00000200  SP(R13) = 0x800095e0
R6 = 0x48060000  LR(R14) = 0x800111dc
R7 = 0x00000020  PC(R15) = 0x800095e0
PSR = 0x48060000
DFSR = 0x00000005  IFSR = 0x00000000
DFAR = 0x44e000ac  IFAR = 0x00000000
ti.sy***ios.family.arm.exc.Exception: line 205: E_dataAbort: pc = 0x800095e0, lr = 0x800111dc.
xdc.runtime.Error.raise: terminating execution
然后就跳入
static void loader_exit(void)
#if defined(EMBED_CIO_BP)
   __asm("         .global C$$EXITE");
#if defined(__32bis__)
   __asm("C$$EXITE:.word 0xDEFED0FE");
#else
   __asm("  .align  4");
#if defined(__big_endian__)
   __asm("C$$EXITE:.half 0xDEFE");
#else
   __asm("C$$EXITE:.half 0xD0FE");
#endif /* __big_endian__ */
#endif /* __32bis__      */
#else  /* !EMBED_CIO_BP */
   __asm("        .global C$$EXIT");
   __asm("C$$EXIT: nop");
#endif
请教一下这是什么原因呢?
举报
乔银栓
2018-6-21 04:14:53
Int main()
我知道了,是因为没有加内存映射MMU初始化!
举报
更多回帖
