TI论坛
直播中
李广旭
7年用户 166经验值
私信 关注
请问谁有AM335X GPIO2 的时钟配置函数void GPIO2Moduleclkconfig(void)?求分享
谁有AM335X GPIO2的时钟配置函数void GPIO2Moduleclkconfig(void)?或者告诉我下怎么从GPIO1的时钟中修改,startware里面没有,多谢!!!
回帖(3)
李维兴
2018-6-21 07:55:11
无论是GPIO123,配置都差不多,大概就是看GPIO在哪一个时钟源下面,一步一步打开就好,下面是GPIO1的配置例程
void GPIO1ModuleClkConfig(void)
/* Configuring L3 Interface Clocks. */
/* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) |=
CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
/* Waiting for MODULEMODE field to reflect the written value. */
while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) &
CM_PER_L3_CLKCTRL_MODULEMODE));
/* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) |=
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) &
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
/* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) |=
CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
/* Waiting for CLKTRCTRL field to reflect the written value. */
while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
/* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) |=
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
/*Waiting for CLKTRCTRL field to reflect the written value. */
while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
/* Writing to MODULEMODE field in CM_PER_OCPWP_CLKCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) |=
CM_PER_OCPWP_CLKCTRL_MODULEMODE_ENABLE;
while(CM_PER_OCPWP_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) &
CM_PER_OCPWP_CLKCTRL_MODULEMODE));
/* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) |=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
/* Checking fields for necessary values. */
/* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
CM_PER_L3_CLKCTRL_IDLEST));
** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
** desired value.
while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
CM_PER_L3_INSTR_CLKCTRL_IDLEST));
** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
** attain the desired value.
while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
** Waiting for STBYST bit in CM_PER_OCPWP_CLKCTRL register to attain
** the desired value.
/* while((CM_PER_OCPWP_CLKCTRL_STBYST_FUNC <<
CM_PER_OCPWP_CLKCTRL_STBYST_SHIFT) !=
CM_PER_OCPWP_CLKCTRL_STBYST)); */
** Waiting for IDLEST field in CM_PER_OCPWP_CLKCTRL register to attain the
** desired value.
while((CM_PER_OCPWP_CLKCTRL_IDLEST_FUNC <<
CM_PER_OCPWP_CLKCTRL_IDLEST_SHIFT) !=
CM_PER_OCPWP_CLKCTRL_IDLEST));
** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
** register to attain the desired value.
while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
** to attain the desired value.
while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
/* Configuring L4 Interface Clocks. */
/* Writing to MODULEMODE field of CM_PER_L4LS_CLKCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) |=
CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
while(CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) &
CM_PER_L4LS_CLKCTRL_MODULEMODE));
/* Writing to CLKTRCTRL field of CM_PER_L4LS_CLKSTCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) |=
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while(CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) &
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL));
/* Verifying if other configurations are correct. */
** Waiting for IDLEST field in CM_PER_L4LS_CLKCTRL register to attain the
** desired value.
while((CM_PER_L4LS_CLKCTRL_IDLEST_FUNC <<
CM_PER_L4LS_CLKCTRL_IDLEST_SHIFT) !=
CM_PER_L4LS_CLKCTRL_IDLEST));
** Waiting for CLKACTIVITY_L4LS_GCLK bit in CM_PER_L4LS_CLKSTCTRL register
while(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK !=
CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK));
** Waiting for CLKACTIVITY_OCPWP_L4_GCLK bit in CM_PER_OCPWP_L3_CLKSTCTRL
/* while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK !=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK)); */
/* Performing configurations for GPIO1 instance. */
/* Writing to MODULEMODE field of CM_PER_GPIO1_CLKCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_GPIO1_CLKCTRL) |=
CM_PER_GPIO1_CLKCTRL_MODULEMODE_ENABLE;
while(CM_PER_GPIO1_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_PER_REGS + CM_PER_GPIO1_CLKCTRL) &
CM_PER_GPIO1_CLKCTRL_MODULEMODE));
** Writing to OPTFCLKEN_GPIO_1_GDBCLK bit in CM_PER_GPIO1_CLKCTRL
** register.
CM_PER_GPIO1_CLKCTRL_OPTFCLKEN_GPIO_1_GDBCLK;
** Waiting for OPTFCLKEN_GPIO_1_GDBCLK bit to reflect the desired
** value.
while(CM_PER_GPIO1_CLKCTRL_OPTFCLKEN_GPIO_1_GDBCLK !=
CM_PER_GPIO1_CLKCTRL_OPTFCLKEN_GPIO_1_GDBCLK));
** Waiting for IDLEST field in CM_PER_GPIO1_CLKCTRL register to attain the
** desired value.
while((CM_PER_GPIO1_CLKCTRL_IDLEST_FUNC <<
CM_PER_GPIO1_CLKCTRL_IDLEST_SHIFT) !=
CM_PER_GPIO1_CLKCTRL_IDLEST));
** Waiting for CLKACTIVITY_GPIO_1_GDBCLK bit in CM_PER_L4LS_CLKSTCTRL
** register to attain desired value.
while(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_1_GDBCLK !=
CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_1_GDBCLK));
举报
李广旭
2018-6-21 08:13:44
对比GPIO1配置的,好像还是不行,希望搞过的人帮看看,多谢!
void GPIO2ModuleClkConfig(void)
    ** desired value.
    ** desired value.
    ** desired value.
    /* Performing configurations for GPIO2 instance. */
    HWREG(SOC_CM_PER_REGS + CM_PER_GPIO2_CLKCTRL) |=
          CM_PER_GPIO2_CLKCTRL_MODULEMODE_ENABLE;
    while(CM_PER_GPIO2_CLKCTRL_MODULEMODE_ENABLE !=
          (HWREG(SOC_CM_PER_REGS + CM_PER_GPIO2_CLKCTRL) &
           CM_PER_GPIO2_CLKCTRL_MODULEMODE));
    ** register.
          CM_PER_GPIO2_CLKCTRL_OPTFCLKEN_GPIO_2_GDBCLK;
    ** value.
    while(CM_PER_GPIO2_CLKCTRL_OPTFCLKEN_GPIO_2_GDBCLK !=
           CM_PER_GPIO2_CLKCTRL_OPTFCLKEN_GPIO_2_GDBCLK));
    ** desired value.
    while((CM_PER_GPIO2_CLKCTRL_IDLEST_FUNC <<
           CM_PER_GPIO2_CLKCTRL_IDLEST_SHIFT) !=
            CM_PER_GPIO2_CLKCTRL_IDLEST));
    while(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_2_GDBCLK !=
           CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_2_GDBCLK));
举报
罗兰君
2018-6-21 08:32:32
首先GPIO1配置之后,是可以正常工作的么?
举报
更多回帖
